RTEMS 6.2-rc2
| uint32_t | Dac_ConfigureDma (DacDma *pDacd, Dacc *pDacHw, uint8_t DacId, sXdmad *pXdmad) |
| Initializes the DacDma structure and the corresponding DAC & DMA . hardware select value. The driver will uses DMA channel 0 for RX . The DMA channels are freed automatically when no DMA command processing. | |
| uint32_t | Dac_SendData (DacDma *pDacd, DacCmd *pCommand) |
| Starts a DAC transfer. This is a non blocking function. It will return as soon as the transfer is started. | |
Implementation of Digital-to-Analog Converter Controller (DACC).
| pDacd | Pointer to a DacDma instance. |
| pDacHw | Associated Dac peripheral. |
| DacId | Dac peripheral identifier. |
| pDmad | Pointer to a Dmad instance. |
| pCommand | Pointer to the Dac command to execute. |
