RTEMS 7.0-rc1
mmu-config.c File Reference
This source file contains the definition of aarch64_mmu_config_table and aarch64_mmu_config_table_size. More...
#include <bsp.h>
#include <bsp/aarch64-mmu.h>
#include <bsp/start.h>
#include <libcpu/mmu-vmsav8-64.h>
BSP_START_DATA_SECTION const aarch64_mmu_config_entry aarch64_mmu_config_table []
 This is the AArch64 MMU configuration table.
BSP_START_DATA_SECTION const size_t aarch64_mmu_config_table_size
 This is the count of entries in the AArch64 MMU configuration table.
Variable Documentation
◆ aarch64_mmu_config_table
BSP_START_DATA_SECTION const aarch64_mmu_config_entry aarch64_mmu_config_table[]
Initial value:
AARCH64_MMU_DEFAULT_SECTIONS,
.begin = 0xf9000000U,
.end = 0xf9100000U,
.flags = AARCH64_MMU_DEVICE
.begin = 0xfd000000U,
.end = 0xffc00000U,
.begin = BSP_XEN_VPL011_BASE,
.end = BSP_XEN_VPL011_BASE + BSP_XEN_VPL011_LENGTH,
.begin = BSP_ARM_GIC_CPUIF_BASE,
.end = BSP_ARM_GIC_CPUIF_BASE + BSP_ARM_GIC_CPUIF_LENGTH,
.begin = BSP_ARM_GIC_DIST_BASE,
.end = BSP_ARM_GIC_DIST_BASE + BSP_ARM_GIC_DIST_LENGTH,
The default table is provided by the BSP. Applications may provide their own.
◆ aarch64_mmu_config_table_size
Initial value:
Definition: mmu-config.c:44
#define RTEMS_ARRAY_SIZE(_array)
Gets the element count of the array.
Definition: basedefs.h:244
