RTEMS 6.2-rc3
PDM Driver
struct  _pdm_channel_config
 PDM channel configurations. More...
struct  _pdm_config
 PDM user configuration structure. More...
struct  _pdm_hwvad_config
 PDM voice activity detector user configuration structure. More...
struct  _pdm_hwvad_noise_filter
 PDM voice activity detector noise filter user configuration structure. More...
struct  _pdm_hwvad_zero_cross_detector
 PDM voice activity detector zero cross detector configuration structure. More...
struct  _pdm_transfer
 PDM SDMA transfer structure. More...
struct  _pdm_hwvad_notification
 PDM HWVAD notification structure. More...
struct  _pdm_handle
 PDM handle structure. More...
Driver version
enum  {
  kStatus_PDM_Busy = MAKE_STATUS(kStatusGroup_PDM, 0) , kStatus_PDM_FIFO_ERROR = MAKE_STATUS(kStatusGroup_PDM, 2) , kStatus_PDM_QueueFull = MAKE_STATUS(kStatusGroup_PDM, 3) , kStatus_PDM_Idle = MAKE_STATUS(kStatusGroup_PDM, 4) ,
  kStatus_PDM_Output_ERROR = MAKE_STATUS(kStatusGroup_PDM, 5) , kStatus_PDM_ChannelConfig_Failed = MAKE_STATUS(kStatusGroup_PDM, 6) , kStatus_PDM_HWVAD_VoiceDetected = MAKE_STATUS(kStatusGroup_PDM, 7) , kStatus_PDM_HWVAD_Error = MAKE_STATUS(kStatusGroup_PDM, 8)
 PDM return status. More...
enum  _pdm_interrupt_enable { kPDM_ErrorInterruptEnable = PDM_CTRL_1_ERREN_MASK , kPDM_FIFOInterruptEnable = PDM_CTRL_1_DISEL(2U) }
 The PDM interrupt enable flag. More...
enum  _pdm_internal_status {
  kPDM_StatusDfBusyFlag = (int)PDM_STAT_BSY_FIL_MASK , kPDM_StatusFIRFilterReady = PDM_STAT_FIR_RDY_MASK , kPDM_StatusCh0FifoDataAvaliable = PDM_STAT_CH0F_MASK , kPDM_StatusCh1FifoDataAvaliable = PDM_STAT_CH1F_MASK ,
  kPDM_StatusCh2FifoDataAvaliable = PDM_STAT_CH2F_MASK , kPDM_StatusCh3FifoDataAvaliable = PDM_STAT_CH3F_MASK , kPDM_StatusCh4FifoDataAvaliable = PDM_STAT_CH4F_MASK , kPDM_StatusCh5FifoDataAvaliable = PDM_STAT_CH5F_MASK ,
  kPDM_StatusCh6FifoDataAvaliable = PDM_STAT_CH6F_MASK , kPDM_StatusCh7FifoDataAvaliable = PDM_STAT_CH7F_MASK
 The PDM status. More...
enum  _pdm_channel_enable_mask {
  kPDM_EnableChannel0 = PDM_STAT_CH0F_MASK , kPDM_EnableChannel1 = PDM_STAT_CH1F_MASK , kPDM_EnableChannel2 = PDM_STAT_CH2F_MASK , kPDM_EnableChannel3 = PDM_STAT_CH3F_MASK ,
  kPDM_EnableChannel4 = PDM_STAT_CH4F_MASK , kPDM_EnableChannel5 = PDM_STAT_CH5F_MASK , kPDM_EnableChannel6 = PDM_STAT_CH6F_MASK , kPDM_EnableChannel7 = PDM_STAT_CH7F_MASK ,
  kPDM_EnableChannelAll
 PDM channel enable mask. More...
enum  _pdm_fifo_status {
  kPDM_FifoStatusUnderflowCh0 = PDM_FIFO_STAT_FIFOUND0_MASK , kPDM_FifoStatusUnderflowCh1 = PDM_FIFO_STAT_FIFOUND1_MASK , kPDM_FifoStatusUnderflowCh2 = PDM_FIFO_STAT_FIFOUND2_MASK , kPDM_FifoStatusUnderflowCh3 = PDM_FIFO_STAT_FIFOUND3_MASK ,
  kPDM_FifoStatusUnderflowCh4 = PDM_FIFO_STAT_FIFOUND4_MASK , kPDM_FifoStatusUnderflowCh5 = PDM_FIFO_STAT_FIFOUND5_MASK , kPDM_FifoStatusUnderflowCh6 = PDM_FIFO_STAT_FIFOUND6_MASK , kPDM_FifoStatusUnderflowCh7 = PDM_FIFO_STAT_FIFOUND6_MASK ,
  kPDM_FifoStatusOverflowCh0 = PDM_FIFO_STAT_FIFOOVF0_MASK , kPDM_FifoStatusOverflowCh1 = PDM_FIFO_STAT_FIFOOVF1_MASK , kPDM_FifoStatusOverflowCh2 = PDM_FIFO_STAT_FIFOOVF2_MASK , kPDM_FifoStatusOverflowCh3 = PDM_FIFO_STAT_FIFOOVF3_MASK ,
  kPDM_FifoStatusOverflowCh4 = PDM_FIFO_STAT_FIFOOVF4_MASK , kPDM_FifoStatusOverflowCh5 = PDM_FIFO_STAT_FIFOOVF5_MASK , kPDM_FifoStatusOverflowCh6 = PDM_FIFO_STAT_FIFOOVF6_MASK , kPDM_FifoStatusOverflowCh7 = PDM_FIFO_STAT_FIFOOVF7_MASK
 The PDM fifo status. More...
enum  _pdm_output_status {
  kPDM_OutputStatusUnderFlowCh0 = PDM_OUT_STAT_OUTUNF0_MASK , kPDM_OutputStatusUnderFlowCh1 = PDM_OUT_STAT_OUTUNF1_MASK , kPDM_OutputStatusUnderFlowCh2 = PDM_OUT_STAT_OUTUNF2_MASK , kPDM_OutputStatusUnderFlowCh3 = PDM_OUT_STAT_OUTUNF3_MASK ,
  kPDM_OutputStatusUnderFlowCh4 = PDM_OUT_STAT_OUTUNF4_MASK , kPDM_OutputStatusUnderFlowCh5 = PDM_OUT_STAT_OUTUNF5_MASK , kPDM_OutputStatusUnderFlowCh6 = PDM_OUT_STAT_OUTUNF6_MASK , kPDM_OutputStatusUnderFlowCh7 = PDM_OUT_STAT_OUTUNF7_MASK ,
  kPDM_OutputStatusOverFlowCh0 = PDM_OUT_STAT_OUTOVF0_MASK , kPDM_OutputStatusOverFlowCh1 = PDM_OUT_STAT_OUTOVF1_MASK , kPDM_OutputStatusOverFlowCh2 = PDM_OUT_STAT_OUTOVF2_MASK , kPDM_OutputStatusOverFlowCh3 = PDM_OUT_STAT_OUTOVF3_MASK ,
  kPDM_OutputStatusOverFlowCh4 = PDM_OUT_STAT_OUTOVF4_MASK , kPDM_OutputStatusOverFlowCh5 = PDM_OUT_STAT_OUTOVF5_MASK , kPDM_OutputStatusOverFlowCh6 = PDM_OUT_STAT_OUTOVF6_MASK , kPDM_OutputStatusOverFlowCh7 = PDM_OUT_STAT_OUTOVF7_MASK
 The PDM output status. More...
enum  _pdm_dc_remover { kPDM_DcRemoverCutOff21Hz = 0U , kPDM_DcRemoverCutOff83Hz = 1U , kPDM_DcRemoverCutOff152Hz = 2U , kPDM_DcRemoverBypass = 3U }
 PDM DC remover configurations. More...
enum  _pdm_df_quality_mode {
  kPDM_QualityModeMedium = 0U , kPDM_QualityModeHigh = 1U , kPDM_QualityModeLow = 7U , kPDM_QualityModeVeryLow0 = 6U ,
  kPDM_QualityModeVeryLow1 = 5U , kPDM_QualityModeVeryLow2 = 4U
 PDM decimation filter quality mode. More...
enum  _pdm_qulaity_mode_k_factor { kPDM_QualityModeHighKFactor = 1U , kPDM_QualityModeMediumKFactor = 2U , kPDM_QualityModeLowKFactor = 4U , kPDM_QualityModeVeryLow2KFactor = 8U }
 PDM quality mode K factor. More...
enum  _pdm_df_output_gain {
  kPDM_DfOutputGain0 = 0U , kPDM_DfOutputGain1 = 1U , kPDM_DfOutputGain2 = 2U , kPDM_DfOutputGain3 = 3U ,
  kPDM_DfOutputGain4 = 4U , kPDM_DfOutputGain5 = 5U , kPDM_DfOutputGain6 = 6U , kPDM_DfOutputGain7 = 7U ,
  kPDM_DfOutputGain8 = 8U , kPDM_DfOutputGain9 = 9U , kPDM_DfOutputGain10 = 0xAU , kPDM_DfOutputGain11 = 0xBU ,
  kPDM_DfOutputGain12 = 0xCU , kPDM_DfOutputGain13 = 0xDU , kPDM_DfOutputGain14 = 0xEU , kPDM_DfOutputGain15 = 0xFU
 PDM decimation filter output gain. More...
enum  _pdm_data_width { kPDM_DataWdith16 = 2U }
 PDM data width. More...
enum  _pdm_hwvad_interrupt_enable { kPDM_HwvadErrorInterruptEnable = PDM_VAD0_CTRL_1_VADERIE_MASK , kPDM_HwvadInterruptEnable = PDM_VAD0_CTRL_1_VADIE_MASK }
 PDM voice activity detector interrupt type. More...
enum  _pdm_hwvad_int_status { kPDM_HwvadStatusInputSaturation = PDM_VAD0_STAT_VADINSATF_MASK , kPDM_HwvadStatusVoiceDetectFlag = PDM_VAD0_STAT_VADIF_MASK }
 The PDM hwvad interrupt status flag. More...
enum  _pdm_hwvad_hpf_config { kPDM_HwvadHpfBypassed = 0x0U , kPDM_HwvadHpfCutOffFreq1750Hz = 0x1U , kPDM_HwvadHpfCutOffFreq215Hz = 0x2U , kPDM_HwvadHpfCutOffFreq102Hz = 0x3U }
 High pass filter configure cut-off frequency. More...
enum  _pdm_hwvad_filter_status { kPDM_HwvadInternalFilterNormalOperation = 0U , kPDM_HwvadInternalFilterInitial = PDM_VAD0_CTRL_1_VADST10_MASK }
 HWVAD internal filter status. More...
enum  _pdm_hwvad_zcd_result { kPDM_HwvadResultOREnergyBasedDetection , kPDM_HwvadResultANDEnergyBasedDetection }
 PDM voice activity detector zero cross detector result. More...
typedef enum _pdm_dc_remover pdm_dc_remover_t
typedef enum _pdm_df_quality_mode pdm_df_quality_mode_t
typedef enum _pdm_df_output_gain pdm_df_output_gain_t
typedef struct _pdm_channel_config pdm_channel_config_t
typedef struct _pdm_config pdm_config_t
typedef enum _pdm_hwvad_hpf_config pdm_hwvad_hpf_config_t
typedef enum _pdm_hwvad_filter_status pdm_hwvad_filter_status_t
typedef struct _pdm_hwvad_config pdm_hwvad_config_t
typedef struct _pdm_hwvad_noise_filter pdm_hwvad_noise_filter_t
typedef enum _pdm_hwvad_zcd_result pdm_hwvad_zcd_result_t
typedef struct _pdm_hwvad_zero_cross_detector pdm_hwvad_zero_cross_detector_t
typedef struct _pdm_transfer pdm_transfer_t
typedef struct _pdm_handle pdm_handle_t
 PDM handle.
typedef void(* pdm_transfer_callback_t) (PDM_Type *base, pdm_handle_t *handle, status_t status, void *userData)
 PDM transfer callback prototype.
typedef void(* pdm_hwvad_callback_t) (status_t status, void *userData)
 PDM HWVAD callback prototype.
typedef struct _pdm_hwvad_notification pdm_hwvad_notification_t
#define FSL_PDM_DRIVER_VERSION   (MAKE_VERSION(2, 8, 0))
#define PDM_XFER_QUEUE_SIZE   (4U)
 PDM XFER QUEUE SIZE.
Initialization and deinitialization
void PDM_Init (PDM_Type *base, const pdm_config_t *config)
 Initializes the PDM peripheral.
void PDM_Deinit (PDM_Type *base)
 De-initializes the PDM peripheral.
void PDM_SetChannelConfig (PDM_Type *base, uint32_t channel, const pdm_channel_config_t *config)
 PDM one channel configurations.
status_t PDM_SetSampleRateConfig (PDM_Type *base, uint32_t sourceClock_HZ, uint32_t sampleRate_HZ)
 PDM set sample rate.
status_t PDM_SetSampleRate (PDM_Type *base, uint32_t enableChannelMask, pdm_df_quality_mode_t qualityMode, uint8_t osr, uint32_t clkDiv)
uint32_t PDM_GetInstance (PDM_Type *base)
 Get the instance number for PDM.
Interrupts
void PDM_EnableInterrupts (PDM_Type *base, uint32_t mask)
 Enables the PDM interrupt requests.
Bus Operations
void PDM_ReadFifo (PDM_Type *base, uint32_t startChannel, uint32_t channelNums, void *buffer, size_t size, uint32_t dataWidth)
 PDM read fifo.
void PDM_SetChannelGain (PDM_Type *base, uint32_t channel, pdm_df_output_gain_t gain)
 Set the PDM channel gain.
Voice Activity Detector
void PDM_SetHwvadConfig (PDM_Type *base, const pdm_hwvad_config_t *config)
 Configure voice activity detector.
void PDM_SetHwvadSignalFilterConfig (PDM_Type *base, bool enableMaxBlock, uint32_t signalGain)
 Configure voice activity detector signal filter.
void PDM_SetHwvadNoiseFilterConfig (PDM_Type *base, const pdm_hwvad_noise_filter_t *config)
 Configure voice activity detector noise filter.
void PDM_SetHwvadZeroCrossDetectorConfig (PDM_Type *base, const pdm_hwvad_zero_cross_detector_t *config)
 Configure voice activity detector zero cross detector.
void PDM_SetHwvadInEnvelopeBasedMode (PDM_Type *base, const pdm_hwvad_config_t *hwvadConfig, const pdm_hwvad_noise_filter_t *noiseConfig, const pdm_hwvad_zero_cross_detector_t *zcdConfig, uint32_t signalGain)
 set HWVAD in envelope based mode . Recommand configurations,
void PDM_SetHwvadInEnergyBasedMode (PDM_Type *base, const pdm_hwvad_config_t *hwvadConfig, const pdm_hwvad_noise_filter_t *noiseConfig, const pdm_hwvad_zero_cross_detector_t *zcdConfig, uint32_t signalGain)
void PDM_EnableHwvadInterruptCallback (PDM_Type *base, pdm_hwvad_callback_t vadCallback, void *userData, bool enable)
 Enable/Disable hwvad callback.
Transactional
void PDM_TransferCreateHandle (PDM_Type *base, pdm_handle_t *handle, pdm_transfer_callback_t callback, void *userData)
 Initializes the PDM handle.
status_t PDM_TransferSetChannelConfig (PDM_Type *base, pdm_handle_t *handle, uint32_t channel, const pdm_channel_config_t *config, uint32_t format)
 PDM set channel transfer config.
status_t PDM_TransferReceiveNonBlocking (PDM_Type *base, pdm_handle_t *handle, pdm_transfer_t *xfer)
 Performs an interrupt non-blocking receive transfer on PDM.
void PDM_TransferAbortReceive (PDM_Type *base, pdm_handle_t *handle)
 Aborts the current IRQ receive.
void PDM_TransferHandleIRQ (PDM_Type *base, pdm_handle_t *handle)
 Tx interrupt handler.
◆ FSL_PDM_DRIVER_VERSION
Version 2.8.0
◆ anonymous enum
anonymous enum
PDM return status.
kStatus_PDM_Busy
PDM is busy.
PDM FIFO underrun or overflow
kStatus_PDM_Idle
PDM is idle
PDM is output error
PDM channel config failed
PDM hwvad voice detected
PDM hwvad error
◆ _pdm_channel_enable_mask
kPDM_EnableChannel0
channgel 0 enable mask
kPDM_EnableChannel1
channgel 1 enable mask
kPDM_EnableChannel2
channgel 2 enable mask
kPDM_EnableChannel3
channgel 3 enable mask
kPDM_EnableChannel4
channgel 4 enable mask
kPDM_EnableChannel5
channgel 5 enable mask
kPDM_EnableChannel6
channgel 6 enable mask
kPDM_EnableChannel7
channgel 7 enable mask
◆ _pdm_data_width
PDM data width.
kPDM_DataWdith16
PDM data width 16bit
◆ _pdm_dc_remover
DC remover cut off 21HZ
DC remover cut off 83HZ
DC remover cut off 152HZ
DC remover bypass
◆ _pdm_df_output_gain
kPDM_DfOutputGain0
Decimation filter output gain 0
kPDM_DfOutputGain1
Decimation filter output gain 1
kPDM_DfOutputGain2
Decimation filter output gain 2
kPDM_DfOutputGain3
Decimation filter output gain 3
kPDM_DfOutputGain4
Decimation filter output gain 4
kPDM_DfOutputGain5
Decimation filter output gain 5
kPDM_DfOutputGain6
Decimation filter output gain 6
kPDM_DfOutputGain7
Decimation filter output gain 7
kPDM_DfOutputGain8
Decimation filter output gain 8
kPDM_DfOutputGain9
Decimation filter output gain 9
kPDM_DfOutputGain10
Decimation filter output gain 10
kPDM_DfOutputGain11
Decimation filter output gain 11
kPDM_DfOutputGain12
Decimation filter output gain 12
kPDM_DfOutputGain13
Decimation filter output gain 13
kPDM_DfOutputGain14
Decimation filter output gain 14
kPDM_DfOutputGain15
Decimation filter output gain 15
◆ _pdm_df_quality_mode
quality mode memdium
quality mode high
kPDM_QualityModeLow
quality mode low
quality mode very low0
quality mode very low1
quality mode very low2
◆ _pdm_fifo_status
channel0 fifo status underflow
channel1 fifo status underflow
channel2 fifo status underflow
channel3 fifo status underflow
channel4 fifo status underflow
channel5 fifo status underflow
channel6 fifo status underflow
channel7 fifo status underflow
channel0 fifo status overflow
channel1 fifo status overflow
channel2 fifo status overflow
channel3 fifo status overflow
channel4 fifo status overflow
channel5 fifo status overflow
channel6 fifo status overflow
channel7 fifo status overflow
◆ _pdm_hwvad_filter_status
internal filter ready for normal operation
interla filter are initial
◆ _pdm_hwvad_hpf_config
High-pass filter bypass
High-pass filter cut off frequency 1750HZ
High-pass filter cut off frequency 215HZ
High-pass filter cut off frequency 102HZ
◆ _pdm_hwvad_int_status
HWVAD saturation condition
HWVAD voice detect interrupt triggered
◆ _pdm_hwvad_interrupt_enable
PDM channel HWVAD error interrupt enable.
PDM channel HWVAD interrupt
◆ _pdm_hwvad_zcd_result
zero cross detector result will be OR with energy based detection
zero cross detector result will be AND with energy based detection
◆ _pdm_internal_status
The PDM status.
Decimation filter is busy processing data
FIR filter data is ready
channel 0 fifo data reached watermark level
channel 1 fifo data reached watermark level
channel 2 fifo data reached watermark level
channel 3 fifo data reached watermark level
channel 4 fifo data reached watermark level
channel 5 fifo data reached watermark level
channel 6 fifo data reached watermark level
channel 7 fifo data reached watermark level
◆ _pdm_interrupt_enable
PDM channel error interrupt enable.
PDM channel FIFO interrupt
◆ _pdm_output_status
channel0 output status underflow
channel1 output status underflow
channel2 output status underflow
channel3 output status underflow
channel4 output status underflow
channel5 output status underflow
channel6 output status underflow
channel7 output status underflow
channel0 output status overflow
channel1 output status overflow
channel2 output status overflow
channel3 output status overflow
channel4 output status overflow
channel5 output status overflow
channel6 output status overflow
channel7 output status overflow
◆ _pdm_qulaity_mode_k_factor
high quality mode K factor = 1 / 2
medium/very low0 quality mode K factor = 2 / 2
low/very low1 quality mode K factor = 4 / 2
very low2 quality mode K factor = 8 / 2
◆ PDM_Deinit()
void PDM_Deinit ( PDM_Type base)
This API gates the PDM clock. The PDM module can't operate unless PDM_Init is called to enable the clock.
Parameters
basePDM base pointer
brief De-initializes the PDM peripheral.
param base PDM base pointer
◆ PDM_EnableHwvadInterruptCallback()
void PDM_EnableHwvadInterruptCallback ( PDM_Type base,
void *  userData,
bool  enable
This function enable/disable the hwvad interrupt for the selected PDM peripheral.
Parameters
baseBase address of the PDM peripheral.
vadCallbackcallback Pointer to store callback function, should be NULL when disable.
userDatauser data.
enabletrue is enable, false is disable.
Return values
None.
brief Enable/Disable hwvad callback.
param base Base address of the PDM peripheral. param vadCallback callback Pointer to store callback function, should be NULL when disable. param userData user data. param enable true is enable, false is disable. retval None.
◆ PDM_EnableInterrupts()
void PDM_EnableInterrupts ( PDM_Type base,
uint32_t  mask
Parameters
maskinterrupt source The parameter can be a combination of the following sources if defined.
  • kPDM_ErrorInterruptEnable
  • kPDM_FIFOInterruptEnable
brief Enables the PDM interrupt requests.
param base PDM base pointer param mask interrupt source The parameter can be a combination of the following sources if defined. arg kPDM_ErrorInterruptEnable arg kPDM_FIFOInterruptEnable
◆ PDM_GetInstance()
uint32_t PDM_GetInstance ( PDM_Type base)
Parameters
basePDM base pointer.
◆ PDM_Init()
void PDM_Init ( PDM_Type base,
const pdm_config_t config
Ungates the PDM clock, resets the module, and configures PDM with a configuration structure. The configuration structure can be custom filled or set with default values by PDM_GetDefaultConfig().
Note
This API should be called at the beginning of the application to use the PDM driver. Otherwise, accessing the PDM module can cause a hard fault because the clock is not enabled.
Parameters
configPDM configuration structure.
brief Initializes the PDM peripheral.
note This API should be called at the beginning of the application to use the PDM driver. Otherwise, accessing the PDM module can cause a hard fault because the clock is not enabled.
param base PDM base pointer param config PDM configuration structure.
◆ PDM_ReadFifo()
void PDM_ReadFifo ( PDM_Type base,
void *  buffer,
size_t  size,
uint32_t  dataWidth
PDM read fifo.
Note
: This function support 16 bit only for IP version that only supports 16bit.
Parameters
startChannelstart channel number.
channelNumstotal enabled channelnums.
bufferreceived buffer address.
sizenumber of samples to read.
dataWidthsample width.
brief PDM read fifo. Note: This function support 16 bit only for IP version that only supports 16bit.
param base PDM base pointer. param startChannel start channel number. param channelNums total enabled channelnums. param buffer received buffer address. param size number of samples to read. param dataWidth sample width.
◆ PDM_SetChannelConfig()
void PDM_SetChannelConfig ( PDM_Type base,
uint32_t  channel,
const pdm_channel_config_t config
Parameters
configPDM channel configurations.
channelchannel number. after completing the current frame in debug mode.
brief PDM one channel configurations.
param base PDM base pointer param config PDM channel configurations. param channel channel number. after completing the current frame in debug mode.
◆ PDM_SetChannelGain()
void PDM_SetChannelGain ( PDM_Type base,
uint32_t  channel,
Please note for different quality mode, the valid gain value is different, reference RM for detail.
Parameters
channelPDM channel index.
gainchannel gain, the register gain value range is 0 - 15.
brief Set the PDM channel gain.
Please note for different quality mode, the valid gain value is different, reference RM for detail. param base PDM base pointer. param channel PDM channel index. param gain channel gain, the register gain value range is 0 - 15.
◆ PDM_SetHwvadConfig()
void PDM_SetHwvadConfig ( PDM_Type base,
const pdm_hwvad_config_t config
Parameters
configVoice activity detector configure structure pointer .
brief Configure voice activity detector.
param base PDM base pointer param config Voice activity detector configure structure pointer .
◆ PDM_SetHwvadInEnergyBasedMode()
void PDM_SetHwvadInEnergyBasedMode ( PDM_Type base,
const pdm_hwvad_config_t hwvadConfig,
const pdm_hwvad_noise_filter_t noiseConfig,
const pdm_hwvad_zero_cross_detector_t zcdConfig,
uint32_t  signalGain
brief set HWVAD in energy based mode . Recommand configurations, code static const pdm_hwvad_config_t hwvadConfig = { .channel = 0, .initializeTime = 10U, .cicOverSampleRate = 0U, .inputGain = 0U, .frameTime = 10U, .cutOffFreq = kPDM_HwvadHpfBypassed, .enableFrameEnergy = true, .enablePreFilter = true, };
static const pdm_hwvad_noise_filter_t noiseFilterConfig = { .enableAutoNoiseFilter = true, .enableNoiseMin = false, .enableNoiseDecimation = false, .noiseFilterAdjustment = 0U, .noiseGain = 7U, .enableNoiseDetectOR = false, }; code param base PDM base pointer. param hwvadConfig internal filter status. param noiseConfig Voice activity detector noise filter configure structure pointer. param zcdConfig Voice activity detector zero cross detector configure structure pointer . param signalGain signal gain value, signal gain value should be properly according to application.
◆ PDM_SetHwvadInEnvelopeBasedMode()
void PDM_SetHwvadInEnvelopeBasedMode ( PDM_Type base,
uint32_t  signalGain
.channel = 0,
.inputGain = 0U,
.frameTime = 10U,
.enableFrameEnergy = false,
.enableNoiseMin = true,
.enableNoiseDecimation = true,
.noiseGain = 7U,
.enableNoiseDetectOR = true,
@ kPDM_HwvadHpfBypassed
Definition: fsl_pdm.h:290
Definition: fsl_pdm.h:305
uint8_t channel
Definition: fsl_pdm.h:306
Definition: fsl_pdm.h:319
bool enableAutoNoiseFilter
Definition: fsl_pdm.h:320
Parameters
hwvadConfiginternal filter status.
noiseConfigVoice activity detector noise filter configure structure pointer.
zcdConfigVoice activity detector zero cross detector configure structure pointer .
signalGainsignal gain value.
brief set HWVAD in envelope based mode . Recommand configurations, code static const pdm_hwvad_config_t hwvadConfig = { .channel = 0, .initializeTime = 10U, .cicOverSampleRate = 0U, .inputGain = 0U, .frameTime = 10U, .cutOffFreq = kPDM_HwvadHpfBypassed, .enableFrameEnergy = false, .enablePreFilter = true, };
static const pdm_hwvad_noise_filter_t noiseFilterConfig = { .enableAutoNoiseFilter = false, .enableNoiseMin = true, .enableNoiseDecimation = true, .noiseFilterAdjustment = 0U, .noiseGain = 7U, .enableNoiseDetectOR = true, }; code param base PDM base pointer. param hwvadConfig internal filter status. param noiseConfig Voice activity detector noise filter configure structure pointer. param zcdConfig Voice activity detector zero cross detector configure structure pointer . param signalGain signal gain value.
◆ PDM_SetHwvadNoiseFilterConfig()
void PDM_SetHwvadNoiseFilterConfig ( PDM_Type base,
const pdm_hwvad_noise_filter_t config
Parameters
configVoice activity detector noise filter configure structure pointer .
brief Configure voice activity detector noise filter.
param base PDM base pointer param config Voice activity detector noise filter configure structure pointer .
◆ PDM_SetHwvadSignalFilterConfig()
void PDM_SetHwvadSignalFilterConfig ( PDM_Type base,
uint32_t  signalGain
Parameters
enableMaxBlockIf signal maximum block enabled.
signalGainGain value for the signal energy.
brief Configure voice activity detector signal filter.
param base PDM base pointer param enableMaxBlock If signal maximum block enabled. param signalGain Gain value for the signal energy.
◆ PDM_SetHwvadZeroCrossDetectorConfig()
void PDM_SetHwvadZeroCrossDetectorConfig ( PDM_Type base,
const pdm_hwvad_zero_cross_detector_t config
Parameters
configVoice activity detector zero cross detector configure structure pointer .
brief Configure voice activity detector zero cross detector.
param base PDM base pointer param config Voice activity detector zero cross detector configure structure pointer .
◆ PDM_SetSampleRate()
status_t PDM_SetSampleRate ( PDM_Type base,
uint8_t  osr,
uint32_t  clkDiv
Deprecated:
Do not use this function. It has been superceded by PDM_SetSampleRateConfig
Parameters
enableChannelMaskPDM channel enable mask.
qualityModequality mode.
osrcic oversample rate
clkDivclock divider
brief PDM set sample rate.
deprecated Do not use this function. It has been superceded by PDM_SetSampleRateConfig param base PDM base pointer param enableChannelMask PDM channel enable mask. param qualityMode quality mode. param osr cic oversample rate param clkDiv clock divider
◆ PDM_SetSampleRateConfig()
status_t PDM_SetSampleRateConfig ( PDM_Type base,
Note
This function is depend on the configuration of the PDM and PDM channel, so the correct call sequence is
PDM_Init(base, pdmConfig)
PDM_SetChannelConfig(base, channel, &channelConfig)
PDM_SetSampleRateConfig(base, source, sampleRate)
status_t PDM_SetSampleRateConfig(PDM_Type *base, uint32_t sourceClock_HZ, uint32_t sampleRate_HZ)
Definition: fsl_pdm.c:217
void PDM_Init(PDM_Type *base, const pdm_config_t *config)
Definition: fsl_pdm.c:313
void PDM_SetChannelConfig(PDM_Type *base, uint32_t channel, const pdm_channel_config_t *config)
Definition: fsl_pdm.c:398
Parameters
sourceClock_HZPDM source clock frequency.
sampleRate_HZPDM sample rate.
note This function is depend on the configuration of the PDM and PDM channel, so the correct call sequence is code PDM_Init(base, pdmConfig) PDM_SetChannelConfig(base, channel, &channelConfig) PDM_SetSampleRateConfig(base, source, sampleRate) endcode param base PDM base pointer param sourceClock_HZ PDM source clock frequency. param sampleRate_HZ PDM sample rate.
◆ PDM_TransferAbortReceive()
void PDM_TransferAbortReceive ( PDM_Type base,
pdm_handle_t handle
Note
This API can be called when an interrupt non-blocking transfer initiates to abort the transfer early.
Parameters
handlePointer to the pdm_handle_t structure which stores the transfer state.
brief Aborts the current IRQ receive.
note This API can be called when an interrupt non-blocking transfer initiates to abort the transfer early.
param base PDM base pointer param handle Pointer to the pdm_handle_t structure which stores the transfer state.
◆ PDM_TransferCreateHandle()
void PDM_TransferCreateHandle ( PDM_Type base,
pdm_handle_t handle,
void *  userData
This function initializes the handle for the PDM transactional APIs. Call this function once to get the handle initialized.
Parameters
handlePDM handle pointer.
callbackPointer to the user callback function.
userDataUser parameter passed to the callback function.
brief Initializes the PDM handle.
param base PDM base pointer. param handle PDM handle pointer. param callback Pointer to the user callback function. param userData User parameter passed to the callback function.
◆ PDM_TransferHandleIRQ()
void PDM_TransferHandleIRQ ( PDM_Type base,
pdm_handle_t handle
Parameters
handlePointer to the pdm_handle_t structure.
brief Tx interrupt handler.
param base PDM base pointer. param handle Pointer to the pdm_handle_t structure.
◆ PDM_TransferReceiveNonBlocking()
status_t PDM_TransferReceiveNonBlocking ( PDM_Type base,
pdm_transfer_t xfer
Note
This API returns immediately after the transfer initiates. Call the PDM_RxGetTransferStatusIRQ to poll the transfer status and check whether the transfer is finished. If the return status is not kStatus_PDM_Busy, the transfer is finished.
Parameters
xferPointer to the pdm_transfer_t structure.
Return values
kStatus_SuccessSuccessfully started the data receive.
kStatus_PDM_BusyPrevious receive still not finished.
brief Performs an interrupt non-blocking receive transfer on PDM.
note This API returns immediately after the transfer initiates. Call the PDM_RxGetTransferStatusIRQ to poll the transfer status and check whether the transfer is finished. If the return status is not kStatus_PDM_Busy, the transfer is finished.
param base PDM base pointer param handle Pointer to the pdm_handle_t structure which stores the transfer state. param xfer Pointer to the pdm_transfer_t structure. retval kStatus_Success Successfully started the data receive. retval kStatus_PDM_Busy Previous receive still not finished.
◆ PDM_TransferSetChannelConfig()
status_t PDM_TransferSetChannelConfig ( PDM_Type base,
uint32_t  channel,
const pdm_channel_config_t config,
uint32_t  format
Parameters
channelPDM channel.
configchannel config.
formatdata format, support data width configurations,_pdm_data_width.
Return values
kStatus_PDM_ChannelConfig_Failedor kStatus_Success.
brief PDM set channel transfer config.
param base PDM base pointer. param handle PDM handle pointer. param channel PDM channel. param config channel config. param format data format.
