RTEMS 6.2-rc2
Used for passing and retrieving registers content to/from real mode interrupt call. More...
#include <realmode_int.h>
Data Fields | |
| uint32_t | reg_eax |
| uint32_t | reg_ebx |
| uint32_t | reg_ecx |
| uint32_t | reg_edx |
| uint32_t | reg_esi |
| uint32_t | reg_edi |
| uint16_t | reg_ds |
| uint16_t | reg_es |
| uint16_t | reg_fs |
| uint16_t | reg_gs |
| uint16_t | offset |
| Offset to segment described by selector. | |
| uint16_t | selector |
| Selector or Segment depending on whether this is used from 16bit protected mode or from real mode. | |
| uint8_t | Signature [4] |
| uint16_t | EntryPoint |
| uint16_t | PMInitialize |
| uint16_t | BIOSDataSel |
| uint16_t | A0000Sel |
| uint16_t | B0000Sel |
| uint16_t | B8000Sel |
| uint16_t | CodeSegSel |
| uint8_t | InProtectMode |
| uint8_t | Checksum |
| uint8_t | VbeSignature [4] |
| uint16_t | VbeVersion |
| uint8_t * | OemStringPtr |
| uint8_t | Capabilities [4] |
| uint32_t * | VideoModePtr |
| uint16_t | TotalMemory |
| uint16_t | OemSoftwareRev |
| uint8_t * | OemVendorNamePtr |
| uint8_t * | OemProductNamePtr |
| uint8_t * | OemProductRevPtr |
| uint8_t | Reserved [222] |
| uint8_t | OemData [256] |
| uint16_t | ModeAttributes |
| uint8_t | WinAAttributes |
| uint8_t | WinBAttributes |
| uint16_t | WinGranularity |
| uint16_t | WinSize |
| uint16_t | WinASegment |
| uint16_t | WinBSegment |
| uint32_t * | WinFuncPtr |
| uint16_t | BytesPerScanLine |
| uint16_t | XResolution |
| uint16_t | YResolution |
| uint8_t | XCharSize |
| uint8_t | YCharSize |
| uint8_t | NumberOfPlanes |
| uint8_t | BitsPerPixel |
| uint8_t | NumberOfBanks |
| uint8_t | MemoryModel |
| uint8_t | BankSize |
| uint8_t | NumberOfImagePages |
| uint8_t | Reserved0 |
| uint8_t | RedMaskSize |
| uint8_t | RedFieldPosition |
| uint8_t | GreenMaskSize |
| uint8_t | GreenFieldPosition |
| uint8_t | BlueMaskSize |
| uint8_t | BlueFieldPosition |
| uint8_t | RsvdMaskSize |
| uint8_t | RsvdFieldPosition |
| uint8_t | DirectColorModeInfo |
| uint32_t * | PhysBasePtr |
| uint32_t | Reserved1 |
| uint16_t | Reserved2 |
| uint16_t | LinBytesPerScanLine |
| uint8_t | BnkNumberOfImagePages |
| uint8_t | LinNumberOfImagePages |
| uint8_t | LinRedMaskSize |
| uint8_t | LinRedFieldPosition |
| uint8_t | LinGreenMaskSize |
| uint8_t | LinGreenFieldPosition |
| uint8_t | LinBlueMaskSize |
| uint8_t | LinBlueFieldPosition |
| uint8_t | LinRsvdMaskSize |
| uint8_t | LinRsvdFieldPosition |
| uint32_t | MaxPixelClock |
| uint8_t | Reserved3 [189] |
| uint16_t | HorizontalTotal |
| uint16_t | HorizontalSyncStart |
| uint16_t | HorizontalSyncEnd |
| uint16_t | VerticalTotal |
| uint16_t | VerticalSyncStart |
| uint16_t | VerticalSyncEnd |
| uint8_t | Flags |
| uint32_t | PixelClock |
| uint16_t | RefreshRate |
| uint8_t | Blue |
| uint8_t | Green |
| uint8_t | Red |
| uint8_t | Alignment |
| uint8_t | SupVbeSignature [7] |
| uint16_t | SupVbeVersion |
| uint8_t | SupVbeSubFunc [8] |
| uint8_t | PixelClock_div10000 [2] |
| uint8_t | HorizontalActiveLow |
| uint8_t | HorizontalBlankingLow |
| uint8_t | HorizontalBlanking_ActiveHigh |
| uint8_t | VerticalActiveLow |
| uint8_t | VerticalBlankingLow |
| uint8_t | VerticalBlanking_ActiveHigh |
| uint8_t | HorizontalSyncOffsetLow |
| uint8_t | HorizontalSyncPulseWidthLow |
| uint8_t | VerticalSyncPulseWidth_OffsetLow |
| uint8_t | Vert_Hor_SyncPulseWidth_Offset_High |
| uint8_t | HorizontalImageSizeLow |
| uint8_t | VerticalImageSizeLow |
| uint8_t | Vertical_HorizontalImageSizeHigh |
| uint8_t | HorizontalBorder |
| uint8_t | VerticalBorder |
| uint8_t | ColorPointWhitePointIndexNumber |
| uint8_t | ColorPointWhiteLowBits |
| uint8_t | ColorPointWhite_x |
| uint8_t | ColorPointWhite_y |
| uint8_t | ColorPointWhiteGamma |
| uint8_t | MinVerticalRateInHz |
| uint8_t | MaxVerticalRateInHz |
| uint8_t | MinHorizontalInKHz |
| uint8_t | MaxHorizontalInKHz |
| uint8_t | MaxSupportedPixelClockIn10MHz |
| uint8_t | GTFStandard [8] |
| uint8_t | AddressableLinesLow |
| uint8_t | AspectRatio_AddressableLinesHigh |
| uint8_t | VerticalRate_PreferredVerticalRate |
| uint8_t | VersionNumber |
| EDID_CVT_3_byte_code_descriptor | cvt [4] |
| uint8_t | RevisionNumber |
| uint8_t | EST_III [12] |
| uint8_t | Flag0 [2] |
| uint8_t | Flag1 |
| uint8_t | DataTypeTag |
| uint8_t | Flag2 |
| uint8_t | DescriptorData [13] |
| uint8_t | HorizontalActivePixels |
| uint8_t | ImageAspectRatio_RefreshRate |
| uint8_t | Header [8] |
| uint8_t | IDManufacturerName [2] |
| uint8_t | IDProductCode [2] |
| uint8_t | IDSerialNumber [4] |
| uint8_t | WeekofManufacture |
| uint8_t | YearofManufacture |
| uint8_t | Version |
| uint8_t | Revision |
| uint8_t | VideoInputDefinition |
| uint8_t | MaxHorizontalImageSize |
| uint8_t | MaxVerticalImageSize |
| uint8_t | DisplayTransferCharacteristic |
| uint8_t | Features |
| uint8_t | GreenRedLow |
| uint8_t | WhiteBlueLow |
| uint8_t | RedXHigh |
| uint8_t | RedYHigh |
| uint8_t | GreenXHigh |
| uint8_t | GreenYHigh |
| uint8_t | BlueXHigh |
| uint8_t | BlueYHigh |
| uint8_t | WhiteXHigh |
| uint8_t | WhiteYHigh |
| uint8_t | EST_I_II_Man [3] |
| EDID_standard_timing_identification | STI [8] |
| union EDID_DTD_MD | dtd_md [4] |
| uint8_t | ExtensionFlag |
| i386_realmode_interrupt_registers | inoutregs |
| uint32_t | pm_esp_bkp |
| uint16_t | pm_ss_bkp |
| uint16_t | ds_bkp |
| uint16_t | rm_entry |
| uint16_t | rm_code_segment |
| uint32_t | pm_entry |
| uint16_t | pm_code_selector |
| uint16_t | idtr_lim_bkp |
| uint32_t | idtr_base_bkp |
| uint16_t | es_bkp |
| uint16_t | fs_bkp |
| uint16_t | gs_bkp |
| uint32_t | rml_entry |
| uint16_t | rml_code_selector |
| uint16_t | rml_data_selector |
| uint16_t | rm_stack_segment |
| uint16_t | rm_stack_pointer |
| uint16_t | rm_data_segment |
| uint16_t | limit_low |
| uint16_t | base_low |
| uint8_t | base_middle |
| uint8_t | access |
| uint8_t | gran_limit_middle |
| uint8_t | base_high |
| uint16_t | size |
| uint64_t | addr |
| uint32_t | format |
| uint32_t | magic |
| rtems_record_item | Version |
| rtems_record_item | Processor_maximum |
| rtems_record_item | Count |
| rtems_record_item | Frequency |
| rtems_record_item | Info [64] |
| unsigned int | limit_15_0: 16 |
| unsigned int | base_address_15_0: 16 |
| unsigned int | base_address_23_16: 8 |
| unsigned int | type: 4 |
| unsigned int | descriptor_type: 1 |
| unsigned int | privilege: 2 |
| unsigned int | present: 1 |
| unsigned int | limit_19_16: 4 |
| unsigned int | available: 1 |
| unsigned int | fixed_value_bits: 1 |
| unsigned int | operation_size: 1 |
| unsigned int | granularity: 1 |
| unsigned int | base_address_31_24: 8 |
describes one entry of Global/Local Descriptor Table
backup values, pointers/parameters accessible in protected mode
parameters, results, backup values accessible in real mode
Supplemental VBE info block.
Describes palette entry.
Describes monitor synchronization.
Describes graphic's mode parameter.
Information about VBE implementation.
Protected mode info block as defined by VBE standard.
Far pointer as defined by VBE standard.
warning: taking address of packed member of 'struct <anonymous>' may result in an unaligned pointer value [-Waddress-of-packed-member]
Disable the warning.
| uint16_t RTEMS_PACKED::A0000Sel |
Selector to access A0000h physical memmory
| uint8_t RTEMS_PACKED::Alignment |
DWORD alignment byte (unused)
| uint16_t RTEMS_PACKED::B0000Sel |
Selector to access B0000h physical memmory
| uint16_t RTEMS_PACKED::B8000Sel |
Selector to access B8000h physical memmory
| uint8_t RTEMS_PACKED::BankSize |
bank size in KB
| uint16_t RTEMS_PACKED::BIOSDataSel |
Selector to BIOS data area emulation block
| uint8_t RTEMS_PACKED::BitsPerPixel |
bits per pixel
| uint8_t RTEMS_PACKED::Blue |
Blue channel value (6 or 8 bits)
| uint8_t RTEMS_PACKED::BlueFieldPosition |
bit position of lsb of blue mask
| uint8_t RTEMS_PACKED::BlueMaskSize |
size of direct color blue mask in b
| uint8_t RTEMS_PACKED::BnkNumberOfImagePages |
number of images for banked modes
| uint16_t RTEMS_PACKED::BytesPerScanLine |
bytes per scan line
| uint8_t RTEMS_PACKED::Capabilities[4] |
Capabilities of graphics controller
| uint8_t RTEMS_PACKED::Checksum |
Checksum byte for structure. Sum over all structure bytes gives 0.
| uint16_t RTEMS_PACKED::CodeSegSel |
Selector to access code segment as data
| uint8_t RTEMS_PACKED::DirectColorModeInfo |
direct color mode attributes
| uint16_t RTEMS_PACKED::ds_bkp |
spot for back up of protected mode data selector
| uint16_t RTEMS_PACKED::EntryPoint |
Offset of PM entry point within BIOS
| uint16_t RTEMS_PACKED::es_bkp |
spot to backup of ES register value in 32bit protected mode
| uint8_t RTEMS_PACKED::Flags |
Flags (Interlaced, Double Scan etc)
| uint16_t RTEMS_PACKED::fs_bkp |
spot to backup of FS register value in 32bit protected mode
| uint8_t RTEMS_PACKED::Green |
Green channel value (6 or 8 bits)
| uint8_t RTEMS_PACKED::GreenFieldPosition |
bit position of lsb of green mask
| uint8_t RTEMS_PACKED::GreenMaskSize |
size of direct color green mask in b
| uint16_t RTEMS_PACKED::gs_bkp |
spot to backup of GS register value in 32bit protected mode
| uint16_t RTEMS_PACKED::HorizontalSyncEnd |
Horizontal sync end in pixels
| uint16_t RTEMS_PACKED::HorizontalSyncStart |
Horizontal sync start in pixels
| uint16_t RTEMS_PACKED::HorizontalTotal |
Horizontal total in pixels
| uint32_t RTEMS_PACKED::idtr_base_bkp |
| uint16_t RTEMS_PACKED::idtr_lim_bkp |
spot for backup protected mode interrupt descriptor table register
| uint8_t RTEMS_PACKED::InProtectMode |
Set to 1 when in protected mode
| uint8_t RTEMS_PACKED::LinBlueFieldPosition |
| uint8_t RTEMS_PACKED::LinBlueMaskSize |
| uint16_t RTEMS_PACKED::LinBytesPerScanLine |
bytes per scan line for linear modes
| uint8_t RTEMS_PACKED::LinGreenFieldPosition |
| uint8_t RTEMS_PACKED::LinGreenMaskSize |
| uint8_t RTEMS_PACKED::LinNumberOfImagePages |
number of images for linear modes
| uint8_t RTEMS_PACKED::LinRedFieldPosition |
bit position of lsb of red mask
| uint8_t RTEMS_PACKED::LinRedMaskSize |
size of direct color red mask
| uint8_t RTEMS_PACKED::LinRsvdFieldPosition |
bit position of lsb of reserved mask
| uint8_t RTEMS_PACKED::LinRsvdMaskSize |
size of direct color reserved mask
| uint32_t RTEMS_PACKED::MaxPixelClock |
maximum pixel clock (in Hz) for graphics mode
| uint8_t RTEMS_PACKED::MemoryModel |
memory model type
| uint16_t RTEMS_PACKED::ModeAttributes |
mode attributes
| uint8_t RTEMS_PACKED::NumberOfBanks |
number of banks
| uint8_t RTEMS_PACKED::NumberOfImagePages |
number of images
| uint8_t RTEMS_PACKED::NumberOfPlanes |
number of memory planes
| uint8_t RTEMS_PACKED::OemData[256] |
Data Area for OEM Strings
| uint8_t * RTEMS_PACKED::OemProductNamePtr |
VBE_far_pointer to Product Name String
| uint8_t * RTEMS_PACKED::OemProductRevPtr |
VBE_far_pointer to Product Revision String
| uint16_t RTEMS_PACKED::OemSoftwareRev |
VBE implementation Software revision
OEM Software revision
| uint8_t * RTEMS_PACKED::OemStringPtr |
VBE_far_pointer to OEM String
| uint8_t * RTEMS_PACKED::OemVendorNamePtr |
VBE_far_pointer to Vendor Name String
| uint32_t* RTEMS_PACKED::PhysBasePtr |
physical address for flat memory frame buffer
| uint32_t RTEMS_PACKED::PixelClock |
Pixel clock in units of Hz
| uint16_t RTEMS_PACKED::pm_code_selector |
returning selector for long indirect jump back to 32bit protected mode
| uint32_t RTEMS_PACKED::pm_entry |
returning offset for long indirect jump back to 32bit protected mode
| uint32_t RTEMS_PACKED::pm_esp_bkp |
spot for back up of protected mode stack pointer
| uint16_t RTEMS_PACKED::pm_ss_bkp |
spot for back up of protected mode stack selector
| uint16_t RTEMS_PACKED::PMInitialize |
Offset of PM initialization entry point
| uint8_t RTEMS_PACKED::Red |
Red channel value(6 or 8 bits)
| uint8_t RTEMS_PACKED::RedFieldPosition |
| uint8_t RTEMS_PACKED::RedMaskSize |
size of direct color red mask in bits
| uint16_t RTEMS_PACKED::RefreshRate |
Refresh rate in units of 0.01 Hz
| uint8_t RTEMS_PACKED::Reserved |
Reserved for VBE implementation scratch
remainder of VBE_mode_info_block
Reserved for description strings and future expansion
| uint8_t RTEMS_PACKED::Reserved0 |
reserved for page function
| uint32_t RTEMS_PACKED::Reserved1 |
Reserved - always set to 0
| uint16_t RTEMS_PACKED::Reserved2 |
| uint8_t RTEMS_PACKED::Reserved3[189] |
| uint16_t RTEMS_PACKED::rm_code_segment |
spot for setting up long indirect jump segment to real mode from 16bit protected mode
| uint16_t RTEMS_PACKED::rm_data_segment |
data segment for real mode
| uint16_t RTEMS_PACKED::rm_entry |
spot for setting up long indirect jump offset to real mode from 16bit protected mode
| uint16_t RTEMS_PACKED::rm_stack_pointer |
| uint16_t RTEMS_PACKED::rm_stack_segment |
values determinig location of real mode stack
| uint16_t RTEMS_PACKED::rml_code_selector |
| uint16_t RTEMS_PACKED::rml_data_selector |
data selector for 16bit protected mode
| uint32_t RTEMS_PACKED::rml_entry |
values for indirect jump to 16bit protected mode
| uint8_t RTEMS_PACKED::RsvdFieldPosition |
| uint8_t RTEMS_PACKED::RsvdMaskSize |
| uint8_t RTEMS_PACKED::Signature[4] |
PM Info Block Signature
| uint8_t RTEMS_PACKED::SupVbeSignature[7] |
Supplemental VBE Signature
| uint8_t RTEMS_PACKED::SupVbeSubFunc[8] |
Bitfield of supported subfunctions
| uint16_t RTEMS_PACKED::SupVbeVersion |
Supplemental VBE Version
| uint16_t RTEMS_PACKED::TotalMemory |
Number of 64kb memory blocks
| uint8_t RTEMS_PACKED::VbeSignature[4] |
VBE Signature
| uint16_t RTEMS_PACKED::VbeVersion |
VBE Version
| uint16_t RTEMS_PACKED::VerticalSyncEnd |
Vertical sync end in lines
| uint16_t RTEMS_PACKED::VerticalSyncStart |
Vertical sync start in lines
| uint16_t RTEMS_PACKED::VerticalTotal |
Vertical total in lines
| uint32_t* RTEMS_PACKED::VideoModePtr |
VBE_far_pointer to VideoModeList
| uint8_t RTEMS_PACKED::WinAAttributes |
window A attributes
| uint16_t RTEMS_PACKED::WinASegment |
window A start segment
| uint8_t RTEMS_PACKED::WinBAttributes |
window B attributes
| uint16_t RTEMS_PACKED::WinBSegment |
window B start segment
| uint32_t* RTEMS_PACKED::WinFuncPtr |
real mode pointer to window function
| uint16_t RTEMS_PACKED::WinGranularity |
window granularity
| uint16_t RTEMS_PACKED::WinSize |
window size
| uint8_t RTEMS_PACKED::XCharSize |
character cell width in pixels
| uint16_t RTEMS_PACKED::XResolution |
horizontal resolution in px or chars
| uint8_t RTEMS_PACKED::YCharSize |
character cell height in pixels
| uint16_t RTEMS_PACKED::YResolution |
vertical resolution in px or chars
