RTEMS 6.2-rc2
| #define | __HAL_I2C_RESET_HANDLE_STATE(__HANDLE__) ((__HANDLE__)->State = HAL_I2C_STATE_RESET) |
| Reset I2C handle state. | |
| #define | __HAL_I2C_ENABLE_IT(__HANDLE__, __INTERRUPT__) ((__HANDLE__)->Instance->CR1 |= (__INTERRUPT__)) |
| Enable the specified I2C interrupt. | |
| #define | __HAL_I2C_DISABLE_IT(__HANDLE__, __INTERRUPT__) ((__HANDLE__)->Instance->CR1 &= (~(__INTERRUPT__))) |
| Disable the specified I2C interrupt. | |
| #define | __HAL_I2C_GET_IT_SOURCE(__HANDLE__, __INTERRUPT__) |
| Check whether the specified I2C interrupt source is enabled or not. | |
| #define | I2C_FLAG_MASK (0x0001FFFFU) |
| Check whether the specified I2C flag is set or not. | |
| #define | __HAL_I2C_GET_FLAG(__HANDLE__, __FLAG__) |
| #define | __HAL_I2C_CLEAR_FLAG(__HANDLE__, __FLAG__) |
| Clear the I2C pending flags which are cleared by writing 1 in a specific bit. | |
| #define | __HAL_I2C_ENABLE(__HANDLE__) (SET_BIT((__HANDLE__)->Instance->CR1, I2C_CR1_PE)) |
| Enable the specified I2C peripheral. | |
| #define | __HAL_I2C_DISABLE(__HANDLE__) (CLEAR_BIT((__HANDLE__)->Instance->CR1, I2C_CR1_PE)) |
| Disable the specified I2C peripheral. | |
| #define | __HAL_I2C_GENERATE_NACK(__HANDLE__) (SET_BIT((__HANDLE__)->Instance->CR2, I2C_CR2_NACK)) |
| Generate a Non-Acknowledge I2C peripheral in Slave mode. | |
| #define __HAL_I2C_CLEAR_FLAG | ( | __HANDLE__, | |
| __FLAG__ | |||
| __HANDLE__ | specifies the I2C Handle. |
| __FLAG__ | specifies the flag to clear. This parameter can be any combination of the following values:
| None |
| #define __HAL_I2C_DISABLE | ( | __HANDLE__ | ) | (CLEAR_BIT((__HANDLE__)->Instance->CR1, I2C_CR1_PE)) |
| None |
| #define __HAL_I2C_DISABLE_IT | ( | __HANDLE__, | |
| __INTERRUPT__ | |||
| ) | ((__HANDLE__)->Instance->CR1 &= (~(__INTERRUPT__))) |
| __INTERRUPT__ | specifies the interrupt source to disable. This parameter can be one of the following values:
| None |
| #define __HAL_I2C_ENABLE | ( | __HANDLE__ | ) | (SET_BIT((__HANDLE__)->Instance->CR1, I2C_CR1_PE)) |
| None |
| #define __HAL_I2C_ENABLE_IT | ( | __HANDLE__, | |
| __INTERRUPT__ | |||
| ) | ((__HANDLE__)->Instance->CR1 |= (__INTERRUPT__)) |
| __INTERRUPT__ | specifies the interrupt source to enable. This parameter can be one of the following values:
| None |
| #define __HAL_I2C_GENERATE_NACK | ( | __HANDLE__ | ) | (SET_BIT((__HANDLE__)->Instance->CR2, I2C_CR2_NACK)) |
| None |
| #define __HAL_I2C_GET_FLAG | ( | __HANDLE__, | |
| __FLAG__ | |||
| #define __HAL_I2C_GET_IT_SOURCE | ( | __HANDLE__, | |
| __INTERRUPT__ | |||
| __INTERRUPT__ | specifies the I2C interrupt source to check. This parameter can be one of the following values:
| The | new state of INTERRUPT (SET or RESET). |
| #define __HAL_I2C_RESET_HANDLE_STATE | ( | __HANDLE__ | ) | ((__HANDLE__)->State = HAL_I2C_STATE_RESET) |
| None |
| #define I2C_FLAG_MASK (0x0001FFFFU) |
| __FLAG__ | specifies the flag to check. This parameter can be one of the following values:
| The | new state of FLAG (SET or RESET). |
