RTEMS 6.3-rc1
This group contains the Classic API directive options. More...
| #define | RTEMS_DEFAULT_OPTIONS 0x00000000 |
| This option constant represents the default option set. | |
| #define | RTEMS_EVENT_ALL 0x00000000 |
| This option constant indicates that the task wishes to wait until all events of interest are available in rtems_event_receive() and rtems_event_system_receive(). | |
| #define | RTEMS_EVENT_ANY 0x00000002 |
| This option constant indicates that the task wishes to wait until at least one of the events of interest is available in rtems_event_receive() and rtems_event_system_receive(). | |
| #define | RTEMS_NO_WAIT 0x00000001 |
| This option constant indicates that the task does not want to wait on the resource. | |
| #define | RTEMS_WAIT 0x00000000 |
| This option constant indicates that the task wants to wait on the resource. | |
Typedefs | |
| typedef uint32_t | rtems_option |
| This type represents a Classic API directive option set. | |
| #define RTEMS_NO_WAIT 0x00000001 |
If the resource is not available, then the directives shall return immediately with a status to indicate that the request is unsatisfied.
| #define RTEMS_WAIT 0x00000000 |
If the resource is not available, then the task shall block and wait for request completion.
