RTEMS 6.2-rc2
Region Manager
The Region Manager provides facilities to dynamically allocate memory in variable sized units. More...
rtems_status_code rtems_region_get_segment_size (rtems_id id, void *segment, uintptr_t *size)
 Gets the size of the region segment.
rtems_status_code rtems_region_create (rtems_name name, void *starting_address, uintptr_t length, uintptr_t page_size, rtems_attribute attribute_set, rtems_id *id)
 Creates a region.
rtems_status_code rtems_region_ident (rtems_name name, rtems_id *id)
 Identifies a region by the object name.
rtems_status_code rtems_region_delete (rtems_id id)
 Deletes the region.
rtems_status_code rtems_region_extend (rtems_id id, void *starting_address, uintptr_t length)
 Extends the region.
rtems_status_code rtems_region_get_segment (rtems_id id, uintptr_t size, rtems_option option_set, rtems_interval timeout, void **segment)
 Gets a segment from the region.
rtems_status_code rtems_region_return_segment (rtems_id id, void *segment)
 Returns the segment to the region.
rtems_status_code rtems_region_resize_segment (rtems_id id, void *segment, uintptr_t size, uintptr_t *old_size)
 Changes the size of the segment.
rtems_status_code rtems_region_get_information (rtems_id id, Heap_Information_block *the_info)
 Gets the region information.
rtems_status_code rtems_region_get_free_information (rtems_id id, Heap_Information_block *the_info)
 Gets the region free information.
◆ rtems_region_create()
rtems_status_code rtems_region_create ( rtems_name  name,
void *  starting_address,
uintptr_t  length,
rtems_id id
Creates a region.
Parameters
nameis the object name of the region.
starting_addressis the starting address of the memory area managed by the region.
lengthis the length in bytes of the memory area managed by the region.
page_sizeis the alignment of the starting address and length of each allocated segment of the region.
attribute_setis the attribute set of the region.
[out]idis the pointer to an rtems_id object. When the directive call is successful, the identifier of the created region will be stored in this object.
This directive creates a region which resides on the local node. The region has the user-defined object name specified in name. The assigned object identifier is returned in id. This identifier is used to access the region with other region related directives.
The region manages the contiguous memory area which starts at starting_address and is length bytes long. The memory area shall be large enough to contain some internal region administration data.
The starting address and length of segments allocated from the region will be an integral multiple of page_size. The specified page size will be aligned to an implementation-dependent minimum alignment if necessary.
The attribute set specified in attribute_set is built through a bitwise or of the attribute constants described below. Not all combinations of attributes are allowed. Some attributes are mutually exclusive. If mutually exclusive attributes are combined, the behaviour is undefined. Attributes not mentioned below are not evaluated by this directive and have no effect. Default attributes can be selected by using the RTEMS_DEFAULT_ATTRIBUTES constant.
The task wait queue discipline is selected by the mutually exclusive RTEMS_FIFO and RTEMS_PRIORITY attributes. The discipline defines the order in which tasks wait for allocatable segments on a currently empty region.
  • The FIFO discipline is the default and can be emphasized through use of the RTEMS_FIFO attribute.
  • The priority discipline is selected by the RTEMS_PRIORITY attribute.
Return values
RTEMS_SUCCESSFULThe requested operation was successful.
RTEMS_INVALID_NAMEThe name parameter was invalid.
RTEMS_INVALID_ADDRESSThe id parameter was NULL.
RTEMS_INVALID_ADDRESSThe starting_address parameter was NULL.
RTEMS_TOO_MANYThere was no inactive object available to create a region. The number of regions available to the application is configured through the CONFIGURE_MAXIMUM_REGIONS application configuration option.
RTEMS_INVALID_SIZEThe page_size parameter was invalid.
RTEMS_INVALID_SIZEThe memory area specified in starting_address and length was too small.
Notes
For control and maintenance of the region, RTEMS allocates a RNCB from the local RNCB free pool and initializes it.
Constraints
The following constraints apply to this directive:
  • The directive may be called from within device driver initialization context.
  • The directive may be called from within task context.
  • The directive may obtain and release the object allocator mutex. This may cause the calling task to be preempted.
  • The number of regions available to the application is configured through the CONFIGURE_MAXIMUM_REGIONS application configuration option.
  • Where the object class corresponding to the directive is configured to use unlimited objects, the directive may allocate memory from the RTEMS Workspace.
◆ rtems_region_delete()
rtems_status_code rtems_region_delete ( rtems_id  id)
Deletes the region.
Parameters
idis the region identifier.
This directive deletes the region specified by id.
Return values
RTEMS_INVALID_IDThere was no region associated with the identifier specified by id.
RTEMS_RESOURCE_IN_USEThere were segments of the region still in use.
Notes
The region cannot be deleted if any of its segments are still allocated.
The RNCB for the deleted region is reclaimed by RTEMS.
Constraints
  • The calling task does not have to be the task that created the object. Any local task that knows the object identifier can delete the object.
  • Where the object class corresponding to the directive is configured to use unlimited objects, the directive may free memory to the RTEMS Workspace.
◆ rtems_region_extend()
rtems_status_code rtems_region_extend ( rtems_id  id,
uintptr_t  length
Extends the region.
Parameters
starting_addressis the starting address of the memory area to extend the region.
lengthis the length in bytes of the memory area to extend the region.
This directive adds the memory area which starts at starting_address for length bytes to the region specified by id.
Return values
RTEMS_INVALID_ADDRESSThe memory area specified by starting_address and length was insufficient to extend the heap.
Notes
There are no alignment requirements for the memory area. The memory area must be big enough to contain some maintenance blocks. It must not overlap parts of the current heap memory areas. Disconnected memory areas added to the heap will lead to used blocks which cover the gaps. Extending with an inappropriate memory area will corrupt the heap resulting in undefined behaviour.
Constraints
◆ rtems_region_get_free_information()
rtems_status_code rtems_region_get_free_information ( rtems_id  id,
Heap_Information_block the_info
Parameters
[out]the_infois the pointer to a Heap_Information_block object. When the directive call is successful, the free information of the region will be stored in this object.
This directive is used to obtain information about the free memory in the region specified by id. This is a snapshot at the time of the call. The information will be returned in the structure pointed to by the_info.
Return values
RTEMS_INVALID_ADDRESSThe the_info parameter was NULL.
Notes
This directive uses the same structure to return information as the rtems_region_get_information() directive but does not fill in the used information.
This is primarily intended as a mechanism to obtain diagnostic information. This directive performs an O(n) scan of the free blocks in the region to calculate the information provided. Given that the execution time is driven by the number of used and free blocks, it can take a non-deterministic time to execute. Typically, there are many used blocks and a much smaller number of free blocks making a call to this directive less expensive than a call to rtems_region_get_information().
Constraints
◆ rtems_region_get_information()
rtems_status_code rtems_region_get_information ( rtems_id  id,
Parameters
[out]the_infois the pointer to a Heap_Information_block object. When the directive call is successful, the information of the region will be stored in this object.
This directive is used to obtain information about the used and free memory in the region specified by id. This is a snapshot at the time of the call. The information will be returned in the structure pointed to by the_info.
Return values
Notes
This is primarily intended as a mechanism to obtain diagnostic information. This directive performs an O(n) scan of the free and an O(n) scan of the used blocks in the region to calculate the information provided. Given that the execution time is driven by the number of used and free blocks, it can take a non-deterministic time to execute.
To get only the free information of the region use rtems_region_get_free_information().
Constraints
◆ rtems_region_get_segment()
rtems_status_code rtems_region_get_segment ( rtems_id  id,
uintptr_t  size,
void **  segment
Parameters
sizeis the size in bytes of the segment to allocate.
option_setis the option set.
timeoutis the timeout in clock ticks if the RTEMS_WAIT option is set. Use RTEMS_NO_TIMEOUT to wait potentially forever.
[out]segmentis the pointer to a void pointer object. When the directive call is successful, the begin address of the allocated segment will be stored in this object.
This directive gets a segment from the region specified by id.
The option set specified in option_set is built through a bitwise or of the option constants described below. Not all combinations of options are allowed. Some options are mutually exclusive. If mutually exclusive options are combined, the behaviour is undefined. Options not mentioned below are not evaluated by this directive and have no effect. Default options can be selected by using the RTEMS_DEFAULT_OPTIONS constant.
The calling task can wait or try to get a segment from the region according to the mutually exclusive RTEMS_WAIT and RTEMS_NO_WAIT options.
  • Waiting to get a segment from the region is the default and can be emphasized through the use of the RTEMS_WAIT option. The timeout parameter defines how long the calling task is willing to wait. Use RTEMS_NO_TIMEOUT to wait potentially forever, otherwise set a timeout interval in clock ticks.
  • Trying to get a segment from the region is selected by the RTEMS_NO_WAIT option. If this option is defined, then the timeout parameter is ignored. When a segment from the region cannot be immediately allocated, then the RTEMS_UNSATISFIED status is returned.
With either RTEMS_WAIT or RTEMS_NO_WAIT if there is a segment of the requested size is available, then it is returned in segment and this directive returns immediately with the RTEMS_SUCCESSFUL status code.
If the calling task chooses to return immediately and the region has no segment of the requested size available, then the directive returns immediately with the RTEMS_UNSATISFIED status code. If the calling task chooses to wait for a segment, then the calling task is placed on the region wait queue and blocked. If the region was created with the RTEMS_PRIORITY option specified, then the calling task is inserted into the wait queue according to its priority. But, if the region was created with the RTEMS_FIFO option specified, then the calling task is placed at the rear of the wait queue.
Return values
RTEMS_INVALID_ADDRESSThe segment parameter was NULL.
RTEMS_INVALID_SIZEThe size parameter was zero.
RTEMS_INVALID_SIZEThe size parameter exceeded the maximum segment size which is possible for the region.
RTEMS_UNSATISFIEDThe region had no segment of the requested size immediately available.
RTEMS_TIMEOUTThe timeout happened while the calling task was waiting to get a segment from the region.
Notes
The actual length of the allocated segment may be larger than the requested size because a segment size is always a multiple of the region's page size.
Constraints
  • When the request cannot be immediately satisfied and the RTEMS_WAIT option is set, the calling task blocks at some point during the directive call.
  • The timeout functionality of the directive requires a clock tick.
◆ rtems_region_get_segment_size()
rtems_status_code rtems_region_get_segment_size ( rtems_id  id,
void *  segment,
uintptr_t *  size
Parameters
segmentis the begin address of the segment.
[out]sizeis the pointer to a uintptr_t object. When the directive call is successful, the size of the segment in bytes will be stored in this object.
This directive obtains the size in bytes of the segment specified by segment of the region specified by id in size.
Return values
RTEMS_INVALID_ADDRESSThe size parameter was NULL.
RTEMS_INVALID_ADDRESSThe segment was not within the region.
Notes
Constraints
◆ rtems_region_ident()
rtems_status_code rtems_region_ident ( rtems_name  name,
rtems_id id
Parameters
nameis the object name to look up.
[out]idis the pointer to an rtems_id object. When the directive call is successful, the object identifier of an object with the specified name will be stored in this object.
This directive obtains a region identifier associated with the region name specified in name.
Return values
RTEMS_INVALID_NAMEThe name parameter was 0.
RTEMS_INVALID_NAMEThere was no object with the specified name on the local node.
Notes
If the region name is not unique, then the region identifier will match the first region with that name in the search order. However, this region identifier is not guaranteed to correspond to the desired region.
The objects are searched from lowest to the highest index. Only the local node is searched.
The region identifier is used with other region related directives to access the region.
Constraints
  • The directive may be called from within any runtime context.
  • The directive will not cause the calling task to be preempted.
◆ rtems_region_resize_segment()
rtems_status_code rtems_region_resize_segment ( rtems_id  id,
void *  segment,
uintptr_t  size,
uintptr_t *  old_size
Parameters
segmentis the begin address of the segment to resize.
sizeis the requested new size of the segment.
[out]old_sizeis the pointer to an uintptr_t object. When the directive call is successful, the old size of the segment will be stored in this object.
This directive is used to increase or decrease the size of the segment of the region specified by id. When increasing the size of a segment, it is possible that there is no memory available contiguous to the segment. In this case, the request is unsatisfied.
Return values
RTEMS_INVALID_ADDRESSThe old_size parameter was NULL.
RTEMS_UNSATISFIEDThe region was unable to resize the segment.
Notes
If an attempt to increase the size of a segment fails, then the application may want to allocate a new segment of the desired size, copy the contents of the original segment to the new, larger segment and then return the original segment.
Constraints
◆ rtems_region_return_segment()
rtems_status_code rtems_region_return_segment ( rtems_id  id,
void *  segment
Parameters
segmentis the begin address of the segment to return.
This directive returns the segment specified by segment to the region specified by id. The returned segment is merged with its neighbors to form the largest possible segment. The first task on the wait queue is examined to determine if its segment request can now be satisfied. If so, it is given a segment and unblocked. This process is repeated until the first task's segment request cannot be satisfied.
Return values
Notes
This directive will cause the calling task to be preempted if one or more local tasks are waiting for a segment and the following conditions exist:
  • A waiting task has a higher priority than the calling task.
  • The size of the segment required by the waiting task is less than or equal to the size of the segment returned.
Constraints
  • The directive may unblock a task. This may cause the calling task to be preempted.
