RTEMS 6.2-rc1
This structure represents an interrupt server. More...
#include <intr.h>
Data Fields | |
| Chain_Control | entries |
| This member is the chain of pending interrupt entries. | |
| rtems_id | server |
| This member is the identifier of the server task. | |
| unsigned long | errors |
| This member is the error count. | |
| uint32_t | index |
| This member is the server index. | |
| Chain_Node | node |
| This member is the node for the interrupt server registry. | |
| void(* | destroy )(struct rtems_interrupt_server_control *) |
| This member is the optional handler to destroy the interrupt server control. | |
The following constraints apply to this structure:
