RTEMS 6.2-rc1
i8259 Chip Support More...
Files | |
| file | i8259.h |
| Data structure and functions used to control i8259 chip. | |
Type definition for RTEMS managed interrupts | |
| typedef unsigned short | rtems_i8259_masks |
| volatile rtems_i8259_masks | i8259s_cache |
Function Prototypes | |
| void | BSP_i8259s_init (void) |
| int | BSP_irq_disable_at_i8259s (const rtems_irq_number irqLine) |
| function to disable a particular irq at 8259 level. | |
| int | BSP_irq_enable_at_i8259s (const rtems_irq_number irqLine) |
| function to enable a particular irq at 8259 level. | |
| int | BSP_irq_ack_at_i8259s (const rtems_irq_number irqLine) |
| function to acknowledge a particular irq at 8259 level. | |
| int | BSP_irq_enabled_at_i8259s (const rtems_irq_number irqLine) |
| function to check if a particular irq is enabled at 8259 level. | |
| int | BSP_i8259s_int_process (void) |
| void | BSP_rtems_irq_mng_init (unsigned cpuId) |
i8259 Chip Support
| int BSP_irq_ack_at_i8259s | ( | const rtems_irq_number | irqLine | ) |
After calling this function, if a device asserts an enabled interrupt line it will be propagated further to the processor. Mainly useful for people writing raw handlers as this is automagically done for RTEMS managed handlers.
| int BSP_irq_disable_at_i8259s | ( | const rtems_irq_number | irqLine | ) |
After calling this function, even if the device asserts the interrupt line it will not be propagated further to the processor.
| 1 | the interrupt was enabled originally |
| 0 | the interrupt was disabled originally |
| <0 | error |
| int BSP_irq_enable_at_i8259s | ( | const rtems_irq_number | irqLine | ) |
After calling this function, if the device asserts the interrupt line it will be propagated further to the processor.
