RTEMS 6.3-rc1
BASIC_SETTING - Basic Setting | |
| #define | TSC_BASIC_SETTING_AUTO_MEASURE_MASK (0x1U) |
| #define | TSC_BASIC_SETTING_AUTO_MEASURE_SHIFT (0U) |
| #define | TSC_BASIC_SETTING_AUTO_MEASURE(x) (((uint32_t)(((uint32_t)(x)) << TSC_BASIC_SETTING_AUTO_MEASURE_SHIFT)) & TSC_BASIC_SETTING_AUTO_MEASURE_MASK) |
| #define | TSC_BASIC_SETTING_WIRE_4_5_MASK (0x10U) |
| #define | TSC_BASIC_SETTING_WIRE_4_5_SHIFT (4U) |
| #define | TSC_BASIC_SETTING_WIRE_4_5(x) (((uint32_t)(((uint32_t)(x)) << TSC_BASIC_SETTING_WIRE_4_5_SHIFT)) & TSC_BASIC_SETTING_WIRE_4_5_MASK) |
| #define | TSC_BASIC_SETTING_MEASURE_DELAY_TIME_MASK (0xFFFFFF00U) |
| #define | TSC_BASIC_SETTING_MEASURE_DELAY_TIME_SHIFT (8U) |
| #define | TSC_BASIC_SETTING_MEASURE_DELAY_TIME(x) (((uint32_t)(((uint32_t)(x)) << TSC_BASIC_SETTING_MEASURE_DELAY_TIME_SHIFT)) & TSC_BASIC_SETTING_MEASURE_DELAY_TIME_MASK) |
FLOW_CONTROL - Flow Control | |
| #define | TSC_FLOW_CONTROL_SW_RST_MASK (0x1U) |
| #define | TSC_FLOW_CONTROL_SW_RST_SHIFT (0U) |
| #define | TSC_FLOW_CONTROL_SW_RST(x) (((uint32_t)(((uint32_t)(x)) << TSC_FLOW_CONTROL_SW_RST_SHIFT)) & TSC_FLOW_CONTROL_SW_RST_MASK) |
| #define | TSC_FLOW_CONTROL_START_MEASURE_MASK (0x10U) |
| #define | TSC_FLOW_CONTROL_START_MEASURE_SHIFT (4U) |
| #define | TSC_FLOW_CONTROL_START_MEASURE(x) (((uint32_t)(((uint32_t)(x)) << TSC_FLOW_CONTROL_START_MEASURE_SHIFT)) & TSC_FLOW_CONTROL_START_MEASURE_MASK) |
| #define | TSC_FLOW_CONTROL_DROP_MEASURE_MASK (0x100U) |
| #define | TSC_FLOW_CONTROL_DROP_MEASURE_SHIFT (8U) |
| #define | TSC_FLOW_CONTROL_DROP_MEASURE(x) (((uint32_t)(((uint32_t)(x)) << TSC_FLOW_CONTROL_DROP_MEASURE_SHIFT)) & TSC_FLOW_CONTROL_DROP_MEASURE_MASK) |
| #define | TSC_FLOW_CONTROL_START_SENSE_MASK (0x1000U) |
| #define | TSC_FLOW_CONTROL_START_SENSE_SHIFT (12U) |
| #define | TSC_FLOW_CONTROL_START_SENSE(x) (((uint32_t)(((uint32_t)(x)) << TSC_FLOW_CONTROL_START_SENSE_SHIFT)) & TSC_FLOW_CONTROL_START_SENSE_MASK) |
| #define | TSC_FLOW_CONTROL_DISABLE_MASK (0x10000U) |
| #define | TSC_FLOW_CONTROL_DISABLE_SHIFT (16U) |
| #define | TSC_FLOW_CONTROL_DISABLE(x) (((uint32_t)(((uint32_t)(x)) << TSC_FLOW_CONTROL_DISABLE_SHIFT)) & TSC_FLOW_CONTROL_DISABLE_MASK) |
MEASEURE_VALUE - Measure Value | |
| #define | TSC_MEASEURE_VALUE_Y_VALUE_MASK (0xFFFU) |
| #define | TSC_MEASEURE_VALUE_Y_VALUE_SHIFT (0U) |
| #define | TSC_MEASEURE_VALUE_Y_VALUE(x) (((uint32_t)(((uint32_t)(x)) << TSC_MEASEURE_VALUE_Y_VALUE_SHIFT)) & TSC_MEASEURE_VALUE_Y_VALUE_MASK) |
| #define | TSC_MEASEURE_VALUE_X_VALUE_MASK (0xFFF0000U) |
| #define | TSC_MEASEURE_VALUE_X_VALUE_SHIFT (16U) |
| #define | TSC_MEASEURE_VALUE_X_VALUE(x) (((uint32_t)(((uint32_t)(x)) << TSC_MEASEURE_VALUE_X_VALUE_SHIFT)) & TSC_MEASEURE_VALUE_X_VALUE_MASK) |
INT_EN - Interrupt Enable | |
| #define | TSC_INT_EN_MEASURE_INT_EN_MASK (0x1U) |
| #define | TSC_INT_EN_MEASURE_INT_EN_SHIFT (0U) |
| #define | TSC_INT_EN_MEASURE_INT_EN(x) (((uint32_t)(((uint32_t)(x)) << TSC_INT_EN_MEASURE_INT_EN_SHIFT)) & TSC_INT_EN_MEASURE_INT_EN_MASK) |
| #define | TSC_INT_EN_DETECT_INT_EN_MASK (0x10U) |
| #define | TSC_INT_EN_DETECT_INT_EN_SHIFT (4U) |
| #define | TSC_INT_EN_DETECT_INT_EN(x) (((uint32_t)(((uint32_t)(x)) << TSC_INT_EN_DETECT_INT_EN_SHIFT)) & TSC_INT_EN_DETECT_INT_EN_MASK) |
| #define | TSC_INT_EN_IDLE_SW_INT_EN_MASK (0x1000U) |
| #define | TSC_INT_EN_IDLE_SW_INT_EN_SHIFT (12U) |
| #define | TSC_INT_EN_IDLE_SW_INT_EN(x) (((uint32_t)(((uint32_t)(x)) << TSC_INT_EN_IDLE_SW_INT_EN_SHIFT)) & TSC_INT_EN_IDLE_SW_INT_EN_MASK) |
INT_SIG_EN - Interrupt Signal Enable | |
| #define | TSC_INT_SIG_EN_MEASURE_SIG_EN_MASK (0x1U) |
| #define | TSC_INT_SIG_EN_MEASURE_SIG_EN_SHIFT (0U) |
| #define | TSC_INT_SIG_EN_MEASURE_SIG_EN(x) (((uint32_t)(((uint32_t)(x)) << TSC_INT_SIG_EN_MEASURE_SIG_EN_SHIFT)) & TSC_INT_SIG_EN_MEASURE_SIG_EN_MASK) |
| #define | TSC_INT_SIG_EN_DETECT_SIG_EN_MASK (0x10U) |
| #define | TSC_INT_SIG_EN_DETECT_SIG_EN_SHIFT (4U) |
| #define | TSC_INT_SIG_EN_DETECT_SIG_EN(x) (((uint32_t)(((uint32_t)(x)) << TSC_INT_SIG_EN_DETECT_SIG_EN_SHIFT)) & TSC_INT_SIG_EN_DETECT_SIG_EN_MASK) |
| #define | TSC_INT_SIG_EN_VALID_SIG_EN_MASK (0x100U) |
| #define | TSC_INT_SIG_EN_VALID_SIG_EN_SHIFT (8U) |
| #define | TSC_INT_SIG_EN_VALID_SIG_EN(x) (((uint32_t)(((uint32_t)(x)) << TSC_INT_SIG_EN_VALID_SIG_EN_SHIFT)) & TSC_INT_SIG_EN_VALID_SIG_EN_MASK) |
| #define | TSC_INT_SIG_EN_IDLE_SW_SIG_EN_MASK (0x1000U) |
| #define | TSC_INT_SIG_EN_IDLE_SW_SIG_EN_SHIFT (12U) |
| #define | TSC_INT_SIG_EN_IDLE_SW_SIG_EN(x) (((uint32_t)(((uint32_t)(x)) << TSC_INT_SIG_EN_IDLE_SW_SIG_EN_SHIFT)) & TSC_INT_SIG_EN_IDLE_SW_SIG_EN_MASK) |
INT_STATUS - Intterrupt Status | |
| #define | TSC_INT_STATUS_MEASURE_MASK (0x1U) |
| #define | TSC_INT_STATUS_MEASURE_SHIFT (0U) |
| #define | TSC_INT_STATUS_MEASURE(x) (((uint32_t)(((uint32_t)(x)) << TSC_INT_STATUS_MEASURE_SHIFT)) & TSC_INT_STATUS_MEASURE_MASK) |
| #define | TSC_INT_STATUS_DETECT_MASK (0x10U) |
| #define | TSC_INT_STATUS_DETECT_SHIFT (4U) |
| #define | TSC_INT_STATUS_DETECT(x) (((uint32_t)(((uint32_t)(x)) << TSC_INT_STATUS_DETECT_SHIFT)) & TSC_INT_STATUS_DETECT_MASK) |
| #define | TSC_INT_STATUS_VALID_MASK (0x100U) |
| #define | TSC_INT_STATUS_VALID_SHIFT (8U) |
| #define | TSC_INT_STATUS_VALID(x) (((uint32_t)(((uint32_t)(x)) << TSC_INT_STATUS_VALID_SHIFT)) & TSC_INT_STATUS_VALID_MASK) |
| #define | TSC_INT_STATUS_IDLE_SW_MASK (0x1000U) |
| #define | TSC_INT_STATUS_IDLE_SW_SHIFT (12U) |
| #define | TSC_INT_STATUS_IDLE_SW(x) (((uint32_t)(((uint32_t)(x)) << TSC_INT_STATUS_IDLE_SW_SHIFT)) & TSC_INT_STATUS_IDLE_SW_MASK) |
DEBUG_MODE - Debug Mode Register | |
| #define | TSC_DEBUG_MODE_ADC_CONV_VALUE_MASK (0xFFFU) |
| #define | TSC_DEBUG_MODE_ADC_CONV_VALUE_SHIFT (0U) |
| #define | TSC_DEBUG_MODE_ADC_CONV_VALUE(x) (((uint32_t)(((uint32_t)(x)) << TSC_DEBUG_MODE_ADC_CONV_VALUE_SHIFT)) & TSC_DEBUG_MODE_ADC_CONV_VALUE_MASK) |
| #define | TSC_DEBUG_MODE_ADC_COCO_MASK (0x1000U) |
| #define | TSC_DEBUG_MODE_ADC_COCO_SHIFT (12U) |
| #define | TSC_DEBUG_MODE_ADC_COCO(x) (((uint32_t)(((uint32_t)(x)) << TSC_DEBUG_MODE_ADC_COCO_SHIFT)) & TSC_DEBUG_MODE_ADC_COCO_MASK) |
| #define | TSC_DEBUG_MODE_EXT_HWTS_MASK (0x1F0000U) |
| #define | TSC_DEBUG_MODE_EXT_HWTS_SHIFT (16U) |
| #define | TSC_DEBUG_MODE_EXT_HWTS(x) (((uint32_t)(((uint32_t)(x)) << TSC_DEBUG_MODE_EXT_HWTS_SHIFT)) & TSC_DEBUG_MODE_EXT_HWTS_MASK) |
| #define | TSC_DEBUG_MODE_TRIGGER_MASK (0x1000000U) |
| #define | TSC_DEBUG_MODE_TRIGGER_SHIFT (24U) |
| #define | TSC_DEBUG_MODE_TRIGGER(x) (((uint32_t)(((uint32_t)(x)) << TSC_DEBUG_MODE_TRIGGER_SHIFT)) & TSC_DEBUG_MODE_TRIGGER_MASK) |
| #define | TSC_DEBUG_MODE_ADC_COCO_CLEAR_MASK (0x2000000U) |
| #define | TSC_DEBUG_MODE_ADC_COCO_CLEAR_SHIFT (25U) |
| #define | TSC_DEBUG_MODE_ADC_COCO_CLEAR(x) (((uint32_t)(((uint32_t)(x)) << TSC_DEBUG_MODE_ADC_COCO_CLEAR_SHIFT)) & TSC_DEBUG_MODE_ADC_COCO_CLEAR_MASK) |
| #define | TSC_DEBUG_MODE_ADC_COCO_CLEAR_DISABLE_MASK (0x4000000U) |
| #define | TSC_DEBUG_MODE_ADC_COCO_CLEAR_DISABLE_SHIFT (26U) |
| #define | TSC_DEBUG_MODE_ADC_COCO_CLEAR_DISABLE(x) (((uint32_t)(((uint32_t)(x)) << TSC_DEBUG_MODE_ADC_COCO_CLEAR_DISABLE_SHIFT)) & TSC_DEBUG_MODE_ADC_COCO_CLEAR_DISABLE_MASK) |
| #define | TSC_DEBUG_MODE_DEBUG_EN_MASK (0x10000000U) |
| #define | TSC_DEBUG_MODE_DEBUG_EN_SHIFT (28U) |
| #define | TSC_DEBUG_MODE_DEBUG_EN(x) (((uint32_t)(((uint32_t)(x)) << TSC_DEBUG_MODE_DEBUG_EN_SHIFT)) & TSC_DEBUG_MODE_DEBUG_EN_MASK) |
DEBUG_MODE2 - Debug Mode Register 2 | |
| #define | TSC_DEBUG_MODE2_XPUL_PULL_DOWN_MASK (0x1U) |
| #define | TSC_DEBUG_MODE2_XPUL_PULL_DOWN_SHIFT (0U) |
| #define | TSC_DEBUG_MODE2_XPUL_PULL_DOWN(x) (((uint32_t)(((uint32_t)(x)) << TSC_DEBUG_MODE2_XPUL_PULL_DOWN_SHIFT)) & TSC_DEBUG_MODE2_XPUL_PULL_DOWN_MASK) |
| #define | TSC_DEBUG_MODE2_XPUL_PULL_UP_MASK (0x2U) |
| #define | TSC_DEBUG_MODE2_XPUL_PULL_UP_SHIFT (1U) |
| #define | TSC_DEBUG_MODE2_XPUL_PULL_UP(x) (((uint32_t)(((uint32_t)(x)) << TSC_DEBUG_MODE2_XPUL_PULL_UP_SHIFT)) & TSC_DEBUG_MODE2_XPUL_PULL_UP_MASK) |
| #define | TSC_DEBUG_MODE2_XPUL_200K_PULL_UP_MASK (0x4U) |
| #define | TSC_DEBUG_MODE2_XPUL_200K_PULL_UP_SHIFT (2U) |
| #define | TSC_DEBUG_MODE2_XPUL_200K_PULL_UP(x) (((uint32_t)(((uint32_t)(x)) << TSC_DEBUG_MODE2_XPUL_200K_PULL_UP_SHIFT)) & TSC_DEBUG_MODE2_XPUL_200K_PULL_UP_MASK) |
| #define | TSC_DEBUG_MODE2_XNUR_PULL_DOWN_MASK (0x8U) |
| #define | TSC_DEBUG_MODE2_XNUR_PULL_DOWN_SHIFT (3U) |
| #define | TSC_DEBUG_MODE2_XNUR_PULL_DOWN(x) (((uint32_t)(((uint32_t)(x)) << TSC_DEBUG_MODE2_XNUR_PULL_DOWN_SHIFT)) & TSC_DEBUG_MODE2_XNUR_PULL_DOWN_MASK) |
| #define | TSC_DEBUG_MODE2_XNUR_PULL_UP_MASK (0x10U) |
| #define | TSC_DEBUG_MODE2_XNUR_PULL_UP_SHIFT (4U) |
| #define | TSC_DEBUG_MODE2_XNUR_PULL_UP(x) (((uint32_t)(((uint32_t)(x)) << TSC_DEBUG_MODE2_XNUR_PULL_UP_SHIFT)) & TSC_DEBUG_MODE2_XNUR_PULL_UP_MASK) |
| #define | TSC_DEBUG_MODE2_XNUR_200K_PULL_UP_MASK (0x20U) |
| #define | TSC_DEBUG_MODE2_XNUR_200K_PULL_UP_SHIFT (5U) |
| #define | TSC_DEBUG_MODE2_XNUR_200K_PULL_UP(x) (((uint32_t)(((uint32_t)(x)) << TSC_DEBUG_MODE2_XNUR_200K_PULL_UP_SHIFT)) & TSC_DEBUG_MODE2_XNUR_200K_PULL_UP_MASK) |
| #define | TSC_DEBUG_MODE2_YPLL_PULL_DOWN_MASK (0x40U) |
| #define | TSC_DEBUG_MODE2_YPLL_PULL_DOWN_SHIFT (6U) |
| #define | TSC_DEBUG_MODE2_YPLL_PULL_DOWN(x) (((uint32_t)(((uint32_t)(x)) << TSC_DEBUG_MODE2_YPLL_PULL_DOWN_SHIFT)) & TSC_DEBUG_MODE2_YPLL_PULL_DOWN_MASK) |
| #define | TSC_DEBUG_MODE2_YPLL_PULL_UP_MASK (0x80U) |
| #define | TSC_DEBUG_MODE2_YPLL_PULL_UP_SHIFT (7U) |
| #define | TSC_DEBUG_MODE2_YPLL_PULL_UP(x) (((uint32_t)(((uint32_t)(x)) << TSC_DEBUG_MODE2_YPLL_PULL_UP_SHIFT)) & TSC_DEBUG_MODE2_YPLL_PULL_UP_MASK) |
| #define | TSC_DEBUG_MODE2_YPLL_200K_PULL_UP_MASK (0x100U) |
| #define | TSC_DEBUG_MODE2_YPLL_200K_PULL_UP_SHIFT (8U) |
| #define | TSC_DEBUG_MODE2_YPLL_200K_PULL_UP(x) (((uint32_t)(((uint32_t)(x)) << TSC_DEBUG_MODE2_YPLL_200K_PULL_UP_SHIFT)) & TSC_DEBUG_MODE2_YPLL_200K_PULL_UP_MASK) |
| #define | TSC_DEBUG_MODE2_YNLR_PULL_DOWN_MASK (0x200U) |
| #define | TSC_DEBUG_MODE2_YNLR_PULL_DOWN_SHIFT (9U) |
| #define | TSC_DEBUG_MODE2_YNLR_PULL_DOWN(x) (((uint32_t)(((uint32_t)(x)) << TSC_DEBUG_MODE2_YNLR_PULL_DOWN_SHIFT)) & TSC_DEBUG_MODE2_YNLR_PULL_DOWN_MASK) |
| #define | TSC_DEBUG_MODE2_YNLR_PULL_UP_MASK (0x400U) |
| #define | TSC_DEBUG_MODE2_YNLR_PULL_UP_SHIFT (10U) |
| #define | TSC_DEBUG_MODE2_YNLR_PULL_UP(x) (((uint32_t)(((uint32_t)(x)) << TSC_DEBUG_MODE2_YNLR_PULL_UP_SHIFT)) & TSC_DEBUG_MODE2_YNLR_PULL_UP_MASK) |
| #define | TSC_DEBUG_MODE2_YNLR_200K_PULL_UP_MASK (0x800U) |
| #define | TSC_DEBUG_MODE2_YNLR_200K_PULL_UP_SHIFT (11U) |
| #define | TSC_DEBUG_MODE2_YNLR_200K_PULL_UP(x) (((uint32_t)(((uint32_t)(x)) << TSC_DEBUG_MODE2_YNLR_200K_PULL_UP_SHIFT)) & TSC_DEBUG_MODE2_YNLR_200K_PULL_UP_MASK) |
| #define | TSC_DEBUG_MODE2_WIPER_PULL_DOWN_MASK (0x1000U) |
| #define | TSC_DEBUG_MODE2_WIPER_PULL_DOWN_SHIFT (12U) |
| #define | TSC_DEBUG_MODE2_WIPER_PULL_DOWN(x) (((uint32_t)(((uint32_t)(x)) << TSC_DEBUG_MODE2_WIPER_PULL_DOWN_SHIFT)) & TSC_DEBUG_MODE2_WIPER_PULL_DOWN_MASK) |
| #define | TSC_DEBUG_MODE2_WIPER_PULL_UP_MASK (0x2000U) |
| #define | TSC_DEBUG_MODE2_WIPER_PULL_UP_SHIFT (13U) |
| #define | TSC_DEBUG_MODE2_WIPER_PULL_UP(x) (((uint32_t)(((uint32_t)(x)) << TSC_DEBUG_MODE2_WIPER_PULL_UP_SHIFT)) & TSC_DEBUG_MODE2_WIPER_PULL_UP_MASK) |
| #define | TSC_DEBUG_MODE2_WIPER_200K_PULL_UP_MASK (0x4000U) |
| #define | TSC_DEBUG_MODE2_WIPER_200K_PULL_UP_SHIFT (14U) |
| #define | TSC_DEBUG_MODE2_WIPER_200K_PULL_UP(x) (((uint32_t)(((uint32_t)(x)) << TSC_DEBUG_MODE2_WIPER_200K_PULL_UP_SHIFT)) & TSC_DEBUG_MODE2_WIPER_200K_PULL_UP_MASK) |
| #define | TSC_DEBUG_MODE2_DETECT_FOUR_WIRE_MASK (0x10000U) |
| #define | TSC_DEBUG_MODE2_DETECT_FOUR_WIRE_SHIFT (16U) |
| #define | TSC_DEBUG_MODE2_DETECT_FOUR_WIRE(x) (((uint32_t)(((uint32_t)(x)) << TSC_DEBUG_MODE2_DETECT_FOUR_WIRE_SHIFT)) & TSC_DEBUG_MODE2_DETECT_FOUR_WIRE_MASK) |
| #define | TSC_DEBUG_MODE2_DETECT_FIVE_WIRE_MASK (0x20000U) |
| #define | TSC_DEBUG_MODE2_DETECT_FIVE_WIRE_SHIFT (17U) |
| #define | TSC_DEBUG_MODE2_DETECT_FIVE_WIRE(x) (((uint32_t)(((uint32_t)(x)) << TSC_DEBUG_MODE2_DETECT_FIVE_WIRE_SHIFT)) & TSC_DEBUG_MODE2_DETECT_FIVE_WIRE_MASK) |
| #define | TSC_DEBUG_MODE2_STATE_MACHINE_MASK (0x700000U) |
| #define | TSC_DEBUG_MODE2_STATE_MACHINE_SHIFT (20U) |
| #define | TSC_DEBUG_MODE2_STATE_MACHINE(x) (((uint32_t)(((uint32_t)(x)) << TSC_DEBUG_MODE2_STATE_MACHINE_SHIFT)) & TSC_DEBUG_MODE2_STATE_MACHINE_MASK) |
| #define | TSC_DEBUG_MODE2_INTERMEDIATE_MASK (0x800000U) |
| #define | TSC_DEBUG_MODE2_INTERMEDIATE_SHIFT (23U) |
| #define | TSC_DEBUG_MODE2_INTERMEDIATE(x) (((uint32_t)(((uint32_t)(x)) << TSC_DEBUG_MODE2_INTERMEDIATE_SHIFT)) & TSC_DEBUG_MODE2_INTERMEDIATE_MASK) |
| #define | TSC_DEBUG_MODE2_DETECT_ENABLE_FOUR_WIRE_MASK (0x1000000U) |
| #define | TSC_DEBUG_MODE2_DETECT_ENABLE_FOUR_WIRE_SHIFT (24U) |
| #define | TSC_DEBUG_MODE2_DETECT_ENABLE_FOUR_WIRE(x) (((uint32_t)(((uint32_t)(x)) << TSC_DEBUG_MODE2_DETECT_ENABLE_FOUR_WIRE_SHIFT)) & TSC_DEBUG_MODE2_DETECT_ENABLE_FOUR_WIRE_MASK) |
| #define | TSC_DEBUG_MODE2_DETECT_ENABLE_FIVE_WIRE_MASK (0x10000000U) |
| #define | TSC_DEBUG_MODE2_DETECT_ENABLE_FIVE_WIRE_SHIFT (28U) |
| #define | TSC_DEBUG_MODE2_DETECT_ENABLE_FIVE_WIRE(x) (((uint32_t)(((uint32_t)(x)) << TSC_DEBUG_MODE2_DETECT_ENABLE_FIVE_WIRE_SHIFT)) & TSC_DEBUG_MODE2_DETECT_ENABLE_FIVE_WIRE_MASK) |
| #define | TSC_DEBUG_MODE2_DE_GLITCH_MASK (0x60000000U) |
| #define | TSC_DEBUG_MODE2_DE_GLITCH_SHIFT (29U) |
| #define | TSC_DEBUG_MODE2_DE_GLITCH(x) (((uint32_t)(((uint32_t)(x)) << TSC_DEBUG_MODE2_DE_GLITCH_SHIFT)) & TSC_DEBUG_MODE2_DE_GLITCH_MASK) |
| #define TSC_BASIC_SETTING_AUTO_MEASURE | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << TSC_BASIC_SETTING_AUTO_MEASURE_SHIFT)) & TSC_BASIC_SETTING_AUTO_MEASURE_MASK) |
AUTO_MEASURE - Auto Measure 0b0..Disable Auto Measure 0b1..Auto Measure
| #define TSC_BASIC_SETTING_MEASURE_DELAY_TIME | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << TSC_BASIC_SETTING_MEASURE_DELAY_TIME_SHIFT)) & TSC_BASIC_SETTING_MEASURE_DELAY_TIME_MASK) |
MEASURE_DELAY_TIME - Measure Delay Time
| #define TSC_BASIC_SETTING_WIRE_4_5 | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << TSC_BASIC_SETTING_WIRE_4_5_SHIFT)) & TSC_BASIC_SETTING_WIRE_4_5_MASK) |
WIRE_4_5 - 4/5 Wire detection 0b0..4-Wire Detection Mode 0b1..5-Wire Detection Mode
| #define TSC_DEBUG_MODE2_DE_GLITCH | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << TSC_DEBUG_MODE2_DE_GLITCH_SHIFT)) & TSC_DEBUG_MODE2_DE_GLITCH_MASK) |
DE_GLITCH 0b00..Normal function: 0x1fff ipg clock cycles; Low power mode: 0x9 low power clock cycles 0b01..Normal function: 0xfff ipg clock cycles; Low power mode: :0x7 low power clock cycles 0b10..Normal function: 0x7ff ipg clock cycles; Low power mode:0x5 low power clock cycles 0b11..Normal function: 0x3 ipg clock cycles; Low power mode:0x3 low power clock cycles
| #define TSC_DEBUG_MODE2_DETECT_ENABLE_FIVE_WIRE | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << TSC_DEBUG_MODE2_DETECT_ENABLE_FIVE_WIRE_SHIFT)) & TSC_DEBUG_MODE2_DETECT_ENABLE_FIVE_WIRE_MASK) |
DETECT_ENABLE_FIVE_WIRE - Detect Enable Five Wire 0b0..Do not read five wire detect value, read default value from analogue 0b1..Read five wire detect status from analogue
| #define TSC_DEBUG_MODE2_DETECT_ENABLE_FOUR_WIRE | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << TSC_DEBUG_MODE2_DETECT_ENABLE_FOUR_WIRE_SHIFT)) & TSC_DEBUG_MODE2_DETECT_ENABLE_FOUR_WIRE_MASK) |
DETECT_ENABLE_FOUR_WIRE - Detect Enable Four Wire 0b0..Do not read four wire detect value, read default value from analogue 0b1..Read four wire detect status from analogue
| #define TSC_DEBUG_MODE2_DETECT_FIVE_WIRE | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << TSC_DEBUG_MODE2_DETECT_FIVE_WIRE_SHIFT)) & TSC_DEBUG_MODE2_DETECT_FIVE_WIRE_MASK) |
DETECT_FIVE_WIRE - Detect Five Wire 0b0..No detect signal 0b1..Yes, there is a detect on the touch screen.
| #define TSC_DEBUG_MODE2_DETECT_FOUR_WIRE | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << TSC_DEBUG_MODE2_DETECT_FOUR_WIRE_SHIFT)) & TSC_DEBUG_MODE2_DETECT_FOUR_WIRE_MASK) |
DETECT_FOUR_WIRE - Detect Four Wire 0b0..No detect signal 0b1..Yes, there is a detect on the touch screen.
| #define TSC_DEBUG_MODE2_INTERMEDIATE | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << TSC_DEBUG_MODE2_INTERMEDIATE_SHIFT)) & TSC_DEBUG_MODE2_INTERMEDIATE_MASK) |
INTERMEDIATE - Intermediate State 0b0..Not in intermedia 0b1..Intermedia
| #define TSC_DEBUG_MODE2_STATE_MACHINE | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << TSC_DEBUG_MODE2_STATE_MACHINE_SHIFT)) & TSC_DEBUG_MODE2_STATE_MACHINE_MASK) |
STATE_MACHINE - State Machine 0b000..Idle 0b001..Pre-charge 0b010..Detect 0b011..X-measure 0b100..Y-measure 0b101..Pre-charge 0b110..Detect
| #define TSC_DEBUG_MODE2_WIPER_200K_PULL_UP | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << TSC_DEBUG_MODE2_WIPER_200K_PULL_UP_SHIFT)) & TSC_DEBUG_MODE2_WIPER_200K_PULL_UP_MASK) |
WIPER_200K_PULL_UP - Wiper Wire 200K Pull Up Switch 0b0..Close the switch 0b1..Open up the switch
| #define TSC_DEBUG_MODE2_WIPER_PULL_DOWN | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << TSC_DEBUG_MODE2_WIPER_PULL_DOWN_SHIFT)) & TSC_DEBUG_MODE2_WIPER_PULL_DOWN_MASK) |
WIPER_PULL_DOWN - Wiper Wire Pull Down Switch 0b0..Close the switch 0b1..Open up the switch
| #define TSC_DEBUG_MODE2_WIPER_PULL_UP | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << TSC_DEBUG_MODE2_WIPER_PULL_UP_SHIFT)) & TSC_DEBUG_MODE2_WIPER_PULL_UP_MASK) |
WIPER_PULL_UP - Wiper Wire Pull Up Switch 0b0..Close the switch 0b1..Open up the switch
| #define TSC_DEBUG_MODE2_XNUR_200K_PULL_UP | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << TSC_DEBUG_MODE2_XNUR_200K_PULL_UP_SHIFT)) & TSC_DEBUG_MODE2_XNUR_200K_PULL_UP_MASK) |
XNUR_200K_PULL_UP - XNUR Wire 200K Pull Up Switch 0b0..Close the switch 0b1..Open up the switch
| #define TSC_DEBUG_MODE2_XNUR_PULL_DOWN | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << TSC_DEBUG_MODE2_XNUR_PULL_DOWN_SHIFT)) & TSC_DEBUG_MODE2_XNUR_PULL_DOWN_MASK) |
XNUR_PULL_DOWN - XNUR Wire Pull Down Switch 0b0..Close the switch 0b1..Open up the switch
| #define TSC_DEBUG_MODE2_XNUR_PULL_UP | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << TSC_DEBUG_MODE2_XNUR_PULL_UP_SHIFT)) & TSC_DEBUG_MODE2_XNUR_PULL_UP_MASK) |
XNUR_PULL_UP - XNUR Wire Pull Up Switch 0b0..Close the switch 0b1..Open up the switch
| #define TSC_DEBUG_MODE2_XPUL_200K_PULL_UP | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << TSC_DEBUG_MODE2_XPUL_200K_PULL_UP_SHIFT)) & TSC_DEBUG_MODE2_XPUL_200K_PULL_UP_MASK) |
XPUL_200K_PULL_UP - XPUL Wire 200K Pull Up Switch 0b0..Close the switch 0b1..Open up the switch
| #define TSC_DEBUG_MODE2_XPUL_PULL_DOWN | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << TSC_DEBUG_MODE2_XPUL_PULL_DOWN_SHIFT)) & TSC_DEBUG_MODE2_XPUL_PULL_DOWN_MASK) |
XPUL_PULL_DOWN - XPUL Wire Pull Down Switch 0b0..Close the switch 0b1..Open up the switch
| #define TSC_DEBUG_MODE2_XPUL_PULL_UP | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << TSC_DEBUG_MODE2_XPUL_PULL_UP_SHIFT)) & TSC_DEBUG_MODE2_XPUL_PULL_UP_MASK) |
XPUL_PULL_UP - XPUL Wire Pull Up Switch 0b0..Close the switch 0b1..Open up the switch
| #define TSC_DEBUG_MODE2_YNLR_200K_PULL_UP | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << TSC_DEBUG_MODE2_YNLR_200K_PULL_UP_SHIFT)) & TSC_DEBUG_MODE2_YNLR_200K_PULL_UP_MASK) |
YNLR_200K_PULL_UP - YNLR Wire 200K Pull Up Switch 0b0..Close the switch 0b1..Open up the switch
| #define TSC_DEBUG_MODE2_YNLR_PULL_DOWN | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << TSC_DEBUG_MODE2_YNLR_PULL_DOWN_SHIFT)) & TSC_DEBUG_MODE2_YNLR_PULL_DOWN_MASK) |
YNLR_PULL_DOWN - YNLR Wire Pull Down Switch 0b0..Close the switch 0b1..Open up the switch
| #define TSC_DEBUG_MODE2_YNLR_PULL_UP | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << TSC_DEBUG_MODE2_YNLR_PULL_UP_SHIFT)) & TSC_DEBUG_MODE2_YNLR_PULL_UP_MASK) |
YNLR_PULL_UP - YNLR Wire Pull Up Switch 0b0..Close the switch 0b1..Open up the switch
| #define TSC_DEBUG_MODE2_YPLL_200K_PULL_UP | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << TSC_DEBUG_MODE2_YPLL_200K_PULL_UP_SHIFT)) & TSC_DEBUG_MODE2_YPLL_200K_PULL_UP_MASK) |
YPLL_200K_PULL_UP - YPLL Wire 200K Pull Up Switch 0b0..Close the switch 0b1..Open up the switch
| #define TSC_DEBUG_MODE2_YPLL_PULL_DOWN | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << TSC_DEBUG_MODE2_YPLL_PULL_DOWN_SHIFT)) & TSC_DEBUG_MODE2_YPLL_PULL_DOWN_MASK) |
YPLL_PULL_DOWN - YPLL Wire Pull Down Switch 0b0..Close the switch 0b1..Open up the switch
| #define TSC_DEBUG_MODE2_YPLL_PULL_UP | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << TSC_DEBUG_MODE2_YPLL_PULL_UP_SHIFT)) & TSC_DEBUG_MODE2_YPLL_PULL_UP_MASK) |
YPLL_PULL_UP - YPLL Wire Pull Up Switch 0b0..Close the switch 0b1..Open the switch
| #define TSC_DEBUG_MODE_ADC_COCO | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << TSC_DEBUG_MODE_ADC_COCO_SHIFT)) & TSC_DEBUG_MODE_ADC_COCO_MASK) |
ADC_COCO - ADC COCO Signal
| #define TSC_DEBUG_MODE_ADC_COCO_CLEAR | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << TSC_DEBUG_MODE_ADC_COCO_CLEAR_SHIFT)) & TSC_DEBUG_MODE_ADC_COCO_CLEAR_MASK) |
ADC_COCO_CLEAR - ADC Coco Clear 0b0..No ADC COCO clear 0b1..Set ADC COCO clear
| #define TSC_DEBUG_MODE_ADC_COCO_CLEAR_DISABLE | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << TSC_DEBUG_MODE_ADC_COCO_CLEAR_DISABLE_SHIFT)) & TSC_DEBUG_MODE_ADC_COCO_CLEAR_DISABLE_MASK) |
ADC_COCO_CLEAR_DISABLE - ADC COCO Clear Disable 0b0..Allow TSC hardware generates ADC COCO clear 0b1..Prevent TSC from generate ADC COCO clear signal
| #define TSC_DEBUG_MODE_ADC_CONV_VALUE | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << TSC_DEBUG_MODE_ADC_CONV_VALUE_SHIFT)) & TSC_DEBUG_MODE_ADC_CONV_VALUE_MASK) |
ADC_CONV_VALUE - ADC Conversion Value
| #define TSC_DEBUG_MODE_DEBUG_EN | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << TSC_DEBUG_MODE_DEBUG_EN_SHIFT)) & TSC_DEBUG_MODE_DEBUG_EN_MASK) |
DEBUG_EN - Debug Enable 0b0..Enable debug mode 0b1..Disable debug mode
| #define TSC_DEBUG_MODE_EXT_HWTS | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << TSC_DEBUG_MODE_EXT_HWTS_SHIFT)) & TSC_DEBUG_MODE_EXT_HWTS_MASK) |
EXT_HWTS - Hardware Trigger Select Signal
| #define TSC_DEBUG_MODE_TRIGGER | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << TSC_DEBUG_MODE_TRIGGER_SHIFT)) & TSC_DEBUG_MODE_TRIGGER_MASK) |
TRIGGER - Trigger 0b0..No hardware trigger signal 0b1..Hardware trigger signal, the signal must last at least 1 ips clock period
| #define TSC_FLOW_CONTROL_DISABLE | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << TSC_FLOW_CONTROL_DISABLE_SHIFT)) & TSC_FLOW_CONTROL_DISABLE_MASK) |
DISABLE 0b0..Leave HW state machine control 0b1..SW set to idle status
| #define TSC_FLOW_CONTROL_DROP_MEASURE | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << TSC_FLOW_CONTROL_DROP_MEASURE_SHIFT)) & TSC_FLOW_CONTROL_DROP_MEASURE_MASK) |
DROP_MEASURE - Drop Measure 0b0..Do not drop measure for now 0b1..Drop the measure and controller return to idle status
| #define TSC_FLOW_CONTROL_START_MEASURE | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << TSC_FLOW_CONTROL_START_MEASURE_SHIFT)) & TSC_FLOW_CONTROL_START_MEASURE_MASK) |
START_MEASURE - Start Measure 0b0..Do not start measure for now 0b1..Start measure the X/Y coordinate value
| #define TSC_FLOW_CONTROL_START_SENSE | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << TSC_FLOW_CONTROL_START_SENSE_SHIFT)) & TSC_FLOW_CONTROL_START_SENSE_MASK) |
START_SENSE - Start Sense 0b0..Stay at idle status 0b1..Start sense detection and (if auto_measure set to 1) measure after detect a touch
| #define TSC_FLOW_CONTROL_SW_RST | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << TSC_FLOW_CONTROL_SW_RST_SHIFT)) & TSC_FLOW_CONTROL_SW_RST_MASK) |
SW_RST - Soft Reset
| #define TSC_INT_EN_DETECT_INT_EN | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << TSC_INT_EN_DETECT_INT_EN_SHIFT)) & TSC_INT_EN_DETECT_INT_EN_MASK) |
DETECT_INT_EN - Detect Interrupt Enable 0b0..Disable detect interrupt 0b1..Enable detect interrupt
| #define TSC_INT_EN_IDLE_SW_INT_EN | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << TSC_INT_EN_IDLE_SW_INT_EN_SHIFT)) & TSC_INT_EN_IDLE_SW_INT_EN_MASK) |
IDLE_SW_INT_EN - Idle Software Interrupt Enable 0b0..Disable idle software interrupt 0b1..Enable idle software interrupt
| #define TSC_INT_EN_MEASURE_INT_EN | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << TSC_INT_EN_MEASURE_INT_EN_SHIFT)) & TSC_INT_EN_MEASURE_INT_EN_MASK) |
MEASURE_INT_EN - Measure Interrupt Enable 0b0..Disable measure interrupt 0b1..Enable measure interrupt
| #define TSC_INT_SIG_EN_DETECT_SIG_EN | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << TSC_INT_SIG_EN_DETECT_SIG_EN_SHIFT)) & TSC_INT_SIG_EN_DETECT_SIG_EN_MASK) |
DETECT_SIG_EN - Detect Signal Enable 0b0..Disable detect signal 0b1..Enable detect signal
| #define TSC_INT_SIG_EN_IDLE_SW_SIG_EN | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << TSC_INT_SIG_EN_IDLE_SW_SIG_EN_SHIFT)) & TSC_INT_SIG_EN_IDLE_SW_SIG_EN_MASK) |
IDLE_SW_SIG_EN - Idle Software Signal Enable 0b0..Disable idle software signal 0b1..Enable idle software signal
| #define TSC_INT_SIG_EN_MEASURE_SIG_EN | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << TSC_INT_SIG_EN_MEASURE_SIG_EN_SHIFT)) & TSC_INT_SIG_EN_MEASURE_SIG_EN_MASK) |
MEASURE_SIG_EN - Measure Signal Enable
| #define TSC_INT_SIG_EN_VALID_SIG_EN | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << TSC_INT_SIG_EN_VALID_SIG_EN_SHIFT)) & TSC_INT_SIG_EN_VALID_SIG_EN_MASK) |
VALID_SIG_EN - Valid Signal Enable 0b0..Disable valid signal 0b1..Enable valid signal
| #define TSC_INT_STATUS_DETECT | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << TSC_INT_STATUS_DETECT_SHIFT)) & TSC_INT_STATUS_DETECT_MASK) |
DETECT - Detect Signal 0b0..Does not exist a detect signal 0b1..Exist detect signal
| #define TSC_INT_STATUS_IDLE_SW | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << TSC_INT_STATUS_IDLE_SW_SHIFT)) & TSC_INT_STATUS_IDLE_SW_MASK) |
IDLE_SW - Idle Software 0b0..Haven't return to idle status 0b1..Already return to idle status
| #define TSC_INT_STATUS_MEASURE | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << TSC_INT_STATUS_MEASURE_SHIFT)) & TSC_INT_STATUS_MEASURE_MASK) |
MEASURE - Measure Signal 0b0..Does not exist a measure signal 0b1..Exist a measure signal
| #define TSC_INT_STATUS_VALID | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << TSC_INT_STATUS_VALID_SHIFT)) & TSC_INT_STATUS_VALID_MASK) |
VALID - Valid Signal 0b0..There is no touch detected after measurement, indicates that the measured value is not valid 0b1..There is touch detection after measurement, indicates that the measure is valid
| #define TSC_MEASEURE_VALUE_X_VALUE | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << TSC_MEASEURE_VALUE_X_VALUE_SHIFT)) & TSC_MEASEURE_VALUE_X_VALUE_MASK) |
X_VALUE - X Value
| #define TSC_MEASEURE_VALUE_Y_VALUE | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << TSC_MEASEURE_VALUE_Y_VALUE_SHIFT)) & TSC_MEASEURE_VALUE_Y_VALUE_MASK) |
Y_VALUE - Y Value
