RTEMS 6.2-rc2
Test context for spec:/rtems/timer/req/fire-when test case. More...
Data Fields | |
| rtems_id | timer_id |
| This member contains a valid id of a timer. | |
| rtems_id | id_param |
This member specifies the id parameter for the action. | |
| const rtems_time_of_day * | wall_time_param |
This member specifies the wall_time parameter for the action. | |
| rtems_timer_service_routine_entry | routine_param |
This member specifies the routine parameter for the action. | |
| rtems_status_code | status |
| This member contains the returned status code of the action. | |
| int | invocations |
| This member contains a counter of invocations of the Timer Service Routine. | |
| rtems_time_of_day | tod_till_fire |
| Function TriggerTimer() is used to figure out when the Timer Service Routine gets executed. This member contains the time-of-day when the Timer Service Routine fires (see fire). | |
| void * | routine_user_data |
| This member contains the user data given to the Timer Service Routine when called. | |
| PreConditionContext | pre_cond_contex |
| This member specifies which pre-condition context (none, interrupt context, server context) must be created before the rtems_timer_fire_when() action gets executed. | |
| const rtems_time_of_day * | pre_cond_tod |
| This member specifies the pre-condition state of the realtime clock. It should either be set to the value referenced by pre_cond_tod or if NULL, then the realtime clock should be not set. | |
| Timer_Classes | pre_class |
| This member stores internal clock and context settings of the timer before the execution of the test action. | |
| Timer_States | pre_state |
| This member stores the state of the timer before the execution of the test action. | |
| Timer_States | post_state |
| This member stores the state of the timer after the execution of the test action. | |
| Timer_Scheduling_Data | pre_scheduling_data |
| This member stores the scheduling data of the timer before the execution of the test action. | |
| Timer_Scheduling_Data | post_scheduling_data |
| This member stores the scheduling data of the timer after the execution of the test action. | |
| struct { | |
| size_t pcs [7] | |
| This member defines the pre-condition states for the next action. | |
| bool in_action_loop | |
| If this member is true, then the test action loop is executed. | |
| size_t index | |
| This member contains the next transition map index. | |
| RtemsTimerReqFireWhen_Entry entry | |
| This member contains the current transition map entry. | |
| bool skip | |
| If this member is true, then the current transition variant should be skipped. | |
| } | Map |
