RTEMS 6.3-rc1
PowerPC Utility Module
PowerPC Utility Module. More...
#define LINKER_SYMBOL(sym)   extern char sym [];
#define CPU_Get_timebase_low(_value)    __asm__ volatile( "mfspr %0,268" : "=r" (_value) )
#define rtems_bsp_delay(_microseconds)
#define rtems_bsp_delay_in_bus_cycles(_cycles)
#define PPC_Set_decrementer(_clicks)
#define PPC_Get_decrementer(_clicks)    __asm__ volatile( "mfdec %0" : "=r" (_clicks) )
#define PPC_STRINGOF(x)   #x
 Preprocessor magic for stringification of x.
#define PPC_SPECIAL_PURPOSE_REGISTER(spr, val)
 Returns the value of the Special Purpose Register with number spr.
#define PPC_SET_SPECIAL_PURPOSE_REGISTER(spr, val)
 Sets the Special Purpose Register with number spr to the value in val.
#define PPC_SET_SPECIAL_PURPOSE_REGISTER_BITS(spr, bits)
 Sets in the Special Purpose Register with number spr all bits which are set in bits.
#define PPC_SET_SPECIAL_PURPOSE_REGISTER_BITS_MASKED(spr, bits, mask)
 Sets in the Special Purpose Register with number spr all bits which are set in bits. The previous register value will be masked with mask.
#define PPC_CLEAR_SPECIAL_PURPOSE_REGISTER_BITS(spr, bits)
 Clears in the Special Purpose Register with number spr all bits which are set in bits.
#define PPC_THREAD_MGMT_REGISTER(tmr)
 Returns the value of the Thread Management Register with number tmr.
#define PPC_SET_THREAD_MGMT_REGISTER(tmr, val)
 Sets the Thread Management Register with number tmr to the value in val.
#define PPC_DEVICE_CONTROL_REGISTER(dcr)
 Returns the value of the Device Control Register with number dcr.
#define PPC_SET_DEVICE_CONTROL_REGISTER(dcr, val)
 Sets the Device Control Register with number dcr to the value in val.
#define PPC_SET_DEVICE_CONTROL_REGISTER_BITS(dcr, bits)
 Sets in the Device Control Register with number dcr all bits which are set in bits.
#define PPC_SET_DEVICE_CONTROL_REGISTER_BITS_MASKED(dcr, bits, mask)
 Sets in the Device Control Register with number dcr all bits which are set in bits. The previous register value will be masked with mask.
#define PPC_CLEAR_DEVICE_CONTROL_REGISTER_BITS(dcr, bits)
 Clears in the Device Control Register with number dcr all bits which are set in bits.
#define ppc_mtivor(x, vec)
void ppc_code_copy (void *dest, const void *src, size_t n)
void printBAT (int bat, uint32_t upper, uint32_t lower)
void ShowBATS (void)
uint32_t bsp_clicks_per_usec
◆ PPC_CLEAR_DEVICE_CONTROL_REGISTER_BITS
#define PPC_CLEAR_DEVICE_CONTROL_REGISTER_BITS (   dcr,
  bits
Value:
do { \
ISR_Level level; \
uint32_t val; \
uint32_t mybits = bits; \
_ISR_Local_disable(level); \
val &= ~mybits; \
PPC_SET_DEVICE_CONTROL_REGISTER(dcr, val); \
_ISR_Local_enable(level); \
} while (0)
Definition: powerpc-utility.h:691
uint32_t ISR_Level
Definition: isrlevel.h:60
Interrupts are disabled throughout this operation.
◆ PPC_CLEAR_SPECIAL_PURPOSE_REGISTER_BITS
#define PPC_CLEAR_SPECIAL_PURPOSE_REGISTER_BITS (   spr,
  bits
Value:
do { \
ISR_Level level; \
uint32_t val; \
PPC_SPECIAL_PURPOSE_REGISTER(spr, val); \
val &= ~mybits; \
PPC_SET_SPECIAL_PURPOSE_REGISTER(spr, val); \
} while (0)
◆ PPC_DEVICE_CONTROL_REGISTER
#define PPC_DEVICE_CONTROL_REGISTER (   dcr)
Value:
uint32_t val; \
__asm__ volatile (\
"mfdcr %0, " PPC_STRINGOF(dcr) \
: "=r" (val) \
val;\
Definition: powerpc-utility.h:573
The PowerPC 4XX family has Device Control Registers.
Note
This macro uses a GNU C extension.
◆ ppc_mtivor
#define ppc_mtivor (   x,
  vec
Value:
__asm__ volatile ( \
"mtivor" RTEMS_XSTRING(x) " %0" \
: "r" (vec) \
#define RTEMS_XSTRING(...)
Stringifies the expansion of the arguments.
Definition: basedefs.h:987
◆ PPC_Set_decrementer
#define PPC_Set_decrementer (   _clicks)
Value:
do { \
__asm__ volatile( "mtdec %0" : : "r" ((_clicks)) ); \
} while (0)
◆ PPC_SET_DEVICE_CONTROL_REGISTER
#define PPC_SET_DEVICE_CONTROL_REGISTER (   dcr,
  val
Value:
do { \
__asm__ volatile (\
"mtdcr " PPC_STRINGOF(dcr) ", %0" \
: "r" (val) \
} while (0)
◆ PPC_SET_DEVICE_CONTROL_REGISTER_BITS
#define PPC_SET_DEVICE_CONTROL_REGISTER_BITS (   dcr,
  bits
Value:
do { \
ISR_Level level; \
uint32_t val; \
val |= mybits; \
} while (0)
◆ PPC_SET_DEVICE_CONTROL_REGISTER_BITS_MASKED
#define PPC_SET_DEVICE_CONTROL_REGISTER_BITS_MASKED (   dcr,
  bits,
  mask
Value:
do { \
ISR_Level level; \
uint32_t val; \
uint32_t mymask = mask; \
val &= ~mymask; \
val |= mybits; \
} while (0)
◆ PPC_SET_SPECIAL_PURPOSE_REGISTER
#define PPC_SET_SPECIAL_PURPOSE_REGISTER (   spr,
  val
Value:
do { \
__asm__ volatile (\
"mtspr " PPC_STRINGOF(spr) ", %0" \
: "r" (val) \
} while (0)
◆ PPC_SET_SPECIAL_PURPOSE_REGISTER_BITS
#define PPC_SET_SPECIAL_PURPOSE_REGISTER_BITS (   spr,
  bits
Value:
do { \
ISR_Level level; \
uint32_t val; \
val |= mybits; \
} while (0)
◆ PPC_SET_SPECIAL_PURPOSE_REGISTER_BITS_MASKED
#define PPC_SET_SPECIAL_PURPOSE_REGISTER_BITS_MASKED (   spr,
  bits,
  mask
Value:
do { \
ISR_Level level; \
uint32_t val; \
val &= ~mymask; \
val |= mybits; \
} while (0)
◆ PPC_SET_THREAD_MGMT_REGISTER
#define PPC_SET_THREAD_MGMT_REGISTER (   tmr,
  val
Value:
do { \
__asm__ volatile (\
"mttmr " PPC_STRINGOF(tmr) ", %0" \
: "r" (val) \
} while (0)
◆ PPC_SPECIAL_PURPOSE_REGISTER
#define PPC_SPECIAL_PURPOSE_REGISTER (   spr,
  val
Value:
__asm__ volatile (\
"mfspr %0, " PPC_STRINGOF(spr) \
: "=r" (val) \
Note
◆ PPC_THREAD_MGMT_REGISTER
#define PPC_THREAD_MGMT_REGISTER (   tmr)
Value:
uint32_t val; \
__asm__ volatile (\
"mftmr %0, " PPC_STRINGOF(tmr) \
: "=r" (val) \
val;\
Note
◆ rtems_bsp_delay
#define rtems_bsp_delay (   _microseconds)
Value:
do { \
uint32_t start, ticks, now; \
CPU_Get_timebase_low( start ) ; \
ticks = (_microseconds) * bsp_clicks_per_usec; \
do \
CPU_Get_timebase_low( now ) ; \
while (now - start < ticks); \
} while (0)
◆ rtems_bsp_delay_in_bus_cycles
#define rtems_bsp_delay_in_bus_cycles (   _cycles)
Value:
do { \
uint32_t start, now; \
CPU_Get_timebase_low( start ); \
do \
CPU_Get_timebase_low( now ); \
while (now - start < (_cycles)); \
} while (0)
