RTEMS 6.2-rc3
Extension of the generic libchip console driver shell. More...
| int | vt_ioctl (unsigned int cmd, unsigned long arg) |
| This function is the ioctl() support for a VGA buffer driver. | |
| console_tbl * | console_find_console_entry (const char *match, size_t length, rtems_device_minor_number *match_minor) |
| console_find_console_entry | |
| void | console_initialize_data (void) |
| console_initialize_data | |
| void | console_register_devices (console_tbl *new_ports, size_t number_of_ports) |
| console_register_devices | |
| rtems_device_minor_number | BSPPrintkPort |
| console_tbl * console_find_console_entry | ( | const char * | match, |
| size_t | length, | ||
| rtems_device_minor_number * | match_minor | ||
This method is used to search the console entries for a specific device entry and return it. If match is NULL the minor number provided is matched.
| void console_initialize_data | ( | void | ) |
This must be called before dynamic registration of devices can occur. It is normally called as a side-effect of console_initialize() but if a probe and dynamic registration occurs before that, then this method should be explicitly invoked.
| void console_register_devices | ( | console_tbl * | new_ports, |
| size_t | number_of_ports | ||
This function expands the console table to include previous ports and the array of new ports specified.
| [in] | new_ports | specifies an array of new ports to register |
| [in] | number_of_ports | specifies the number of elements in the new_ports array |
| int vt_ioctl | ( | unsigned int | cmd, |
| unsigned long | arg | ||
