RTEMS 6.2-rc3
| #define | IS_SAI_BLOCK_SYNCEXT(STATE) |
| #define | IS_SAI_SUPPORTED_PROTOCOL(PROTOCOL) |
| #define | IS_SAI_PROTOCOL_DATASIZE(DATASIZE) |
| #define | IS_SAI_AUDIO_FREQUENCY(AUDIO) |
| #define | IS_SAI_BLOCK_MCK_OVERSAMPLING(VALUE) |
| #define | IS_SAI_PDM_MIC_PAIRS_NUMBER(VALUE) ((1U <= (VALUE)) && ((VALUE) <= 3U)) |
| #define | IS_SAI_PDM_CLOCK_ENABLE(CLOCK) |
| #define | IS_SAI_BLOCK_MODE(MODE) |
| #define | IS_SAI_BLOCK_PROTOCOL(PROTOCOL) |
| #define | IS_SAI_BLOCK_DATASIZE(DATASIZE) |
| #define | IS_SAI_BLOCK_FIRST_BIT(BIT) |
| #define | IS_SAI_BLOCK_CLOCK_STROBING(CLOCK) |
| #define | IS_SAI_BLOCK_SYNCHRO(SYNCHRO) |
| #define | IS_SAI_BLOCK_MCK_OUTPUT(VALUE) |
| #define | IS_SAI_BLOCK_OUTPUT_DRIVE(DRIVE) |
| #define | IS_SAI_BLOCK_NODIVIDER(NODIVIDER) |
| #define | IS_SAI_BLOCK_MUTE_COUNTER(COUNTER) ((COUNTER) <= 63U) |
| #define | IS_SAI_BLOCK_MUTE_VALUE(VALUE) |
| #define | IS_SAI_BLOCK_COMPANDING_MODE(MODE) |
| #define | IS_SAI_BLOCK_FIFO_THRESHOLD(THRESHOLD) |
| #define | IS_SAI_BLOCK_TRISTATE_MANAGEMENT(STATE) |
| #define | IS_SAI_MONO_STEREO_MODE(MODE) |
| #define | IS_SAI_SLOT_ACTIVE(ACTIVE) ((ACTIVE) <= SAI_SLOTACTIVE_ALL) |
| #define | IS_SAI_BLOCK_SLOT_NUMBER(NUMBER) ((1U <= (NUMBER)) && ((NUMBER) <= 16U)) |
| #define | IS_SAI_BLOCK_SLOT_SIZE(SIZE) |
| #define | IS_SAI_BLOCK_FIRSTBIT_OFFSET(OFFSET) ((OFFSET) <= 24U) |
| #define | IS_SAI_BLOCK_FS_OFFSET(OFFSET) |
| #define | IS_SAI_BLOCK_FS_POLARITY(POLARITY) |
| #define | IS_SAI_BLOCK_FS_DEFINITION(DEFINITION) |
| #define | IS_SAI_BLOCK_MASTER_DIVIDER(DIVIDER) ((DIVIDER) <= 63U) |
| #define | IS_SAI_BLOCK_FRAME_LENGTH(LENGTH) ((8U <= (LENGTH)) && ((LENGTH) <= 256U)) |
| #define | IS_SAI_BLOCK_ACTIVE_FRAME(LENGTH) ((1U <= (LENGTH)) && ((LENGTH) <= 128U)) |
| #define IS_SAI_AUDIO_FREQUENCY | ( | AUDIO | ) |
| #define IS_SAI_BLOCK_CLOCK_STROBING | ( | CLOCK | ) |
| #define IS_SAI_BLOCK_COMPANDING_MODE | ( | MODE | ) |
| #define IS_SAI_BLOCK_DATASIZE | ( | DATASIZE | ) |
| #define IS_SAI_BLOCK_FIFO_THRESHOLD | ( | THRESHOLD | ) |
| #define IS_SAI_BLOCK_FIRST_BIT | ( | BIT | ) |
| #define IS_SAI_BLOCK_FS_DEFINITION | ( | DEFINITION | ) |
| #define IS_SAI_BLOCK_FS_OFFSET | ( | OFFSET | ) |
| #define IS_SAI_BLOCK_FS_POLARITY | ( | POLARITY | ) |
| #define IS_SAI_BLOCK_MCK_OUTPUT | ( | VALUE | ) |
| #define IS_SAI_BLOCK_MCK_OVERSAMPLING | ( | VALUE | ) |
| #define IS_SAI_BLOCK_MODE | ( | MODE | ) |
| #define IS_SAI_BLOCK_MUTE_VALUE | ( | VALUE | ) |
| #define IS_SAI_BLOCK_NODIVIDER | ( | NODIVIDER | ) |
| #define IS_SAI_BLOCK_OUTPUT_DRIVE | ( | DRIVE | ) |
| #define IS_SAI_BLOCK_PROTOCOL | ( | PROTOCOL | ) |
| #define IS_SAI_BLOCK_SLOT_SIZE | ( | SIZE | ) |
| #define IS_SAI_BLOCK_SYNCEXT | ( | STATE | ) |
| #define IS_SAI_BLOCK_SYNCHRO | ( | SYNCHRO | ) |
| #define IS_SAI_BLOCK_TRISTATE_MANAGEMENT | ( | STATE | ) |
| #define IS_SAI_MONO_STEREO_MODE | ( | MODE | ) |
| #define IS_SAI_PDM_CLOCK_ENABLE | ( | CLOCK | ) |
| #define IS_SAI_PROTOCOL_DATASIZE | ( | DATASIZE | ) |
| #define IS_SAI_SUPPORTED_PROTOCOL | ( | PROTOCOL | ) |
