RTEMS 6.2-rc1
FlexCAN Receive Message Buffer configuration structure. More...
#include <fsl_flexcan.h>
Data Fields | |
| uint32_t | id |
| flexcan_frame_format_t | format |
| flexcan_frame_type_t | type |
This structure is used as the parameter of FLEXCAN_SetRxMbConfig() function. The FLEXCAN_SetRxMbConfig() function is used to configure FlexCAN Receive Message Buffer. The function abort previous receiving process, clean the Message Buffer and activate the Rx Message Buffer using given Message Buffer setting.
