RTEMS 6.2-rc1
Test context for spec:/rtems/sem/req/create test case. More...
Data Fields | |
| void * | seized_objects |
| rtems_status_code | status |
| Semaphore_Variant | variant |
| Semaphore_Discipline | discipline |
| uint32_t | sem_count |
| Thread_Control * | executing |
| Thread_Control * | owner |
| rtems_name | name |
| uint32_t | count |
| rtems_attribute | attribute_set |
| rtems_task_priority | priority_ceiling |
| rtems_id * | id |
| rtems_id | id_value |
| struct { | |
| size_t pcs [11] | |
| This member defines the pre-condition states for the next action. | |
| bool in_action_loop | |
| If this member is true, then the test action loop is executed. | |
| size_t index | |
| This member contains the next transition map index. | |
| RtemsSemReqCreate_Entry entry | |
| This member contains the current transition map entry. | |
| bool skip | |
| If this member is true, then the current transition variant should be skipped. | |
| } | Map |
