Hurricane Board Support Package.
More...
| file | bsp.h |
| | Global BSP definitions.
| file | tm27.h |
| | This header file includes the generic tm27 support implementation.
#define | BSP_FEATURE_IRQ_EXTENSION |
#define | BSP_SHARED_HANDLER_SUPPORT 1 |
#define | CPU_CLOCK_RATE_MHZ (200) |
#define | CLOCKS_PER_MICROSECOND ( CPU_CLOCK_RATE_MHZ ) /* equivalent to CPU clock speed in MHz */ |
| #define | rtems_bsp_delay(microseconds) |
#define | RAM_START 0 |
#define | RAM_END 0x100000 |
void | WriteDisplay (char *string) |
uint32_t | mips_get_timer (void) |
void | init_tlb (void) |
void | resettlb (int i) |
◆ rtems_bsp_delay
| #define rtems_bsp_delay |
microseconds | ) |
Value: { \
uint32_t _end_clock = \
mips_get_timer() + microseconds * CLOCKS_PER_MICROSECOND; \
_end_clock %= 0x100000000; \
while ( _end_clock < mips_get_timer() ); \
while ( _end_clock > mips_get_timer() ); \
