RTEMS 6.2-rc3
#include <errno.h>#include <pthread.h>#include <rtems/score/percpu.h>#include <rtems/score/threadqimpl.h>Go to the source code of this file.
| struct | POSIX_Condition_variables_Control |
| #define | POSIX_CONDITION_VARIABLES_CLOCK_MONOTONIC 0x1UL |
| #define | POSIX_CONDITION_VARIABLES_FLAGS_MASK 0x1UL |
| #define | POSIX_CONDITION_VARIABLES_MAGIC 0x18dfb1feUL |
| #define | POSIX_CONDITION_VARIABLES_NO_MUTEX NULL |
| #define | POSIX_CONDITION_VARIABLES_TQ_OPERATIONS &_Thread_queue_Operations_FIFO |
| #define | POSIX_CONDITION_VARIABLE_OF_THREAD_QUEUE_QUEUE(queue) |
| #define | POSIX_CONDITION_VARIABLES_VALIDATE_OBJECT(the_cond, flags) |
| int | _POSIX_Condition_variables_Signal_support (pthread_cond_t *cond, bool is_broadcast) |
| Implements wake up version of the "signal" operation. | |
| int | _POSIX_Condition_variables_Wait_support (pthread_cond_t *cond, pthread_mutex_t *mutex, const struct timespec *abstime) |
| POSIX condition variables wait support. | |
| bool | _POSIX_Condition_variables_Auto_initialization (POSIX_Condition_variables_Control *the_cond) |
| const pthread_condattr_t | _POSIX_Condition_variables_Default_attributes |
This include file contains the static inline implementation of the private inlined routines for POSIX condition variables.
| #define POSIX_CONDITION_VARIABLE_OF_THREAD_QUEUE_QUEUE | ( | queue | ) |
| #define POSIX_CONDITION_VARIABLES_NO_MUTEX NULL |
Constant to indicate condition variable does not currently have a mutex assigned to it.
| #define POSIX_CONDITION_VARIABLES_VALIDATE_OBJECT | ( | the_cond, | |
| flags | |||
| int _POSIX_Condition_variables_Signal_support | ( | pthread_cond_t * | cond, |
| bool | is_broadcast | ||
A support routine which implements guts of the broadcast and single task wake up version of the "signal" operation.
| int _POSIX_Condition_variables_Wait_support | ( | pthread_cond_t * | cond, |
| pthread_mutex_t * | mutex, | ||
| const struct timespec * | abstime | ||
A support routine which implements guts of the blocking, non-blocking, and timed wait version of condition variable wait routines.
extern |
The default condition variable attributes structure.
