RTEMS 6.2-rc1
Test context for spec:/score/tq/req/surrender-mrsp test case. More...
Data Fields | |
| bool | inherited_priorities_are_dispensible |
| If this member is true, then all priorities of the previous owner inherited from the thread queue thread shall be dispensable. | |
| bool | helping_schedules_are_dispensible |
| If this member is true, then all helping schedulers of the previous owner thread gained through the thread queue shall be dispensable. | |
| bool | use_helping_scheduler |
| If this member is true, then the previous owner thread shall use helping scheduler. | |
| bool | gains_new_helping_scheduler |
| If this member is true, then the new owner thread shall gain a vital helping scheduler. | |
| bool | suspended |
| If this member is true, then the new owner thread shall be suspended. | |
| bool | intend_to_block |
| If this member is true, then the new owner thread shall be in the intend to block wait state. | |
| rtems_task_priority | priority_before |
| This member contains the current priority of the previous owner thread before the thread queue surrender operation. | |
| rtems_task_priority | priority_after |
| This member contains the current priority of the previous owner thread after the thread queue surrender operation. | |
| rtems_id | previous_owner |
| This member contains the identifier of the previous owner thread. | |
| TQContext * | tq_ctx |
| This member contains a copy of the corresponding ScoreTqReqSurrenderMrsp_Run() parameter. | |
| struct { | |
| size_t pcs [6] | |
| This member defines the pre-condition states for the next action. | |
| bool in_action_loop | |
| If this member is true, then the test action loop is executed. | |
| size_t index | |
| This member contains the next transition map index. | |
| ScoreTqReqSurrenderMrsp_Entry entry | |
| This member contains the current transition map entry. | |
| bool skip | |
| If this member is true, then the current transition variant should be skipped. | |
| } | Map |
