RTEMS 6.2-rc2
Test context for spec:/dev/clock/xil-ttc/val/fatal-irq-install test case. More...
Data Fields | |
| rtems_fatal_source | source |
| This member contains a copy of the corresponding DevClockXilTtcValFatalIrqInstall_Run() parameter. | |
| rtems_fatal_code | code |
