RTEMS 6.2-rc2
| struct | sai_edma_handle |
| SAI DMA transfer handle, users should not touch the content of the handle. More... | |
Driver version | |
| typedef struct sai_edma_handle | sai_edma_handle_t |
| typedef void(* | sai_edma_callback_t) (I2S_Type *base, sai_edma_handle_t *handle, status_t status, void *userData) |
| SAI eDMA transfer callback function for finish and error. | |
| #define | FSL_SAI_EDMA_DRIVER_VERSION (MAKE_VERSION(2, 5, 0)) |
eDMA Transactional | |
| void | SAI_TransferTxCreateHandleEDMA (I2S_Type *base, sai_edma_handle_t *handle, sai_edma_callback_t callback, void *userData, edma_handle_t *txDmaHandle) |
| Initializes the SAI eDMA handle. | |
| void | SAI_TransferRxCreateHandleEDMA (I2S_Type *base, sai_edma_handle_t *handle, sai_edma_callback_t callback, void *userData, edma_handle_t *rxDmaHandle) |
| Initializes the SAI Rx eDMA handle. | |
| void | SAI_TransferTxSetFormatEDMA (I2S_Type *base, sai_edma_handle_t *handle, sai_transfer_format_t *format, uint32_t mclkSourceClockHz, uint32_t bclkSourceClockHz) |
| Configures the SAI Tx audio format. | |
| void | SAI_TransferRxSetFormatEDMA (I2S_Type *base, sai_edma_handle_t *handle, sai_transfer_format_t *format, uint32_t mclkSourceClockHz, uint32_t bclkSourceClockHz) |
| Configures the SAI Rx audio format. | |
| void | SAI_TransferTxSetConfigEDMA (I2S_Type *base, sai_edma_handle_t *handle, sai_transceiver_t *saiConfig) |
| Configures the SAI Tx. | |
| void | SAI_TransferRxSetConfigEDMA (I2S_Type *base, sai_edma_handle_t *handle, sai_transceiver_t *saiConfig) |
| Configures the SAI Rx. | |
| status_t | SAI_TransferSendEDMA (I2S_Type *base, sai_edma_handle_t *handle, sai_transfer_t *xfer) |
| Performs a non-blocking SAI transfer using DMA. | |
| status_t | SAI_TransferReceiveEDMA (I2S_Type *base, sai_edma_handle_t *handle, sai_transfer_t *xfer) |
| Performs a non-blocking SAI receive using eDMA. | |
| status_t | SAI_TransferSendLoopEDMA (I2S_Type *base, sai_edma_handle_t *handle, sai_transfer_t *xfer, uint32_t loopTransferCount) |
| Performs a non-blocking SAI loop transfer using eDMA. | |
| status_t | SAI_TransferReceiveLoopEDMA (I2S_Type *base, sai_edma_handle_t *handle, sai_transfer_t *xfer, uint32_t loopTransferCount) |
| void | SAI_TransferTerminateSendEDMA (I2S_Type *base, sai_edma_handle_t *handle) |
| Terminate all SAI send. | |
| void | SAI_TransferTerminateReceiveEDMA (I2S_Type *base, sai_edma_handle_t *handle) |
| Terminate all SAI receive. | |
| void | SAI_TransferAbortSendEDMA (I2S_Type *base, sai_edma_handle_t *handle) |
| Aborts a SAI transfer using eDMA. | |
| void | SAI_TransferAbortReceiveEDMA (I2S_Type *base, sai_edma_handle_t *handle) |
| Aborts a SAI receive using eDMA. | |
| status_t | SAI_TransferGetSendCountEDMA (I2S_Type *base, sai_edma_handle_t *handle, size_t *count) |
| Gets byte count sent by SAI. | |
| status_t | SAI_TransferGetReceiveCountEDMA (I2S_Type *base, sai_edma_handle_t *handle, size_t *count) |
| Gets byte count received by SAI. | |
| uint32_t | SAI_TransferGetValidTransferSlotsEDMA (I2S_Type *base, sai_edma_handle_t *handle) |
| Gets valid transfer slot. | |
| #define FSL_SAI_EDMA_DRIVER_VERSION (MAKE_VERSION(2, 5, 0)) |
Version 2.5.0
| void SAI_TransferAbortReceiveEDMA | ( | I2S_Type * | base, |
| sai_edma_handle_t * | handle | ||
This function only aborts the current transfer slots, the other transfer slots' information still kept in the handler. If users want to terminate all transfer slots, just call SAI_TransferTerminateReceiveEDMA.
| base | SAI base pointer |
| handle | SAI eDMA handle pointer. |
brief Aborts a SAI receive using eDMA.
param base SAI base pointer. param handle SAI eDMA handle pointer.
| void SAI_TransferAbortSendEDMA | ( | I2S_Type * | base, |
This function only aborts the current transfer slots, the other transfer slots' information still kept in the handler. If users want to terminate all transfer slots, just call SAI_TransferTerminateSendEDMA.
| base | SAI base pointer. |
brief Aborts a SAI transfer using eDMA.
| status_t SAI_TransferGetReceiveCountEDMA | ( | I2S_Type * | base, |
| sai_edma_handle_t * | handle, | ||
| size_t * | count | ||
| count | Bytes count received by SAI. |
| kStatus_Success | Succeed get the transfer count. |
| kStatus_NoTransferInProgress | There is no non-blocking transaction in progress. |
brief Gets byte count received by SAI.
param base SAI base pointer param handle SAI eDMA handle pointer. param count Bytes count received by SAI. retval kStatus_Success Succeed get the transfer count. retval kStatus_NoTransferInProgress There is no non-blocking transaction in progress.
| status_t SAI_TransferGetSendCountEDMA | ( | I2S_Type * | base, |
| count | Bytes count sent by SAI. |
brief Gets byte count sent by SAI.
param base SAI base pointer. param handle SAI eDMA handle pointer. param count Bytes count sent by SAI. retval kStatus_Success Succeed get the transfer count. retval kStatus_NoTransferInProgress There is no non-blocking transaction in progress.
| uint32_t SAI_TransferGetValidTransferSlotsEDMA | ( | I2S_Type * | base, |
This function can be used to query the valid transfer request slot that the application can submit. It should be called in the critical section, that means the application could call it in the corresponding callback function or disable IRQ before calling it in the application, otherwise, the returned value may not correct.
| valid | slot count that application submit. |
@rief Gets valid transfer slot.
param base SAI base pointer param handle SAI eDMA handle pointer. retval valid slot count that application submit.
| status_t SAI_TransferReceiveEDMA | ( | I2S_Type * | base, |
| sai_transfer_t * | xfer | ||
This function support multi channel transfer,
| xfer | Pointer to DMA transfer structure. |
| kStatus_Success | Start a SAI eDMA receive successfully. |
| kStatus_InvalidArgument | The input argument is invalid. |
| kStatus_RxBusy | SAI is busy receiving data. |
brief Performs a non-blocking SAI receive using eDMA.
note This interface returns immediately after the transfer initiates. Call the SAI_GetReceiveRemainingBytes to poll the transfer status and check whether the SAI transfer is finished.
param base SAI base pointer param handle SAI eDMA handle pointer. param xfer Pointer to DMA transfer structure. retval kStatus_Success Start a SAI eDMA receive successfully. retval kStatus_InvalidArgument The input argument is invalid. retval kStatus_RxBusy SAI is busy receiving data.
| status_t SAI_TransferReceiveLoopEDMA | ( | I2S_Type * | base, |
| sai_transfer_t * | xfer, | ||
| uint32_t | loopTransferCount | ||
Once the loop transfer start, application can use function SAI_TransferAbortReceiveEDMA to stop the loop transfer.
| xfer | Pointer to the DMA transfer structure, should be a array with elements counts >=1(loopTransferCount). |
| loopTransferCount | the counts of xfer array. |
brief Performs a non-blocking SAI loop transfer using eDMA.
note This function support loop transfer only,such as A->B->...->A, application must be aware of that the more counts of the loop transfer, then more tcd memory required, as the function use the tcd pool in sai_edma_handle_t, so application could redefine the SAI_XFER_QUEUE_SIZE to determine the proper TCD pool size. This function support one sai channel only.
param base SAI base pointer. param handle SAI eDMA handle pointer. param xfer Pointer to the DMA transfer structure, should be a array with elements counts >=1(loopTransferCount). param loopTransferCount the counts of xfer array. retval kStatus_Success Start a SAI eDMA receive successfully. retval kStatus_InvalidArgument The input argument is invalid.
| void SAI_TransferRxCreateHandleEDMA | ( | I2S_Type * | base, |
| sai_edma_callback_t | callback, | ||
| void * | userData, | ||
| edma_handle_t * | rxDmaHandle | ||
This function initializes the SAI slave DMA handle, which can be used for other SAI master transactional APIs. Usually, for a specified SAI instance, call this API once to get the initialized handle.
| base | SAI peripheral base address. |
| callback | Pointer to user callback function. |
| userData | User parameter passed to the callback function. |
| rxDmaHandle | eDMA handle pointer, this handle shall be static allocated by users. |
brief Initializes the SAI Rx eDMA handle.
param base SAI base pointer. param handle SAI eDMA handle pointer. param base SAI peripheral base address. param callback Pointer to user callback function. param userData User parameter passed to the callback function. param dmaHandle eDMA handle pointer, this handle shall be static allocated by users.
| void SAI_TransferRxSetConfigEDMA | ( | I2S_Type * | base, |
| sai_transceiver_t * | saiConfig | ||
| saiConfig | sai configurations. |
brief Configures the SAI Rx.
note SAI eDMA supports data transfer in a multiple SAI channels if the FIFO Combine feature is supported. To activate the multi-channel transfer enable SAI channels by filling the channelMask of sai_transceiver_t with the corresponding values of _sai_channel_mask enum, enable the FIFO Combine mode by assigning kSAI_FifoCombineModeEnabledOnRead to the fifoCombine member of sai_fifo_combine_t which is a member of sai_transceiver_t. This is an example of multi-channel data transfer configuration step. code sai_transceiver_t config; SAI_GetClassicI2SConfig(&config, kSAI_WordWidth16bits, kSAI_Stereo, kSAI_Channel0Mask|kSAI_Channel1Mask); config.fifo.fifoCombine = kSAI_FifoCombineModeEnabledOnRead; SAI_TransferRxSetConfigEDMA(I2S0, &edmaHandle, &config); endcode param base SAI base pointer. param handle SAI eDMA handle pointer. param saiConfig sai configurations.
| void SAI_TransferRxSetFormatEDMA | ( | I2S_Type * | base, |
| sai_transfer_format_t * | format, | ||
| uint32_t | mclkSourceClockHz, | ||
| uint32_t | bclkSourceClockHz | ||
The audio format can be changed at run-time. This function configures the sample rate and audio data format to be transferred. This function also sets the eDMA parameter according to formatting requirements.
| format | Pointer to SAI audio data format structure. |
| mclkSourceClockHz | SAI master clock source frequency in Hz. |
| bclkSourceClockHz | SAI bit clock source frequency in Hz. If a bit clock source is the master clock, this value should equal to masterClockHz in format. |
| kStatus_Success | Audio format set successfully. |
brief Configures the SAI Rx audio format.
deprecated Do not use this function. It has been superceded by ref SAI_TransferRxSetConfigEDMA
param base SAI base pointer. param handle SAI eDMA handle pointer. param format Pointer to SAI audio data format structure. param mclkSourceClockHz SAI master clock source frequency in Hz. param bclkSourceClockHz SAI bit clock source frequency in Hz. If a bit clock source is the master clock, this value should equal to masterClockHz in format. retval kStatus_Success Audio format set successfully. retval kStatus_InvalidArgument The input argument is invalid.
| status_t SAI_TransferSendEDMA | ( | I2S_Type * | base, |
| xfer | Pointer to the DMA transfer structure. |
| kStatus_Success | Start a SAI eDMA send successfully. |
| kStatus_TxBusy | SAI is busy sending data. |
brief Performs a non-blocking SAI transfer using DMA.
note This interface returns immediately after the transfer initiates. Call SAI_GetTransferStatus to poll the transfer status and check whether the SAI transfer is finished.
param base SAI base pointer. param handle SAI eDMA handle pointer. param xfer Pointer to the DMA transfer structure. retval kStatus_Success Start a SAI eDMA send successfully. retval kStatus_InvalidArgument The input argument is invalid. retval kStatus_TxBusy SAI is busy sending data.
| status_t SAI_TransferSendLoopEDMA | ( | I2S_Type * | base, |
Once the loop transfer start, application can use function SAI_TransferAbortSendEDMA to stop the loop transfer.
param base SAI base pointer. param handle SAI eDMA handle pointer. param xfer Pointer to the DMA transfer structure, should be a array with elements counts >=1(loopTransferCount). param loopTransferCount the counts of xfer array. retval kStatus_Success Start a SAI eDMA send successfully. retval kStatus_InvalidArgument The input argument is invalid.
| void SAI_TransferTerminateReceiveEDMA | ( | I2S_Type * | base, |
This function will clear all transfer slots buffered in the sai queue. If users only want to abort the current transfer slot, please call SAI_TransferAbortReceiveEDMA.
brief Terminate all SAI receive.
| void SAI_TransferTerminateSendEDMA | ( | I2S_Type * | base, |
This function will clear all transfer slots buffered in the sai queue. If users only want to abort the current transfer slot, please call SAI_TransferAbortSendEDMA.
brief Terminate all SAI send.
| void SAI_TransferTxCreateHandleEDMA | ( | I2S_Type * | base, |
| edma_handle_t * | txDmaHandle | ||
This function initializes the SAI master DMA handle, which can be used for other SAI master transactional APIs. Usually, for a specified SAI instance, call this API once to get the initialized handle.
| txDmaHandle | eDMA handle pointer, this handle shall be static allocated by users. |
brief Initializes the SAI eDMA handle.
| void SAI_TransferTxSetConfigEDMA | ( | I2S_Type * | base, |
brief Configures the SAI Tx.
note SAI eDMA supports data transfer in a multiple SAI channels if the FIFO Combine feature is supported. To activate the multi-channel transfer enable SAI channels by filling the channelMask of sai_transceiver_t with the corresponding values of _sai_channel_mask enum, enable the FIFO Combine mode by assigning kSAI_FifoCombineModeEnabledOnWrite to the fifoCombine member of sai_fifo_combine_t which is a member of sai_transceiver_t. This is an example of multi-channel data transfer configuration step. code sai_transceiver_t config; SAI_GetClassicI2SConfig(&config, kSAI_WordWidth16bits, kSAI_Stereo, kSAI_Channel0Mask|kSAI_Channel1Mask); config.fifo.fifoCombine = kSAI_FifoCombineModeEnabledOnWrite; SAI_TransferTxSetConfigEDMA(I2S0, &edmaHandle, &config); endcode param base SAI base pointer. param handle SAI eDMA handle pointer. param saiConfig sai configurations.
| void SAI_TransferTxSetFormatEDMA | ( | I2S_Type * | base, |
| bclkSourceClockHz | SAI bit clock source frequency in Hz. If bit clock source is master clock, this value should equals to masterClockHz in format. |
brief Configures the SAI Tx audio format.
deprecated Do not use this function. It has been superceded by ref SAI_TransferTxSetConfigEDMA
param base SAI base pointer. param handle SAI eDMA handle pointer. param format Pointer to SAI audio data format structure. param mclkSourceClockHz SAI master clock source frequency in Hz. param bclkSourceClockHz SAI bit clock source frequency in Hz. If bit clock source is master clock, this value should equals to masterClockHz in format. retval kStatus_Success Audio format set successfully. retval kStatus_InvalidArgument The input argument is invalid.
