RTEMS 6.2-rc1
Test context for spec:/rtems/barrier/req/delete test case. More...
Data Fields | |
| rtems_id | worker_id |
| rtems_id | barrier_id |
| uint32_t | wait_done |
| uint32_t | wait_expected |
| rtems_id | id |
| rtems_status_code | status |
| struct { | |
| size_t pcs [1] | |
| This member defines the pre-condition states for the next action. | |
| bool in_action_loop | |
| If this member is true, then the test action loop is executed. | |
| size_t index | |
| This member contains the next transition map index. | |
| RtemsBarrierReqDelete_Entry entry | |
| This member contains the current transition map entry. | |
| bool skip | |
| If this member is true, then the current transition variant should be skipped. | |
| } | Map |
