RTEMS 6.2-rc1
#include <sys/cdefs.h>#include <stdio.h>#include <rtems/rtl/rtl.h>#include <errno.h>#include "rtl-elf.h"#include "rtl-error.h"#include <rtems/rtl/rtl-trace.h>#include "rtl-unwind.h"#include "rtl-unwind-dw2.h"Functions | |
| uint32_t | rtems_rtl_elf_section_flags (const rtems_rtl_obj_t *obj, const Elf_Shdr *shdr) |
| uint32_t | rtems_rtl_elf_arch_parse_section (const rtems_rtl_obj *obj, int section, const char *name, const Elf_Shdr *shdr, const uint32_t flags) |
| bool | rtems_rtl_elf_arch_section_alloc (const rtems_rtl_obj *obj, rtems_rtl_obj_sect *sect) |
| bool | rtems_rtl_elf_arch_section_free (const rtems_rtl_obj *obj, rtems_rtl_obj_sect *sect) |
| bool | rtems_rtl_elf_rel_resolve_sym (Elf_Word type) |
| uint32_t | rtems_rtl_obj_tramp_alignment (const rtems_rtl_obj *obj) |
| size_t | rtems_rtl_elf_relocate_tramp_max_size (void) |
| rtems_rtl_elf_rel_status | rtems_rtl_elf_relocate_rela_tramp (rtems_rtl_obj *obj, const Elf_Rela *rela, const rtems_rtl_obj_sect *sect, const char *symname, const Elf_Byte syminfo, const Elf_Word symvalue) |
| rtems_rtl_elf_rel_status | rtems_rtl_elf_relocate_rela (rtems_rtl_obj *obj, const Elf_Rela *rela, const rtems_rtl_obj_sect *sect, const char *symname, const Elf_Byte syminfo, const Elf_Word symvalue) |
| rtems_rtl_elf_rel_status | rtems_rtl_elf_relocate_rel_tramp (rtems_rtl_obj *obj, const Elf_Rel *rel, const rtems_rtl_obj_sect *sect, const char *symname, const Elf_Byte syminfo, const Elf_Word symvalue) |
| rtems_rtl_elf_rel_status | rtems_rtl_elf_relocate_rel (rtems_rtl_obj *obj, const Elf_Rel *rel, const rtems_rtl_obj_sect *sect, const char *symname, const Elf_Byte syminfo, const Elf_Word symvalue) |
| bool | rtems_rtl_elf_unwind_parse (const rtems_rtl_obj *obj, const char *name, uint32_t flags) |
| bool | rtems_rtl_elf_unwind_register (rtems_rtl_obj *obj) |
| bool | rtems_rtl_elf_unwind_deregister (rtems_rtl_obj *obj) |
| uint32_t rtems_rtl_elf_arch_parse_section | ( | const rtems_rtl_obj * | obj, |
| int | section, | ||
| const char * | name, | ||
| const Elf_Shdr * | shdr, | ||
| const uint32_t | flags | ||
Architecture specific handler to parse the section and add any flags that may be need to handle the section.
| obj | The object file being relocated. |
| seciton | The section index. |
| name | The name of the section |
| shdr | The ELF section header. |
| flags | The standard ELF parsed flags. |
| uint32_t | Extra RTL object file flags. |
| bool rtems_rtl_elf_arch_section_alloc | ( | const rtems_rtl_obj * | obj, |
| rtems_rtl_obj_sect * | sect | ||
Architecture specific handler to allocate a section. Some sections are specific to an architecture and need special allocators.
| sect | The section data. |
| true | The allocator was successful. |
| bool rtems_rtl_elf_arch_section_free | ( | const rtems_rtl_obj * | obj, |
Architecture specific handler to free a section. Some sections are specific to an architecture and need special allocators.
| bool rtems_rtl_elf_rel_resolve_sym | ( | Elf_Word | type | ) |
Architecture specific handler to check is a relocation record's type is required to resolve a symbol.
| type | The type field in the relocation record. |
| true | The relocation record require symbol resolution. |
| false | The relocation record does not require symbol resolution. |
| rtems_rtl_elf_rel_status rtems_rtl_elf_relocate_rel | ( | rtems_rtl_obj * | obj, |
| const Elf_Rel * | rel, | ||
| const rtems_rtl_obj_sect * | sect, | ||
| const char * | symname, | ||
| const Elf_Byte | syminfo, | ||
| const Elf_Word | symvalue | ||
Architecture specific relocation handler compiled in for a specific architecture by the build system. The handler applies the relocation to the target.
| rel | The ELF relocation record. |
| sect | The section of the object file the relocation is for. |
| symname | The symbol's name. |
| syminfo | The ELF symbol info field. |
| symvalue | If a symbol is referenced, this is the symbols value. |
| rtems_rtl_elf_rel_status | The result of the trampoline parsing. |
| rtems_rtl_elf_rel_status rtems_rtl_elf_relocate_rel_tramp | ( | rtems_rtl_obj * | obj, |
Architecture specific relocation trampoline handler compiled in for a specific architecture by the build system. The handler determines if the relocation record requires a trampoline.
| rela | The ELF relocation record. |
| rtems_rtl_elf_rel_status rtems_rtl_elf_relocate_rela | ( | rtems_rtl_obj * | obj, |
| const Elf_Rela * | rela, | ||
| rela | The ELF addend relocation record. |
| rtems_rtl_elf_rel_status rtems_rtl_elf_relocate_rela_tramp | ( | rtems_rtl_obj * | obj, |
| size_t rtems_rtl_elf_relocate_tramp_max_size | ( | void | ) |
Architecture specific relocation maximum trampoline size. A trampoline entry of this size is allocated for each unresolved external.
| bool rtems_rtl_elf_unwind_deregister | ( | rtems_rtl_obj * | obj | ) |
Architecture specific handler to remove an object file's unwind information from the base image.
| obj | The object file. |
| true | The unwind information has been deregistered. |
| false | The unwind information could not be deregistered. |
| bool rtems_rtl_elf_unwind_parse | ( | const rtems_rtl_obj * | obj, |
Architecture specific handler to check if a section contains exception handler data..
| name | The section's name. |
| uint32 | flags The object file's flags. |
| true | The section contains unwind information. |
| false | The section does not contain unwind information. |
| bool rtems_rtl_elf_unwind_register | ( | rtems_rtl_obj * | obj | ) |
Architecture specific handler to add an object file's unwind information to the base image.
| true | The unwind information has been registered. |
| false | The unwind information could not be registered. |
| uint32_t rtems_rtl_obj_tramp_alignment | ( | const rtems_rtl_obj * | obj | ) |
The trampolinme alignment for the architecture.
This is implemented and set in the architecture backend.
| obj | The object file's descriptor. |
