RTEMS 7.0-rc1
Modules | Data Structures | Macros | Typedefs | Enumerations | Functions | Variables
This group contains AArch64 Board Support Packages. More...
 AMD Zynq UltraScale+ MPSoC and RFSoC - Application Processing Unit
 This group contains the BSP for the Application Processing Unit (APU) contained in AMD Zynq UltraScale+ MPSoC and RFSoC devices.
 Shared
 This group contains support shared by AArch64 Board Support Packages.
struct  Cache_Error_Info
 Structure containing information about a Cache error. More...
struct  OCM_Error_Info
 Structure containing information about a OCM ECC error. More...
struct  DDR_Error_Info
 Structure containing information about a DDR ECC error. More...
#define BSP_ARM_GIC_CPUIF_BASE   0x08010000
#define BSP_ARM_GIC_DIST_BASE   0x08000000
#define BSP_ARM_GIC_REDIST_BASE   0x080A0000
#define BSP_A53_QEMU_VPL011_BASE   0x9000000
#define BSP_A53_QEMU_VPL011_LENGTH   0x1000
#define BSP_A72_QEMU_VPL011_BASE   0x9000000
#define BSP_A72_QEMU_VPL011_LENGTH   0x1000
#define BSP_FDT_IS_SUPPORTED
#define BSP_ARM_GIC_CPUIF_BASE   0xFF842000
#define BSP_ARM_GIC_DIST_BASE   0xFF841000
#define BSP_RESET_SMC
#define BSP_ARM_GIC_CPUIF_BASE   0xf9040000
#define BSP_ARM_GIC_DIST_BASE   0xf9000000
#define BSP_ARM_GIC_REDIST_BASE   0xf9080000
typedef void(* zynqmp_ecc_handler) (ECC_Event_Type event, void *data)
 Typedef for ECC handlers.
enum  ECC_Event_Type {
  L1_CACHE , L2_CACHE , L1_L2_CACHE , OCM_RAM ,
  DDR_RAM
 Enumeration describing the possible types of ECC events.
enum  Cache_Error_RAM_ID {
  RAM_ID_L1I_TAG , RAM_ID_L1I_DATA , RAM_ID_L1D_TAG , RAM_ID_L1D_DATA ,
  RAM_ID_L1D_DIRTY , RAM_ID_TLB , RAM_ID_L2_TAG , RAM_ID_L2_DATA ,
  RAM_ID_SCU , RAM_ID_UNKNOWN
 The specific locations where a cache error can originate.
enum  OCM_Error_Type { OCM_UNCORRECTABLE , OCM_UNCORRECTABLE_RMW , OCM_CORRECTABLE }
 The types of OCM ECC errors.
enum  DDR_Error_Type { DDR_UNCORRECTABLE , DDR_CORRECTABLE }
 The types of DDR ECC errors.
BSP_START_TEXT_SECTION void raspberrypi_4_setup_mmu_and_cache (void)
BSP_START_TEXT_SECTION void rpi_setup_secondary_cpu_mmu_and_cache (void)
BSP_START_TEXT_SECTION void versal_setup_mmu_and_cache (void)
 Versal specific set up of the MMU.
void versal_debug_console_flush (void)
uint32_t versal_clock_i2c0 (void)
uint32_t versal_clock_i2c1 (void)
void zynqmp_ecc_register_handler (zynqmp_ecc_handler handler)
int zynqmp_ecc_enable (ECC_Event_Type event)
 Enable ECC error reporting.
void zynqmp_ocm_inject_fault (void)
 Injects an ECC fault in the On-Chip Memory (OCM)
void zynqmp_ecc_init (void)
 Initialize ECC reporting support.
void zynqmp_ecc_init_bsp (void)
 Initialize BSP-specific ECC reporting.
rtems_status_code zynqmp_configure_cache_ecc (void)
 Configure Cache ECC reporting.
rtems_status_code zynqmp_configure_ocm_ecc (void)
 Configure On-Chip Memory (OCM) ECC reporting.
rtems_status_code zynqmp_configure_ddr_ecc (void)
 Configure DDR Memory ECC reporting.
void zynqmp_invoke_ecc_handler (ECC_Event_Type event, void *data)
 Invoke the ECC error handler.
const unsigned char bcm2711_rpi_4_b_dtb []
const size_t bcm2711_rpi_4_b_dtb_size
Typedef Documentation
◆ zynqmp_ecc_handler
Functions matching this prototype can be registered as the handler for ECC event callbacks. The data argument is a struct describing the event that occurred.
◆ versal_setup_mmu_and_cache()
BSP_START_TEXT_SECTION void versal_setup_mmu_and_cache ( void  )
Provide in the application to override the defaults in the BSP.
◆ zynqmp_ecc_enable()
int zynqmp_ecc_enable ( ECC_Event_Type  event)
Enables ECC error reporting for the specified subsystem.
Parameters
eventThe ECC error event type to enable
◆ zynqmp_ecc_init()
void zynqmp_ecc_init ( void  )
This initializes the base ECC event reporting support for the platform.
◆ zynqmp_ecc_init_bsp()
void zynqmp_ecc_init_bsp ( void  )
Various BSPs may have different ECC capabilities. This allows those BSPs to initialize those facilities as necessary.
◆ zynqmp_ecc_register_handler()
void zynqmp_ecc_register_handler ( zynqmp_ecc_handler  handler)
Note that the provided handler may be called from interrupt context.
Parameters
handlerThe handler to be called for all ECC error events
◆ zynqmp_invoke_ecc_handler()
void zynqmp_invoke_ecc_handler ( ECC_Event_Type  event,
void *  data
Parameters
eventThe ECC error event type to be raised
dataThe details associated with the raised ECC error
