RTEMS 6.3-rc1
Test context for spec:/rtems/barrier/req/wait test case. More...
rtems_id main_id
rtems_id high_worker_id
rtems_id low_worker_id
rtems_id manual_release_id
rtems_id auto_release_id
rtems_id id
rtems_interval timeout
rtems_status_code status
struct {
   size_t   pci [3]
 This member defines the pre-condition indices for the next action.
   size_t   pcs [3]
 This member defines the pre-condition states for the next action.
   bool   in_action_loop
 If this member is true, then the test action loop is executed.
   size_t   index
 This member contains the next transition map index.
   RtemsBarrierReqWait_Entry   entry
 This member contains the current transition map entry.
   bool   skip
 If this member is true, then the current transition variant should be skipped.
Map
