RTEMS 6.2-rc1
The configuration of a new thread to initialize. More...
#include <threadimpl.h>
Data Fields | |
| const struct _Scheduler_Control * | scheduler |
| The scheduler control instance for the thread. | |
| void * | stack_area |
| The starting address of the stack area. | |
| size_t | stack_size |
| The size of the stack area in bytes. | |
| void(* | stack_free )(void *) |
| This member contains the handler to free the stack. | |
| Priority_Control | priority |
| The new thread's priority. | |
| const Thread_CPU_budget_operations * | cpu_budget_operations |
| The thread's initial CPU budget operations. | |
| uint32_t | name |
| 32-bit unsigned integer name of the object for the thread. | |
| uint32_t | isr_level |
| The thread's initial ISR level. | |
| bool | is_fp |
| Indicates whether the thread needs a floating-point area. | |
| bool | is_preemptible |
| Indicates whether the new thread is preemptible. | |
| void(* Thread_Configuration::stack_free) (void *) |
It shall not be NULL. Use _Objects_Free_nothing() if nothing is to free.
