RTEMS 6.2-rc2
This structure defines the GR740 I/0 and PLL Configuration register block memory map. More...
#include <gr740-iopll-regs.h>
Data Fields | |
| uint32_t | ftmfunc |
| See FTMCTRL function enable register (FTMFUNC). | |
| uint32_t | altfunc |
| See Alternative function enable register (ALTFUNC). | |
| uint32_t | lvdsmclk |
| See LVDS and memory clock pad enable register (LVDSMCLK). | |
| uint32_t | pllnewcfg |
| See PLL new configuration register (PLLNEWCFG). | |
| uint32_t | pllrecfg |
| See PLL reconfigure command register (PLLRECFG). | |
| uint32_t | pllcurcfg |
| See PLL current configuration register (PLLCURCFG). | |
| uint32_t | drvstr1 |
| See Drive strength configuration register 1 (DRVSTR1). | |
| uint32_t | drvstr2 |
| See Drive strength configuration register 2 (DRVSTR2). | |
| uint32_t | lockdown |
| See Configuration lockdown register (LOCKDOWN). | |
