RTEMS 7.0-rc1
RTEMS CAN Chip Info. | |
Arguments that can be used with RTEMS_CAN_CHIP_GET_INFO IOCTL command. | |
| #define | RTEMS_CAN_CHIP_BITRATE ( 1 ) |
| This define specifies user wants to obtain controller's nominal bitrate via RTEMS_CAN_CHIP_GET_INFO ioctl. | |
| #define | RTEMS_CAN_CHIP_DBITRATE ( 2 ) |
| This define specifies user wants to obtain controller's data bitrate via RTEMS_CAN_CHIP_GET_INFO ioctl. | |
| #define | RTEMS_CAN_CHIP_NUSERS ( 3 ) |
| This define specifies user wants to obtain number of users using the controller via RTEMS_CAN_CHIP_GET_INFO ioctl. | |
| #define | RTEMS_CAN_CHIP_FLAGS ( 4 ) |
| This define specifies user wants to obtain controller's flags via RTEMS_CAN_CHIP_GET_INFO ioctl. Refer to CANChip for flags definitions. | |
| #define | RTEMS_CAN_CHIP_MODE ( 5 ) |
| This define specifies user wants to obtain currently set controller's modes via RTEMS_CAN_CHIP_GET_INFO ioctl. | |
| #define | RTEMS_CAN_CHIP_MODE_SUPPORTED ( 6 ) |
| This define specifies user wants to obtain modes supported by the controller via RTEMS_CAN_CHIP_GET_INFO ioctl. | |
