RTEMS 6.3-rc1
Classic API Initialization Task Configuration
#define CONFIGURE_INIT_TASK_ARGUMENTS
 This configuration option is an integer define.
#define CONFIGURE_INIT_TASK_ATTRIBUTES
#define CONFIGURE_INIT_TASK_CONSTRUCT_STORAGE_SIZE
#define CONFIGURE_INIT_TASK_ENTRY_POINT
 This configuration option is an initializer define.
#define CONFIGURE_INIT_TASK_INITIAL_MODES
#define CONFIGURE_INIT_TASK_NAME
#define CONFIGURE_INIT_TASK_PRIORITY
#define CONFIGURE_INIT_TASK_STACK_SIZE
#define CONFIGURE_RTEMS_INIT_TASKS_TABLE
 This configuration option is a boolean feature define.
This section describes configuration options related to the Classic API initialization task.
◆ CONFIGURE_INIT_TASK_ARGUMENTS
The value of this configuration option defines task argument of the Classic API initialization task.
Default Value
The default value is 0.
Constraints
The value of the configuration option shall be convertible to an integer of type rtems_task_argument.
◆ CONFIGURE_INIT_TASK_ATTRIBUTES
The value of this configuration option defines the task attributes of the Classic API initialization task.
Default Value
The default value is RTEMS_DEFAULT_ATTRIBUTES.
Constraints
The value of the configuration option shall be a valid task attribute set.
◆ CONFIGURE_INIT_TASK_CONSTRUCT_STORAGE_SIZE
The value of this configuration option defines the task storage size of the Classic API initialization task.
Default Value
This configuration option has no default value. If it is not specified, then the Classic API initialization task will be created with the stack size defined by the CONFIGURE_INIT_TASK_STACK_SIZE configuration option.
Constraints
The following constraints apply to this configuration option:
Notes
If this configuration option is specified, then
The
configuration options are mutually exclusive.
◆ CONFIGURE_INIT_TASK_ENTRY_POINT
The value of this configuration option initializes the entry point of the Classic API initialization task.
Default Value
The default value is Init.
Constraints
The value of the configuration option shall be defined to a valid function pointer of the type void ( *entry_point )( rtems_task_argument ).
Notes
The application shall provide the function referenced by this configuration option.
◆ CONFIGURE_INIT_TASK_INITIAL_MODES
The value of this configuration option defines the initial execution mode of the Classic API initialization task.
Default Value
In SMP configurations, the default value is RTEMS_DEFAULT_MODES otherwise the default value is RTEMS_NO_PREEMPT.
Constraints
The value of the configuration option shall be a valid task mode set.
◆ CONFIGURE_INIT_TASK_NAME
The value of this configuration option defines the name of the Classic API initialization task.
Default Value
The default value is ‘rtems_build_name( 'U’, 'I', '1', ' ' )`.
Constraints
The value of the configuration option shall be convertible to an integer of type rtems_name.
Notes
Use rtems_build_name() to define the task name.
◆ CONFIGURE_INIT_TASK_PRIORITY
The value of this configuration option defines the initial priority of the Classic API initialization task.
Default Value
The default value is 1.
Constraints
The value of the configuration option shall be a valid Classic API task priority. The set of valid task priorities depends on the scheduler configuration.
◆ CONFIGURE_INIT_TASK_STACK_SIZE
The value of this configuration option defines the task stack size of the Classic API initialization task.
Default Value
The default value is CONFIGURE_MINIMUM_TASK_STACK_SIZE.
Constraints
  • The value of the configuration option shall be greater than or equal to CONFIGURE_MINIMUM_TASK_STACK_SIZE.
  • The value of the configuration option shall be small enough so that the task stack space calculation carried out by <rtems/confdefs.h> does not overflow an integer of type uintptr_t.
Notes
The
◆ CONFIGURE_RTEMS_INIT_TASKS_TABLE
In case this configuration option is defined, then exactly one Classic API initialization task is configured.
Default Configuration
If this configuration option is undefined, then the described feature is not enabled.
Notes
The application shall define at least one of the following configuration options
otherwise a compile time error in the configuration file will occur.
The Classic API initialization task performs the Global Construction.
