RTEMS 6.2-rc1
Files | |
| file | stringto.h |
| Convert String to Pointer (with validation) | |
| file | stringtodouble.c |
| Convert String to Double (with validation) | |
| file | stringtofloat.c |
| Convert String to Float (with validation) | |
| file | stringtoint.c |
| Convert String to Int (with validation) | |
| file | stringtolong.c |
| Convert String to Long (with validation) | |
| file | stringtolongdouble.c |
| Convert String to long double (with validation) | |
| file | stringtolonglong.c |
| Convert String to Long Long (with validation) | |
| file | stringtopointer.c |
| file | stringtounsignedchar.c |
| Convert String to Unsigned Character (with validation) | |
| file | stringtounsignedint.c |
| Convert String to Unsigned Int (with validation) | |
| file | stringtounsignedlong.c |
| Convert String to Unsigned Long Long (with validation) | |
| file | stringtounsignedlonglong.c |
| rtems_status_code | rtems_string_to_pointer (const char *s, void **n, char **endptr) |
| Convert String to Pointer (with validation). | |
| rtems_status_code | rtems_string_to_unsigned_char (const char *s, unsigned char *n, char **endptr, int base) |
| Convert String to Unsigned Character (with validation). | |
| rtems_status_code | rtems_string_to_int (const char *s, int *n, char **endptr, int base) |
| Convert String to Int (with validation). | |
| rtems_status_code | rtems_string_to_unsigned_int (const char *s, unsigned int *n, char **endptr, int base) |
| Convert String to Unsigned Int (with validation). | |
| rtems_status_code | rtems_string_to_long (const char *s, long *n, char **endptr, int base) |
| Convert String to Long (with validation). | |
| rtems_status_code | rtems_string_to_unsigned_long (const char *s, unsigned long *n, char **endptr, int base) |
| Convert String to Unsigned Long (with validation). | |
| rtems_status_code | rtems_string_to_long_long (const char *s, long long *n, char **endptr, int base) |
| Convert String to Long Long (with validation). | |
| rtems_status_code | rtems_string_to_unsigned_long_long (const char *s, unsigned long long *n, char **endptr, int base) |
| Convert String to Unsigned Long Long (with validation). | |
| rtems_status_code | rtems_string_to_float (const char *s, float *n, char **endptr) |
| Convert String to Float (with validation). | |
| rtems_status_code | rtems_string_to_double (const char *s, double *n, char **endptr) |
| Convert String to Double (with validation). | |
| rtems_status_code | rtems_string_to_long_double (const char *s, long double *n, char **endptr) |
| Convert String to long double (with validation). | |
| rtems_status_code rtems_string_to_double | ( | const char * | s, |
| double * | n, | ||
| char ** | endptr | ||
This method converts a string to a double with range validation.
| [in] | s | is the string to convert |
| [in] | n | points to the variable to place the converted output in |
| [in] | endptr | is used to keep track of the position in the string |
| This | method returns RTEMS_SUCCESSFUL on successful conversion and *n is filled in. Otherwise, the status indicates the source of the error. |
| rtems_status_code rtems_string_to_float | ( | const char * | s, |
| float * | n, | ||
This method converts a string to a float with range validation.
| rtems_status_code rtems_string_to_int | ( | const char * | s, |
| int * | n, | ||
| char ** | endptr, | ||
| int | base | ||
This method converts a string to an int with range validation.
| [in] | base | is the expected base of the number |
| rtems_status_code rtems_string_to_long | ( | const char * | s, |
| long * | n, | ||
| int | base | ||
This method converts a string to a long with range validation.
| rtems_status_code rtems_string_to_long_double | ( | const char * | s, |
| long double * | n, | ||
This method converts a string to a long double with range validation.
| rtems_status_code rtems_string_to_long_long | ( | const char * | s, |
| long long * | n, | ||
| int | base | ||
This method converts a string to a long long with range validation.
| rtems_status_code rtems_string_to_pointer | ( | const char * | s, |
| void ** | n, | ||
This method converts a string to a pointer (void *) with basic numeric validation.
| rtems_status_code rtems_string_to_unsigned_char | ( | const char * | s, |
| unsigned char * | n, | ||
| int | base | ||
This method converts a string to an unsigned character with range validation.
| rtems_status_code rtems_string_to_unsigned_int | ( | const char * | s, |
| unsigned int * | n, | ||
| int | base | ||
This method converts a string to an unsigned int with range validation.
| rtems_status_code rtems_string_to_unsigned_long | ( | const char * | s, |
| unsigned long * | n, | ||
| int | base | ||
This method converts a string to an unsigned long with range validation.
| rtems_status_code rtems_string_to_unsigned_long_long | ( | const char * | s, |
| unsigned long long * | n, | ||
| int | base | ||
