RTEMS 6.2-rc2
Test context for spec:/rtems/task/req/resume test case. More...
Data Fields | |
| rtems_id | worker_id |
| This member contains the identifier of a task. | |
| bool | suspend |
| If this member is true, then the worker is suspended before the rtems_task_resume() call. | |
| rtems_status_code | status |
| This member contains the return value of the rtems_task_resume() call. | |
| rtems_id | id |
This member specifies if the id parameter value. | |
| struct { | |
| size_t pci [2] | |
| This member defines the pre-condition indices for the next action. | |
| size_t pcs [2] | |
| This member defines the pre-condition states for the next action. | |
| bool in_action_loop | |
| If this member is true, then the test action loop is executed. | |
| size_t index | |
| This member contains the next transition map index. | |
| RtemsTaskReqResume_Entry entry | |
| This member contains the current transition map entry. | |
| bool skip | |
| If this member is true, then the current transition variant should be skipped. | |
| } | Map |
