RTEMS 6.2-rc1
Device configuration support. More...
#include <rtems/libio.h>Go to the source code of this file.
| #define | ZYNQ_DEVCFG_NAME "/dev/fpga" |
| #define | ZYNQ_DEVCFG_DRIVER_TABLE_ENTRY |
| #define | ZYNQ_DEVCFG_PCAP_DMA_ALIGN 64 |
| #define | ZYNQ_DEVCFG_CFG_DUMMY ( 0xffffffff ) |
| #define | ZYNQ_DEVCFG_CFG_BUS_WIDTH_SYNC ( 0x000000bb ) |
| #define | ZYNQ_DEVCFG_CFG_BUS_WIDTH_DETECT ( 0x11220044 ) |
| #define | ZYNQ_DEVCFG_CFG_SYNC ( 0xaa995566 ) |
| #define | ZYNQ_DEVCFG_CONFIG_FRAME_LEN ( 101 * 4 ) |
| Zynq configuration frame length in bytes. | |
| #define | ZYNQ_DEVCFG_IOCTL_VERSION_MAX_LEN 16 |
| rtems_device_driver | zynq_devcfg_init (rtems_device_major_number major, rtems_device_minor_number minor, void *args) |
| rtems_device_driver | zynq_devcfg_open (rtems_device_major_number major, rtems_device_minor_number minor, void *args) |
| rtems_device_driver | zynq_devcfg_close (rtems_device_major_number major, rtems_device_minor_number minor, void *args) |
| rtems_device_driver | zynq_devcfg_read (rtems_device_major_number major, rtems_device_minor_number minor, void *args) |
| Read from the PCAP controller. | |
| rtems_device_driver | zynq_devcfg_write (rtems_device_major_number major, rtems_device_minor_number minor, void *args) |
| Write to the PCAP controller. | |
| rtems_device_driver | zynq_devcfg_control (rtems_device_major_number major, rtems_device_minor_number minor, void *args) |
Provides support for the Zynq7000 series device configuration interface controller. PCAP command sequences are written using the write interface, and PCAP responses are retrieved with the read interface. The driver can be used for reconfiguration of the FPGA, and also reading FPGA configuration data for error checking.
| #define ZYNQ_DEVCFG_DRIVER_TABLE_ENTRY |
| enum zynq_devcfg_ioctl |
| rtems_device_driver zynq_devcfg_read | ( | rtems_device_major_number | major, |
| rtems_device_minor_number | minor, | ||
| void * | args | ||
Readback reads cannot be split into multiple DMA reads, this may cause the PCAP DMA to exhibit unexpected behavior. Therefore, the read length must match the preceding command sequence's expected data output length.
| rtems_device_driver zynq_devcfg_write | ( | rtems_device_major_number | major, |
| void * | args | ||
Data format: dword aligned bistream data or PCAP commands. Bitstream data is expected to be formatted as Vivado 2016.4 outputs BIN-format bitstreams by default (not bit-swapped) BUT with the byte order within each dword changed to little endian. See UG470 for information on data ordering.
