RTEMS 7.0-rc1
SMDK2410 Board Support Package. More...
Modules | |
| SMC Disk Driver | |
| SMC Disk Driver Support. | |
Files | |
| file | btimer.c |
| S3C2400 Timer driver. | |
| file | clockdrv.c |
| S3C2400 clock specific using the System Timer. | |
| file | bsp.h |
| Global BSP definitons. | |
| file | s3c2410.h |
| This header file s32410 hardware information. | |
| file | s3c24xx.h |
| This header file selects the right code for different Samsung CPUs. | |
| file | tm27.h |
| This header file includes the generic tm27 support implementation. | |
| void * | bsp_idle_thread (uintptr_t ignored) |
| This BSP provides its own IDLE thread to override the RTEMS one. | |
| uint32_t | get_FCLK (void) |
| functions to get the differents s3c2400 clks | |
| uint32_t | get_HCLK (void) |
| uint32_t | get_PCLK (void) |
| uint32_t | get_UCLK (void) |
| void * bsp_idle_thread | ( | uintptr_t | ignored | ) |
So we prototype it and define the constant confdefs.h expects to configure a BSP specific one.
This idle task sets the power mode to idle. This causes the processor clock to be stopped, while on-chip peripherals remain active. Any enabled interrupt from a peripheral or an external interrupt source will cause the processor to resume execution.
To enable the idle task use the following in the system configuration:
Optimized idle task.
The MSR[POW] bit is set to put the CPU into the low power mode defined in HID0. HID0 is set during starup in start.S.
