RTEMS 6.2-rc3
OSC_48M_CTRL - 48MHz RCOSC Control Register | |
| #define | ANADIG_OSC_OSC_48M_CTRL_TEN_MASK (0x2U) |
| #define | ANADIG_OSC_OSC_48M_CTRL_TEN_SHIFT (1U) |
| #define | ANADIG_OSC_OSC_48M_CTRL_TEN(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_OSC_OSC_48M_CTRL_TEN_SHIFT)) & ANADIG_OSC_OSC_48M_CTRL_TEN_MASK) |
| #define | ANADIG_OSC_OSC_48M_CTRL_RC_48M_DIV2_EN_MASK (0x1000000U) |
| #define | ANADIG_OSC_OSC_48M_CTRL_RC_48M_DIV2_EN_SHIFT (24U) |
| #define | ANADIG_OSC_OSC_48M_CTRL_RC_48M_DIV2_EN(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_OSC_OSC_48M_CTRL_RC_48M_DIV2_EN_SHIFT)) & ANADIG_OSC_OSC_48M_CTRL_RC_48M_DIV2_EN_MASK) |
| #define | ANADIG_OSC_OSC_48M_CTRL_RC_48M_DIV2_CONTROL_MODE_MASK (0x40000000U) |
| #define | ANADIG_OSC_OSC_48M_CTRL_RC_48M_DIV2_CONTROL_MODE_SHIFT (30U) |
| #define | ANADIG_OSC_OSC_48M_CTRL_RC_48M_DIV2_CONTROL_MODE(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_OSC_OSC_48M_CTRL_RC_48M_DIV2_CONTROL_MODE_SHIFT)) & ANADIG_OSC_OSC_48M_CTRL_RC_48M_DIV2_CONTROL_MODE_MASK) |
| #define | ANADIG_OSC_OSC_48M_CTRL_RC_48M_CONTROL_MODE_MASK (0x80000000U) |
| #define | ANADIG_OSC_OSC_48M_CTRL_RC_48M_CONTROL_MODE_SHIFT (31U) |
| #define | ANADIG_OSC_OSC_48M_CTRL_RC_48M_CONTROL_MODE(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_OSC_OSC_48M_CTRL_RC_48M_CONTROL_MODE_SHIFT)) & ANADIG_OSC_OSC_48M_CTRL_RC_48M_CONTROL_MODE_MASK) |
OSC_24M_CTRL - 24MHz OSC Control Register | |
| #define | ANADIG_OSC_OSC_24M_CTRL_BYPASS_CLK_MASK (0x1U) |
| #define | ANADIG_OSC_OSC_24M_CTRL_BYPASS_CLK_SHIFT (0U) |
| #define | ANADIG_OSC_OSC_24M_CTRL_BYPASS_CLK(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_OSC_OSC_24M_CTRL_BYPASS_CLK_SHIFT)) & ANADIG_OSC_OSC_24M_CTRL_BYPASS_CLK_MASK) |
| #define | ANADIG_OSC_OSC_24M_CTRL_BYPASS_EN_MASK (0x2U) |
| #define | ANADIG_OSC_OSC_24M_CTRL_BYPASS_EN_SHIFT (1U) |
| #define | ANADIG_OSC_OSC_24M_CTRL_BYPASS_EN(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_OSC_OSC_24M_CTRL_BYPASS_EN_SHIFT)) & ANADIG_OSC_OSC_24M_CTRL_BYPASS_EN_MASK) |
| #define | ANADIG_OSC_OSC_24M_CTRL_LP_EN_MASK (0x4U) |
| #define | ANADIG_OSC_OSC_24M_CTRL_LP_EN_SHIFT (2U) |
| #define | ANADIG_OSC_OSC_24M_CTRL_LP_EN(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_OSC_OSC_24M_CTRL_LP_EN_SHIFT)) & ANADIG_OSC_OSC_24M_CTRL_LP_EN_MASK) |
| #define | ANADIG_OSC_OSC_24M_CTRL_OSC_COMP_MODE_MASK (0x8U) |
| #define | ANADIG_OSC_OSC_24M_CTRL_OSC_COMP_MODE_SHIFT (3U) |
| #define | ANADIG_OSC_OSC_24M_CTRL_OSC_COMP_MODE(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_OSC_OSC_24M_CTRL_OSC_COMP_MODE_SHIFT)) & ANADIG_OSC_OSC_24M_CTRL_OSC_COMP_MODE_MASK) |
| #define | ANADIG_OSC_OSC_24M_CTRL_OSC_EN_MASK (0x10U) |
| #define | ANADIG_OSC_OSC_24M_CTRL_OSC_EN_SHIFT (4U) |
| #define | ANADIG_OSC_OSC_24M_CTRL_OSC_EN(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_OSC_OSC_24M_CTRL_OSC_EN_SHIFT)) & ANADIG_OSC_OSC_24M_CTRL_OSC_EN_MASK) |
| #define | ANADIG_OSC_OSC_24M_CTRL_OSC_24M_GATE_MASK (0x80U) |
| #define | ANADIG_OSC_OSC_24M_CTRL_OSC_24M_GATE_SHIFT (7U) |
| #define | ANADIG_OSC_OSC_24M_CTRL_OSC_24M_GATE(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_OSC_OSC_24M_CTRL_OSC_24M_GATE_SHIFT)) & ANADIG_OSC_OSC_24M_CTRL_OSC_24M_GATE_MASK) |
| #define | ANADIG_OSC_OSC_24M_CTRL_OSC_24M_STABLE_MASK (0x40000000U) |
| #define | ANADIG_OSC_OSC_24M_CTRL_OSC_24M_STABLE_SHIFT (30U) |
| #define | ANADIG_OSC_OSC_24M_CTRL_OSC_24M_STABLE(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_OSC_OSC_24M_CTRL_OSC_24M_STABLE_SHIFT)) & ANADIG_OSC_OSC_24M_CTRL_OSC_24M_STABLE_MASK) |
| #define | ANADIG_OSC_OSC_24M_CTRL_OSC_24M_CONTROL_MODE_MASK (0x80000000U) |
| #define | ANADIG_OSC_OSC_24M_CTRL_OSC_24M_CONTROL_MODE_SHIFT (31U) |
| #define | ANADIG_OSC_OSC_24M_CTRL_OSC_24M_CONTROL_MODE(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_OSC_OSC_24M_CTRL_OSC_24M_CONTROL_MODE_SHIFT)) & ANADIG_OSC_OSC_24M_CTRL_OSC_24M_CONTROL_MODE_MASK) |
OSC_400M_CTRL0 - 400MHz RCOSC Control0 Register | |
| #define | ANADIG_OSC_OSC_400M_CTRL0_OSC400M_AI_BUSY_MASK (0x80000000U) |
| #define | ANADIG_OSC_OSC_400M_CTRL0_OSC400M_AI_BUSY_SHIFT (31U) |
| #define | ANADIG_OSC_OSC_400M_CTRL0_OSC400M_AI_BUSY(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_OSC_OSC_400M_CTRL0_OSC400M_AI_BUSY_SHIFT)) & ANADIG_OSC_OSC_400M_CTRL0_OSC400M_AI_BUSY_MASK) |
OSC_400M_CTRL1 - 400MHz RCOSC Control1 Register | |
| #define | ANADIG_OSC_OSC_400M_CTRL1_PWD_MASK (0x1U) |
| #define | ANADIG_OSC_OSC_400M_CTRL1_PWD_SHIFT (0U) |
| #define | ANADIG_OSC_OSC_400M_CTRL1_PWD(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_OSC_OSC_400M_CTRL1_PWD_SHIFT)) & ANADIG_OSC_OSC_400M_CTRL1_PWD_MASK) |
| #define | ANADIG_OSC_OSC_400M_CTRL1_CLKGATE_400MEG_MASK (0x2U) |
| #define | ANADIG_OSC_OSC_400M_CTRL1_CLKGATE_400MEG_SHIFT (1U) |
| #define | ANADIG_OSC_OSC_400M_CTRL1_CLKGATE_400MEG(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_OSC_OSC_400M_CTRL1_CLKGATE_400MEG_SHIFT)) & ANADIG_OSC_OSC_400M_CTRL1_CLKGATE_400MEG_MASK) |
| #define | ANADIG_OSC_OSC_400M_CTRL1_RC_400M_CONTROL_MODE_MASK (0x80000000U) |
| #define | ANADIG_OSC_OSC_400M_CTRL1_RC_400M_CONTROL_MODE_SHIFT (31U) |
| #define | ANADIG_OSC_OSC_400M_CTRL1_RC_400M_CONTROL_MODE(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_OSC_OSC_400M_CTRL1_RC_400M_CONTROL_MODE_SHIFT)) & ANADIG_OSC_OSC_400M_CTRL1_RC_400M_CONTROL_MODE_MASK) |
OSC_400M_CTRL2 - 400MHz RCOSC Control2 Register | |
| #define | ANADIG_OSC_OSC_400M_CTRL2_ENABLE_CLK_MASK (0x1U) |
| #define | ANADIG_OSC_OSC_400M_CTRL2_ENABLE_CLK_SHIFT (0U) |
| #define | ANADIG_OSC_OSC_400M_CTRL2_ENABLE_CLK(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_OSC_OSC_400M_CTRL2_ENABLE_CLK_SHIFT)) & ANADIG_OSC_OSC_400M_CTRL2_ENABLE_CLK_MASK) |
| #define | ANADIG_OSC_OSC_400M_CTRL2_TUNE_BYP_MASK (0x400U) |
| #define | ANADIG_OSC_OSC_400M_CTRL2_TUNE_BYP_SHIFT (10U) |
| #define | ANADIG_OSC_OSC_400M_CTRL2_TUNE_BYP(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_OSC_OSC_400M_CTRL2_TUNE_BYP_SHIFT)) & ANADIG_OSC_OSC_400M_CTRL2_TUNE_BYP_MASK) |
| #define | ANADIG_OSC_OSC_400M_CTRL2_OSC_TUNE_VAL_MASK (0xFF000000U) |
| #define | ANADIG_OSC_OSC_400M_CTRL2_OSC_TUNE_VAL_SHIFT (24U) |
| #define | ANADIG_OSC_OSC_400M_CTRL2_OSC_TUNE_VAL(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_OSC_OSC_400M_CTRL2_OSC_TUNE_VAL_SHIFT)) & ANADIG_OSC_OSC_400M_CTRL2_OSC_TUNE_VAL_MASK) |
OSC_16M_CTRL - 16MHz RCOSC Control Register | |
| #define | ANADIG_OSC_OSC_16M_CTRL_EN_IRC4M16M_MASK (0x2U) |
| #define | ANADIG_OSC_OSC_16M_CTRL_EN_IRC4M16M_SHIFT (1U) |
| #define | ANADIG_OSC_OSC_16M_CTRL_EN_IRC4M16M(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_OSC_OSC_16M_CTRL_EN_IRC4M16M_SHIFT)) & ANADIG_OSC_OSC_16M_CTRL_EN_IRC4M16M_MASK) |
| #define | ANADIG_OSC_OSC_16M_CTRL_EN_POWER_SAVE_MASK (0x8U) |
| #define | ANADIG_OSC_OSC_16M_CTRL_EN_POWER_SAVE_SHIFT (3U) |
| #define | ANADIG_OSC_OSC_16M_CTRL_EN_POWER_SAVE(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_OSC_OSC_16M_CTRL_EN_POWER_SAVE_SHIFT)) & ANADIG_OSC_OSC_16M_CTRL_EN_POWER_SAVE_MASK) |
| #define | ANADIG_OSC_OSC_16M_CTRL_SOURCE_SEL_16M_MASK (0x100U) |
| #define | ANADIG_OSC_OSC_16M_CTRL_SOURCE_SEL_16M_SHIFT (8U) |
| #define | ANADIG_OSC_OSC_16M_CTRL_SOURCE_SEL_16M(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_OSC_OSC_16M_CTRL_SOURCE_SEL_16M_SHIFT)) & ANADIG_OSC_OSC_16M_CTRL_SOURCE_SEL_16M_MASK) |
| #define | ANADIG_OSC_OSC_16M_CTRL_RC_16M_CONTROL_MODE_MASK (0x80000000U) |
| #define | ANADIG_OSC_OSC_16M_CTRL_RC_16M_CONTROL_MODE_SHIFT (31U) |
| #define | ANADIG_OSC_OSC_16M_CTRL_RC_16M_CONTROL_MODE(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_OSC_OSC_16M_CTRL_RC_16M_CONTROL_MODE_SHIFT)) & ANADIG_OSC_OSC_16M_CTRL_RC_16M_CONTROL_MODE_MASK) |
| #define ANADIG_OSC_OSC_16M_CTRL_EN_IRC4M16M | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << ANADIG_OSC_OSC_16M_CTRL_EN_IRC4M16M_SHIFT)) & ANADIG_OSC_OSC_16M_CTRL_EN_IRC4M16M_MASK) |
EN_IRC4M16M - Enable Clock Output 0b0..Disable 0b1..Enable
| #define ANADIG_OSC_OSC_16M_CTRL_EN_POWER_SAVE | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << ANADIG_OSC_OSC_16M_CTRL_EN_POWER_SAVE_SHIFT)) & ANADIG_OSC_OSC_16M_CTRL_EN_POWER_SAVE_MASK) |
EN_POWER_SAVE - Power Save Enable 0b0..Disable 0b1..Enable
| #define ANADIG_OSC_OSC_16M_CTRL_RC_16M_CONTROL_MODE | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << ANADIG_OSC_OSC_16M_CTRL_RC_16M_CONTROL_MODE_SHIFT)) & ANADIG_OSC_OSC_16M_CTRL_RC_16M_CONTROL_MODE_MASK) |
RC_16M_CONTROL_MODE - Control Mode for 16MHz Oscillator 0b0..Software mode (default) 0b1..GPC mode (Setpoint)
| #define ANADIG_OSC_OSC_16M_CTRL_SOURCE_SEL_16M | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << ANADIG_OSC_OSC_16M_CTRL_SOURCE_SEL_16M_SHIFT)) & ANADIG_OSC_OSC_16M_CTRL_SOURCE_SEL_16M_MASK) |
SOURCE_SEL_16M - Source select 0b0..16MHz Oscillator 0b1..24MHz Oscillator
| #define ANADIG_OSC_OSC_24M_CTRL_BYPASS_CLK | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << ANADIG_OSC_OSC_24M_CTRL_BYPASS_CLK_SHIFT)) & ANADIG_OSC_OSC_24M_CTRL_BYPASS_CLK_MASK) |
BYPASS_CLK - 24MHz OSC Bypass Clock
| #define ANADIG_OSC_OSC_24M_CTRL_BYPASS_EN | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << ANADIG_OSC_OSC_24M_CTRL_BYPASS_EN_SHIFT)) & ANADIG_OSC_OSC_24M_CTRL_BYPASS_EN_MASK) |
BYPASS_EN - 24MHz OSC Bypass Enable 0b0..Disable 0b1..Enable
| #define ANADIG_OSC_OSC_24M_CTRL_LP_EN | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << ANADIG_OSC_OSC_24M_CTRL_LP_EN_SHIFT)) & ANADIG_OSC_OSC_24M_CTRL_LP_EN_MASK) |
LP_EN - 24MHz OSC Low-Power Mode Enable 0b0..High Gain mode (HP) 0b1..Low-power mode (LP)
| #define ANADIG_OSC_OSC_24M_CTRL_OSC_24M_CONTROL_MODE | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << ANADIG_OSC_OSC_24M_CTRL_OSC_24M_CONTROL_MODE_SHIFT)) & ANADIG_OSC_OSC_24M_CTRL_OSC_24M_CONTROL_MODE_MASK) |
OSC_24M_CONTROL_MODE - 24MHz OSC Control Mode 0b0..Software mode (default) 0b1..GPC mode (Setpoint)
| #define ANADIG_OSC_OSC_24M_CTRL_OSC_24M_GATE | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << ANADIG_OSC_OSC_24M_CTRL_OSC_24M_GATE_SHIFT)) & ANADIG_OSC_OSC_24M_CTRL_OSC_24M_GATE_MASK) |
OSC_24M_GATE - 24MHz OSC Gate Control 0b0..Not Gated 0b1..Gated
| #define ANADIG_OSC_OSC_24M_CTRL_OSC_24M_STABLE | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << ANADIG_OSC_OSC_24M_CTRL_OSC_24M_STABLE_SHIFT)) & ANADIG_OSC_OSC_24M_CTRL_OSC_24M_STABLE_MASK) |
OSC_24M_STABLE - 24MHz OSC Stable 0b0..Not Stable 0b1..Stable
| #define ANADIG_OSC_OSC_24M_CTRL_OSC_COMP_MODE | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << ANADIG_OSC_OSC_24M_CTRL_OSC_COMP_MODE_SHIFT)) & ANADIG_OSC_OSC_24M_CTRL_OSC_COMP_MODE_MASK) |
OSC_COMP_MODE - 24MHz OSC Comparator Mode 0b0..Single-ended mode (default) 0b1..Differential mode (test mode)
| #define ANADIG_OSC_OSC_24M_CTRL_OSC_EN | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << ANADIG_OSC_OSC_24M_CTRL_OSC_EN_SHIFT)) & ANADIG_OSC_OSC_24M_CTRL_OSC_EN_MASK) |
OSC_EN - 24MHz OSC Enable 0b0..Disable 0b1..Enable
| #define ANADIG_OSC_OSC_400M_CTRL0_OSC400M_AI_BUSY | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << ANADIG_OSC_OSC_400M_CTRL0_OSC400M_AI_BUSY_SHIFT)) & ANADIG_OSC_OSC_400M_CTRL0_OSC400M_AI_BUSY_MASK) |
OSC400M_AI_BUSY - 400MHz OSC AI BUSY
| #define ANADIG_OSC_OSC_400M_CTRL1_CLKGATE_400MEG | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << ANADIG_OSC_OSC_400M_CTRL1_CLKGATE_400MEG_SHIFT)) & ANADIG_OSC_OSC_400M_CTRL1_CLKGATE_400MEG_MASK) |
CLKGATE_400MEG - Clock gate control for 400MHz RCOSC 0b0..Not Gated 0b1..Gated
| #define ANADIG_OSC_OSC_400M_CTRL1_PWD | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << ANADIG_OSC_OSC_400M_CTRL1_PWD_SHIFT)) & ANADIG_OSC_OSC_400M_CTRL1_PWD_MASK) |
PWD - Power down control for 400MHz RCOSC 0b0..No Power down 0b1..Power down
| #define ANADIG_OSC_OSC_400M_CTRL1_RC_400M_CONTROL_MODE | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << ANADIG_OSC_OSC_400M_CTRL1_RC_400M_CONTROL_MODE_SHIFT)) & ANADIG_OSC_OSC_400M_CTRL1_RC_400M_CONTROL_MODE_MASK) |
RC_400M_CONTROL_MODE - 400MHz RCOSC Control mode 0b0..Software mode (default) 0b1..GPC mode (Setpoint)
| #define ANADIG_OSC_OSC_400M_CTRL2_ENABLE_CLK | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << ANADIG_OSC_OSC_400M_CTRL2_ENABLE_CLK_SHIFT)) & ANADIG_OSC_OSC_400M_CTRL2_ENABLE_CLK_MASK) |
ENABLE_CLK - Clock enable 0b0..Clock is disabled before entering GPC mode 0b1..Clock is enabled before entering GPC mode
| #define ANADIG_OSC_OSC_400M_CTRL2_OSC_TUNE_VAL | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << ANADIG_OSC_OSC_400M_CTRL2_OSC_TUNE_VAL_SHIFT)) & ANADIG_OSC_OSC_400M_CTRL2_OSC_TUNE_VAL_MASK) |
OSC_TUNE_VAL - Oscillator Tune Value
| #define ANADIG_OSC_OSC_400M_CTRL2_TUNE_BYP | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << ANADIG_OSC_OSC_400M_CTRL2_TUNE_BYP_SHIFT)) & ANADIG_OSC_OSC_400M_CTRL2_TUNE_BYP_MASK) |
TUNE_BYP - Bypass tuning logic 0b0..Use the output of tuning logic to run the oscillator 0b1..Bypass the tuning logic and use the programmed OSC_TUNE_VAL to run the oscillator
| #define ANADIG_OSC_OSC_48M_CTRL_RC_48M_CONTROL_MODE | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << ANADIG_OSC_OSC_48M_CTRL_RC_48M_CONTROL_MODE_SHIFT)) & ANADIG_OSC_OSC_48M_CTRL_RC_48M_CONTROL_MODE_MASK) |
RC_48M_CONTROL_MODE - 48MHz RCOSC Control Mode 0b0..Software mode (default) 0b1..GPC mode (Setpoint)
| #define ANADIG_OSC_OSC_48M_CTRL_RC_48M_DIV2_CONTROL_MODE | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << ANADIG_OSC_OSC_48M_CTRL_RC_48M_DIV2_CONTROL_MODE_SHIFT)) & ANADIG_OSC_OSC_48M_CTRL_RC_48M_DIV2_CONTROL_MODE_MASK) |
RC_48M_DIV2_CONTROL_MODE - RCOSC_48M_DIV2 Control Mode 0b0..Software mode (default) 0b1..GPC mode (Setpoint)
| #define ANADIG_OSC_OSC_48M_CTRL_RC_48M_DIV2_EN | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << ANADIG_OSC_OSC_48M_CTRL_RC_48M_DIV2_EN_SHIFT)) & ANADIG_OSC_OSC_48M_CTRL_RC_48M_DIV2_EN_MASK) |
RC_48M_DIV2_EN - RCOSC_48M_DIV2 Enable 0b0..Disable 0b1..Enable
| #define ANADIG_OSC_OSC_48M_CTRL_TEN | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << ANADIG_OSC_OSC_48M_CTRL_TEN_SHIFT)) & ANADIG_OSC_OSC_48M_CTRL_TEN_MASK) |
TEN - 48MHz RCOSC Enable 0b0..Power down 0b1..Power up
