RTEMS 6.2-rc1
RTEMS Run-Time Linker Unwind Support. More...
#include "rtl-elf.h"Go to the source code of this file.
| bool | rtems_rtl_elf_unwind_parse (const rtems_rtl_obj *obj, const char *name, uint32_t flags) |
| bool | rtems_rtl_elf_unwind_register (rtems_rtl_obj *obj) |
| bool | rtems_rtl_elf_unwind_deregister (rtems_rtl_obj *obj) |
| bool rtems_rtl_elf_unwind_deregister | ( | rtems_rtl_obj * | obj | ) |
Architecture specific handler to remove an object file's unwind information from the base image.
| obj | The object file. |
| true | The unwind information has been deregistered. |
| false | The unwind information could not be deregistered. |
| bool rtems_rtl_elf_unwind_parse | ( | const rtems_rtl_obj * | obj, |
| const char * | name, | ||
| uint32_t | flags | ||
Architecture specific handler to check if a section contains exception handler data..
| name | The section's name. |
| uint32 | flags The object file's flags. |
| true | The section contains unwind information. |
| false | The section does not contain unwind information. |
| bool rtems_rtl_elf_unwind_register | ( | rtems_rtl_obj * | obj | ) |
Architecture specific handler to add an object file's unwind information to the base image.
| true | The unwind information has been registered. |
| false | The unwind information could not be registered. |
