RTEMS 6.2-rc2
Files | |
| file | fsl_cdog.h |
| struct | cdog_config_t |
Driver version | |
| enum | __cdog_debug_Action_ctrl_enum { kCDOG_DebugHaltCtrl_Run = 0x1 , kCDOG_DebugHaltCtrl_Pause = 0x2 } |
| enum | __cdog_irq_pause_ctrl_enum { kCDOG_IrqPauseCtrl_Run = 0x1 , kCDOG_IrqPauseCtrl_Pause = 0x2 } |
| enum | __cdog_fault_ctrl_enum { kCDOG_FaultCtrl_EnableReset = 0x1U , kCDOG_FaultCtrl_EnableInterrupt = 0x2U , kCDOG_FaultCtrl_NoAction = 0x4U } |
| enum | __code_lock_ctrl_enum { kCDOG_LockCtrl_Lock = 0x1 , kCDOG_LockCtrl_Unlock = 0x2 } |
| typedef uint32_t | secure_counter_t |
| void | CDOG_DriverIRQHandler (void) |
| #define | FSL_CDOG_DRIVER_VERSION (MAKE_VERSION(2, 1, 1)) |
| Defines CDOG driver version 2.1.1. | |
| #define | SC_ADD(add) |
| #define | SC_ADD1 |
| #define | SC_ADD16 |
| #define | SC_ADD256 |
| #define | SC_SUB(sub) |
| #define | SC_SUB1 |
| #define | SC_SUB16 |
| #define | SC_SUB256 |
| #define | SC_CHECK(val) |
CDOG Functional Operation | |
| status_t | CDOG_Init (CDOG_Type *base, cdog_config_t *conf) |
| Initialize CDOG. | |
| void | CDOG_Deinit (CDOG_Type *base) |
| Deinitialize CDOG. | |
| void | CDOG_GetDefaultConfig (cdog_config_t *conf) |
| Sets the default configuration of CDOG. | |
| void | CDOG_Stop (CDOG_Type *base, uint32_t stop) |
| Stops secure counter and instruction timer. | |
| void | CDOG_Start (CDOG_Type *base, uint32_t reload, uint32_t start) |
| Sets secure counter and instruction timer values. | |
| void | CDOG_Check (CDOG_Type *base, uint32_t check) |
| Checks secure counter. | |
| void | CDOG_Set (CDOG_Type *base, uint32_t stop, uint32_t reload, uint32_t start) |
| void | CDOG_Add (CDOG_Type *base, uint32_t add) |
| Add value to secure counter. | |
| void | CDOG_Add1 (CDOG_Type *base) |
| Add 1 to secure counter. | |
| void | CDOG_Add16 (CDOG_Type *base) |
| Add 16 to secure counter. | |
| void | CDOG_Add256 (CDOG_Type *base) |
| Add 256 to secure counter. | |
| void | CDOG_Sub (CDOG_Type *base, uint32_t sub) |
| void | CDOG_Sub1 (CDOG_Type *base) |
| Substract 1 from secure counter. | |
| void | CDOG_Sub16 (CDOG_Type *base) |
| Substract 16 from secure counter. | |
| void | CDOG_Sub256 (CDOG_Type *base) |
| Substract 256 from secure counter. | |
| void | CDOG_WritePersistent (CDOG_Type *base, uint32_t value) |
| Set the CDOG persistent word. | |
| uint32_t | CDOG_ReadPersistent (CDOG_Type *base) |
| Get the CDOG persistent word. | |
| #define FSL_CDOG_DRIVER_VERSION (MAKE_VERSION(2, 1, 1)) |
Change log:
| #define SC_ADD | ( | add | ) |
| #define SC_ADD1 |
| #define SC_ADD16 |
| #define SC_ADD256 |
| #define SC_CHECK | ( | val | ) |
| #define SC_SUB | ( | sub | ) |
| #define SC_SUB1 |
| #define SC_SUB16 |
| #define SC_SUB256 |
| void CDOG_Add | ( | CDOG_Type * | base, |
| uint32_t | add | ||
This function add specified value to secure counter.
| base | CDOG peripheral base address. |
| add | Value to be added. |
brief Add value to secure counter
param base CDOG peripheral base address. param add Value to be added.
| void CDOG_Add1 | ( | CDOG_Type * | base | ) |
This function add 1 to secure counter.
brief Add 1 to secure counter
| void CDOG_Add16 | ( | CDOG_Type * | base | ) |
This function add 16 to secure counter.
brief Add 16 to secure counter
| void CDOG_Add256 | ( | CDOG_Type * | base | ) |
This function add 256 to secure counter.
brief Add 256 to secure counter
| void CDOG_Check | ( | CDOG_Type * | base, |
| uint32_t | check | ||
This function compares stop value in handler with secure counter value by writting to RELOAD refister.
| base | CDOG peripheral base address |
| check | expected (stop) value |
brief Checks secure counter.
This function compares stop value with secure counter value by writting to RELOAD refister.
param base CDOG peripheral base address param check expected (stop) value.
| void CDOG_Deinit | ( | CDOG_Type * | base | ) |
Deinitialize CDOG.
This function deinitializes CDOG secure counter.
brief Deinitialize CDOG
This function stops CDOG secure counter.
| void CDOG_GetDefaultConfig | ( | cdog_config_t * | conf | ) |
This function initialize CDOG config structure to default values.
| conf | CDOG configuration structure |
brief Sets the default configuration of CDOG
param conf CDOG configuration structure
| status_t CDOG_Init | ( | CDOG_Type * | base, |
| cdog_config_t * | conf | ||
Initialize CDOG.
This function initializes CDOG block and setting.
brief Initialize CDOG
param base CDOG peripheral base address param conf CDOG configuration structure return Status of the init operation
| uint32_t CDOG_ReadPersistent | ( | CDOG_Type * | base | ) |
brief Get the CDOG persistent word.
param base CDOG peripheral base address. return The persistent word.
| void CDOG_Set | ( | CDOG_Type * | base, |
| uint32_t | stop, | ||
| uint32_t | reload, | ||
| uint32_t | start | ||
This function sets value in STOP, RELOAD and START registers for instruction timer and secure counter.
| stop | expected value which will be compared with value of secure counter |
| reload | reload value for instruction timer |
| start | start value for secure timer |
brief Sets secure counter and instruction timer values
param base CDOG peripheral base address param stop expected value which will be compared with value of secure counter param reload reload value for instruction timer param start start value for secure timer
| void CDOG_Start | ( | CDOG_Type * | base, |
This function sets value in RELOAD and START registers for instruction timer and secure counter
| reload | reload value |
| start | start value |
This function sets value in RELOAD and START registers for instruction timer.
param base CDOG peripheral base address param reload reload value param start start value
| void CDOG_Stop | ( | CDOG_Type * | base, |
| uint32_t | stop | ||
This function stops instruction timer and secure counter. This also change state od CDOG to IDLE.
brief Stops secure counter and instruction timer
This function stops instruction timer and secure counter. This also change state of CDOG to IDLE.
| void CDOG_Sub | ( | CDOG_Type * | base, |
| uint32_t | sub | ||
brief Substract value to secure counter
This function substract specified value to secure counter.
param base CDOG peripheral base address. param sub Value to be substracted.
| void CDOG_Sub1 | ( | CDOG_Type * | base | ) |
This function substract specified 1 from secure counter.
brief Substract 1 from secure counter
| void CDOG_Sub16 | ( | CDOG_Type * | base | ) |
This function substract specified 16 from secure counter.
brief Substract 16 from secure counter
| void CDOG_Sub256 | ( | CDOG_Type * | base | ) |
This function substract specified 256 from secure counter.
brief Substract 256 from secure counter
| void CDOG_WritePersistent | ( | CDOG_Type * | base, |
| uint32_t | value | ||
| value | The value to be written. |
brief Set the CDOG persistent word.
param base CDOG peripheral base address. param value The value to be written.
