RTEMS 6.2-rc1
RTC driver for the MCP7940M. More...
Files | |
| file | mcp7940m-rtc.h |
| This file provides the interfaces of Shared_tod_mcp7940m_rtc. | |
| file | mcp7940m.c |
| struct | mcp7940m_rtc |
| #define | MCP7940M_RTC_INITIALIZER(i2c_path, i2c_address, has_crystal) |
| #define | MCP7940M_RTC_TBL_ENTRY(dev_name, mcp7940m_rtc_ctx) I2C_RTC_TBL_ENTRY(dev_name, mcp7940m_rtc_ctx) |
| int | mcp7940m_hw_init (struct i2c_rtc_base *base) |
To use this driver, use the following initialization:
Define a context for the RTC somewhere:
static struct mcp7940m_rtc rtc_ctx = MCP7940M_RTC_INITIALIZER("/dev/i2c-1", 0x6F, true);
Then you can use the following for the RTC_Table:
MCP7940M_RTC_TBL_ENTRY("/dev/rtc", &rtc_ctx)
| #define MCP7940M_RTC_INITIALIZER | ( | i2c_path, | |
| i2c_address, | |||
| has_crystal | |||
| int mcp7940m_hw_init | ( | struct i2c_rtc_base * | base | ) |
Hardware init. Used internally.
