RTEMS 6.2-rc3
Files | |
| file | i2c-bus.c |
| Inter-Integrated Circuit (I2C) Bus Implementation. | |
| struct | i2c_bus |
| I2C bus control. More... | |
| int | i2c_bus_init (i2c_bus *bus) |
| Initializes a bus control. | |
| i2c_bus * | i2c_bus_alloc_and_init (size_t size) |
| Allocates a bus control from the heap and initializes it. | |
| void | i2c_bus_destroy (i2c_bus *bus) |
| Destroys a bus control. | |
| void | i2c_bus_destroy_and_free (i2c_bus *bus) |
| Destroys a bus control and frees its memory. | |
| int | i2c_bus_register (i2c_bus *bus, const char *bus_path) |
| Registers a bus control. | |
| int | i2c_bus_try_obtain (i2c_bus *bus) |
| Try to obtain the bus. | |
| void | i2c_bus_obtain (i2c_bus *bus) |
| Obtains the bus. | |
| void | i2c_bus_release (i2c_bus *bus) |
| Releases the bus. | |
| int | i2c_bus_transfer (i2c_bus *bus, i2c_msg *msgs, uint32_t msg_count) |
| Transfers I2C messages. | |
| int | i2c_bus_do_transfer (i2c_bus *bus, i2c_msg *msgs, uint32_t msg_count, uint32_t flags) |
| Transfers I2C messages with optional flags. | |
I2C IO Control Commands | |
| #define | I2C_BUS_OBTAIN 0x800 |
| #define | I2C_BUS_RELEASE 0x801 |
| #define | I2C_BUS_GET_CONTROL 0x802 |
| Gets the bus control. | |
| #define | I2C_BUS_SET_CLOCK 0x803 |
| Sets the bus clock in Hz. | |
| #define I2C_BUS_GET_CONTROL 0x802 |
The argument type is a pointer to i2c_bus pointer.
| #define I2C_BUS_OBTAIN 0x800 |
Obtains the bus.
This command has no argument.
| #define I2C_BUS_RELEASE 0x801 |
Releases the bus.
| #define I2C_BUS_SET_CLOCK 0x803 |
The argument type is unsigned long.
| i2c_bus * i2c_bus_alloc_and_init | ( | size_t | size | ) |
After a sucessful allocation and initialization the bus control must be destroyed via i2c_bus_destroy_and_free(). A registered bus control will be automatically destroyed in case the device file is unlinked. Make sure to call i2c_bus_destroy_and_free() in a custom destruction handler.
| [in] | size | The size of the bus control. This enables the addition of bus controller specific data to the base bus control. The bus control is zero initialized. |
| non-NULL | The new bus control. |
| NULL | An error occurred. The errno is set to indicate the error. |
| void i2c_bus_destroy | ( | i2c_bus * | bus | ) |
| [in] | bus | The bus control. |
| void i2c_bus_destroy_and_free | ( | i2c_bus * | bus | ) |
The bus is obtained before the transfer and released afterwards. If the flag I2C_BUS_NOBLOCK is set and the bus is already obtained, nothing will be transfered and the function returns with an -EAGAIN.
| [in] | msgs | The messages to transfer. |
| [in] | msg_count | The count of messages to transfer. It must be positive. |
| [in] | flags | Options for the whole transfer. |
| 0 | Successful operation. |
| -EAGAIN | if I2C_BUS_NOBLOCK is set and the bus is already obtained. |
| negative | Negative error number in case of an error. |
| int i2c_bus_init | ( | i2c_bus * | bus | ) |
After a sucessful initialization the bus control must be destroyed via i2c_bus_destroy(). A registered bus control will be automatically destroyed in case the device file is unlinked. Make sure to call i2c_bus_destroy() in a custom destruction handler.
| -1 | An error occurred. The errno is set to indicate the error. |
| void i2c_bus_obtain | ( | i2c_bus * | bus | ) |
Obtains the bus.
| int i2c_bus_register | ( | i2c_bus * | bus, |
| const char * | bus_path | ||
This function claims ownership of the bus control regardless if the registration is successful or not.
| [in] | bus_path | The path to the bus device file. |
| void i2c_bus_release | ( | i2c_bus * | bus | ) |
Releases the bus.
The bus is obtained before the transfer and released afterwards. This is the same like calling i2c_bus_do_transfer with flags set to 0.
| int i2c_bus_try_obtain | ( | i2c_bus * | bus | ) |
| EBUSY | if mutex is already locked. |
