RTEMS 6.2-rc1
Test context for spec:/rtems/task/req/exit test case. More...
Data Fields | |
| T_scheduler_log_4 | scheduler_log |
| This member provides the scheduler operation records. | |
| rtems_id | runner_id |
| This member contains the identifier of the runner task. | |
| rtems_id | worker_id |
| This member contains the identifier of the worker task. | |
| rtems_id | deleter_id |
| This member contains the identifier of the deleter task. | |
| rtems_id | extension_id |
| This member contains the identifier of the test user extensions. | |
| uint32_t | fatal_extension_calls |
| This member contains the count of fatal extension calls. | |
| uint32_t | delete_extension_calls |
| This member contains the count of thread delete extension calls. | |
| uint32_t | restart_extension_calls |
| This member contains the count of thread restart extension calls. | |
| uint32_t | terminate_extension_calls |
| This member contains the count of thread terminate extension calls. | |
| bool | protected |
| If this member is true, then the thread life of the worker is protected before the rtems_task_exit() call. | |
| bool | allocator_locked |
| If this member is true, then the worker locked the allocator. | |
| bool | restarting |
| If this member is true, then the worker is restarting before the rtems_task_exit() call. | |
| bool | terminating |
| If this member is true, then the worker is terminating before the rtems_task_exit() call. | |
| bool | dispatch_disabled |
| If this member is true, then thread dispatching is disabled by the worker task before the rtems_task_exit() call. | |
| bool | delete_worker_expected |
| If this member is true, then it is expected to delete the worker. | |
| struct { | |
| size_t pcs [4] | |
| This member defines the pre-condition states for the next action. | |
| bool in_action_loop | |
| If this member is true, then the test action loop is executed. | |
| size_t index | |
| This member contains the next transition map index. | |
| RtemsTaskReqExit_Entry entry | |
| This member contains the current transition map entry. | |
| bool skip | |
| If this member is true, then the current transition variant should be skipped. | |
| } | Map |
