RTEMS 6.2-rc1
Driver version | |
| void | RDC_SEMA42_Init (RDC_SEMAPHORE_Type *base) |
| Initializes the RDC_SEMA42 module. | |
| void | RDC_SEMA42_Deinit (RDC_SEMAPHORE_Type *base) |
| De-initializes the RDC_SEMA42 module. | |
| status_t | RDC_SEMA42_TryLock (RDC_SEMAPHORE_Type *base, uint8_t gateNum, uint8_t masterIndex, uint8_t domainId) |
| Tries to lock the RDC_SEMA42 gate. | |
| void | RDC_SEMA42_Lock (RDC_SEMAPHORE_Type *base, uint8_t gateNum, uint8_t masterIndex, uint8_t domainId) |
| Locks the RDC_SEMA42 gate. | |
| int32_t | RDC_SEMA42_GetLockDomainID (RDC_SEMAPHORE_Type *base, uint8_t gateNum) |
| Gets which domain has currently locked the gate. | |
| status_t | RDC_SEMA42_ResetGate (RDC_SEMAPHORE_Type *base, uint8_t gateNum) |
| Resets the RDC_SEMA42 gate to an unlocked status. | |
| #define | FSL_RDC_SEMA42_DRIVER_VERSION (MAKE_VERSION(2, 0, 4)) |
| RDC_SEMA42 driver version. | |
| #define | RDC_SEMA42_GATE_NUM_RESET_ALL (64U) |
| The number to reset all RDC_SEMA42 gates. | |
| #define | RDC_SEMA42_GATEn(base, n) (((volatile uint8_t *)(&((base)->GATE0)))[(n)]) |
| RDC_SEMA42 gate n register address. | |
| #define | RDC_SEMA42_GATE_COUNT (64U) |
| RDC_SEMA42 gate count. | |
| #define | RDC_SEMAPHORE_GATE_GTFSM_MASK RDC_SEMAPHORE_GATE0_GTFSM_MASK |
| void RDC_SEMA42_Deinit | ( | RDC_SEMAPHORE_Type * | base | ) |
This function de-initializes the RDC_SEMA42 module. It only disables the clock.
| base | RDC_SEMA42 peripheral base address. |
brief De-initializes the RDC_SEMA42 module.
param base RDC_SEMA42 peripheral base address.
| int32_t RDC_SEMA42_GetLockDomainID | ( | RDC_SEMAPHORE_Type * | base, |
| uint8_t | gateNum | ||
| gateNum | Gate number. |
brief Gets which domain has currently locked the gate.
param base RDC_SEMA42 peripheral base address. param gateNum Gate number.
return Return -1 if the gate is not locked by any domain, otherwise return the domain ID.
| void RDC_SEMA42_Init | ( | RDC_SEMAPHORE_Type * | base | ) |
This function initializes the RDC_SEMA42 module. It only enables the clock but does not reset the gates because the module might be used by other processors at the same time. To reset the gates, call either RDC_SEMA42_ResetGate or RDC_SEMA42_ResetAllGates function.
brief Initializes the RDC_SEMA42 module.
| void RDC_SEMA42_Lock | ( | RDC_SEMAPHORE_Type * | base, |
| uint8_t | gateNum, | ||
| uint8_t | masterIndex, | ||
| uint8_t | domainId | ||
This function locks the specific RDC_SEMA42 gate. If the gate has been locked by other processors, this function waits until it is unlocked and then lock it.
| gateNum | Gate number to lock. |
| masterIndex | Current processor master index. |
| domainId | Current processor domain ID. |
brief Locks the RDC_SEMA42 gate.
param base RDC_SEMA42 peripheral base address. param gateNum Gate number to lock. param masterIndex Current processor master index. param domainId Current processor domain ID.
| status_t RDC_SEMA42_ResetGate | ( | RDC_SEMAPHORE_Type * | base, |
This function resets a RDC_SEMA42 gate to an unlocked status.
| kStatus_Success | RDC_SEMA42 gate is reset successfully. |
| kStatus_Failed | Some other reset process is ongoing. |
brief Resets the RDC_SEMA42 gate to an unlocked status.
retval kStatus_Success RDC_SEMA42 gate is reset successfully. retval kStatus_Failed Some other reset process is ongoing.
| status_t RDC_SEMA42_TryLock | ( | RDC_SEMAPHORE_Type * | base, |
This function tries to lock the specific RDC_SEMA42 gate. If the gate has been locked by another processor, this function returns an error code.
| kStatus_Success | Lock the sema42 gate successfully. |
| kStatus_Failed | Sema42 gate has been locked by another processor. |
brief Tries to lock the RDC_SEMA42 gate.
retval kStatus_Success Lock the sema42 gate successfully. retval kStatus_Failed Sema42 gate has been locked by another processor.
