RTEMS 6.2-rc1
| u8 __attribute__::AddrCycles |
Number of address cycles
| u8 __attribute__::BitsPerCell |
Number of bits per cell
| u16 __attribute__::BlockEndurance |
Block endurance
| u16 __attribute__::BlockEnduranceGVB |
Block endurance for guaranteed valid block
| u32 __attribute__::BlocksPerLun |
Number of blocks per LUN
| u32 __attribute__::BytesPerPage |
Number of data bytes per page
| u32 __attribute__::BytesPerPartialPage |
Number of data bytes per partial page
| u16 __attribute__::ClkInputPinCap |
CLK input pin capacitance
| u16 __attribute__::Crc |
Integrity CRC
| u8 __attribute__::DateCode[2] |
Date code
| u8 __attribute__::DeviceManufacturer[12] |
Device manufacturer
| u8 __attribute__::DeviceModel[20] |
Device model
| u8 __attribute__::DrvStrength |
Driver strength support
| u8 __attribute__::EccBits |
Number of bits ECC correctability
| u16 __attribute__::ExtParamPageLen |
Extended Parameter Page Length
| u8 __attribute__::EzNandSupport |
EZ NAND support
| u16 __attribute__::Features |
Features supported
| u8 __attribute__::GuaranteedValidBlock |
Guaranteed valid blocks at beginning of target
| u16 __attribute__::InputPinCap |
Input pin capacitance typical
| u8 __attribute__::InputPinCapMax |
Input pin capacitance maximum
| u16 __attribute__::IOPinCap |
I/O pin capacitance
| u8 __attribute__::IOPinCapacitance |
I/O pin capacitance, maximum
| u8 __attribute__::JedecJtgPrmAdvCmd |
ONFI JEDEC JTG primary advanced command support
| u8 __attribute__::JedecManufacturerId |
JEDEC Manufacturer ID
| u16 __attribute__::MaxBadBlocksPerLun |
Bad blocks maximum per LUN
| u8 __attribute__::NumLuns |
Number of LUN's
| u8 __attribute__::NumOfParamPages |
Number of Parameter Pages
| u8 __attribute__::NVDDR2Features |
NVDDR2 Features
| u8 __attribute__::NVDDR2TimingMode |
NVDDR2 timing mode support
| u8 __attribute__::NVDDR2WarmupCycles |
NVDDR2 Warmup Cycles
| u8 __attribute__::NVDDRTimingMode |
NVDDR timing mode support
| u16 __attribute__::OptionalCmds |
Optional commands supported
| u32 __attribute__::PagesPerBlock |
Number of pages per block
| u8 __attribute__::PartialProgAttr |
Partial programming attributes
| u8 __attribute__::PlaneAddrBits |
Number of plane address bits
| u8 __attribute__::PlaneOperationAttr |
Multi-plane operation attributes
| u8 __attribute__::ProgramsPerPage |
Number of programs per page
| u8 __attribute__::Reserved0 |
Reserved (11)
| u8 __attribute__::Reserved1 |
Reserved (15-31)
| u8 __attribute__::Reserved2[13] |
Reserved (67-79)
| u8 __attribute__::Reserved3[12] |
Reserved (116 - 127)
| u8 __attribute__::Reserved4[4] |
Reserved (160 - 163)
| u16 __attribute__::Revision |
Revision Number
| u16 __attribute__::SDRPagecacheTimingMode |
SDR Program cache timing mode
| u16 __attribute__::SDRTimingMode |
SDR Timing mode support
| u8 __attribute__::Signature[4] |
Parameter page signature
| u16 __attribute__::SpareBytesPerPage |
Number of spare bytes per page
| u16 __attribute__::SpareBytesPerPartialPage |
Number of spare bytes per partial page
| u8 __attribute__::SynFeatures |
NVDDR/NVDDR2 features
| u16 __attribute__::TAdl |
Program page register clear enhancement value
| u16 __attribute__::TBers |
Maximum block erase time
| u16 __attribute__::TCcs |
Maximum change column setup time
| u16 __attribute__::TEr |
Typical page read time for EZ NAND
| u16 __attribute__::TMr |
Maximum multi-plane read time
| u16 __attribute__::TProg |
Maximum page program time
| u16 __attribute__::TR |
Maximum page read time
| u16 __attribute__::VendorRevisionNum |
Vendor specific revision number
| u8 __attribute__::VendorSpecific[88] |
Vendor specific
