RTEMS 6.2-rc1
Test context for spec:/rtems/support/req/is-name-valid test case. More...
Data Fields | |
| bool | result |
| This member contains the return value of the rtems_is_name_valid() call. | |
| rtems_name | name |
This member specifies if the name parameter value. | |
| struct { | |
| size_t pcs [1] | |
| This member defines the pre-condition states for the next action. | |
| bool in_action_loop | |
| If this member is true, then the test action loop is executed. | |
| size_t index | |
| This member contains the next transition map index. | |
| RtemsSupportReqIsNameValid_Entry entry | |
| This member contains the current transition map entry. | |
| bool skip | |
| If this member is true, then the current transition variant should be skipped. | |
| } | Map |
