RTEMS 6.2-rc2
Test context for spec:/rtems/message/req/receive test case. More...
TQContext tq_ctx
 This member contains the thread queue test context.
rtems_attribute attribute_set
 This member specifies the attribute set of the message queue.
 storage_area [MAXIMUM_PENDING_MESSAGES]
 This member is used as storage area for the message queue.
uint32_t magic
 This member contains always the same arbitrary number magic.
uint8_t send_msg_counter
 This member contains a number which is sent as next message.
uint8_t receive_buffer [MAXIMUM_MESSAGE_SIZE]
 This member contains a buffer to receive messages from the queue.
size_t receive_size
 This member contains a buffer to receive the messages size.
rtems_id id_param
 This member specifies the id parameter for the action.
void * buffer_param
 This member specifies the buffer parameter for the action.
size_t * size_param
 This member specifies the size parameter for the action.
rtems_option option_set_param
 This member specifies the option_set parameter for the action.
rtems_interval timeout_param
 This member specifies the timeout parameter for the action.
rtems_status_code status
 This member contains the returned status code of the action.
uint32_t action_duration
 This member contains the duration of the action in ticks.
rtems_id task_id
 This member contains the task identifier of the main task.
rtems_id worker_id
 This member contains the task identifier of the worker task.
void(* concurrent_activity )(void *ctx_in)
 This member contains a pointer to a function which is executed while the worker is waiting to receive a message (delete(), nop()).
void(* check_msgq_unchanged )(void *ctx_in)
 This member contains a pointer to a function which is executed to check that the action has not changed the content of the message queue.
struct {
   size_t   pcs [8]
 This member defines the pre-condition states for the next action.
   bool   in_action_loop
 If this member is true, then the test action loop is executed.
   size_t   index
 This member contains the next transition map index.
   RtemsMessageReqReceive_Entry   entry
 This member contains the current transition map entry.
   bool   skip
 If this member is true, then the current transition variant should be skipped.
Map
Field Documentation
◆ magic
uint32_t RtemsMessageReqReceive_Context::magic
It is used for run-time type checking.
