RTEMS 6.2-rc2
| #define | __HAL_COMP_RESET_HANDLE_STATE(__HANDLE__) ((__HANDLE__)->State = HAL_COMP_STATE_RESET) |
| Reset COMP handle state. | |
| #define | COMP_CLEAR_ERRORCODE(__HANDLE__) ((__HANDLE__)->ErrorCode = HAL_COMP_ERROR_NONE) |
| Clear COMP error code (set it to no error code "HAL_COMP_ERROR_NONE"). | |
| #define | __HAL_COMP_ENABLE(__HANDLE__) SET_BIT((__HANDLE__)->Instance->CFGR, COMP_CFGRx_EN) |
| Enable the specified comparator. | |
| #define | __HAL_COMP_DISABLE(__HANDLE__) CLEAR_BIT((__HANDLE__)->Instance->CFGR, COMP_CFGRx_EN) |
| Disable the specified comparator. | |
| #define | __HAL_COMP_LOCK(__HANDLE__) SET_BIT((__HANDLE__)->Instance->CFGR, COMP_CFGRx_LOCK) |
| Lock the specified comparator configuration. | |
| #define | __HAL_COMP_IS_LOCKED(__HANDLE__) (READ_BIT((__HANDLE__)->Instance->CFGR, COMP_CFGRx_LOCK) == COMP_CFGRx_LOCK) |
| Check whether the specified comparator is locked. | |
| #define __HAL_COMP_DISABLE | ( | __HANDLE__ | ) | CLEAR_BIT((__HANDLE__)->Instance->CFGR, COMP_CFGRx_EN) |
| __HANDLE__ | COMP handle |
| None |
| #define __HAL_COMP_ENABLE | ( | __HANDLE__ | ) | SET_BIT((__HANDLE__)->Instance->CFGR, COMP_CFGRx_EN) |
| None |
| #define __HAL_COMP_IS_LOCKED | ( | __HANDLE__ | ) | (READ_BIT((__HANDLE__)->Instance->CFGR, COMP_CFGRx_LOCK) == COMP_CFGRx_LOCK) |
| Value | 0 if COMP instance is not locked, value 1 if COMP instance is locked |
| #define __HAL_COMP_LOCK | ( | __HANDLE__ | ) | SET_BIT((__HANDLE__)->Instance->CFGR, COMP_CFGRx_LOCK) |
| None |
| #define __HAL_COMP_RESET_HANDLE_STATE | ( | __HANDLE__ | ) | ((__HANDLE__)->State = HAL_COMP_STATE_RESET) |
| None |
| #define COMP_CLEAR_ERRORCODE | ( | __HANDLE__ | ) | ((__HANDLE__)->ErrorCode = HAL_COMP_ERROR_NONE) |
| None |
