RTEMS 6.2-rc1
Legacy I2C library. More...
Files | |
| file | libi2c.h |
| Legacy I2C Library. | |
| struct | rtems_libi2c_bus_t_ |
| struct | rtems_libi2c_bus_ops_ |
| struct | rtems_libi2c_drv_t_ |
| struct | rtems_libi2c_read_write_t |
| struct | rtems_libi2c_tfr_mode_t |
| struct | rtems_libi2c_tfm_read_write_t |
| struct | rtems_libi2c_read_write_async_t |
| IO command data for asynchronous read and write. More... | |
| #define | RTEMS_LIBI2C_DRIVER_TABLE_ENTRY |
| #define | RTEMS_LIBI2C_MAKE_MINOR(busno, i2caddr) ((((busno)&((1<<3)-1))<<10) | ((i2caddr)&((1<<10)-1))) |
| #define | RTEMS_LIBI2C_IOCTL_READ_WRITE 1 |
| #define | RTEMS_LIBI2C_IOCTL_START_TFM_READ_WRITE 2 |
| #define | RTEMS_LIBI2C_IOCTL_SET_TFRMODE 3 |
| #define | RTEMS_LIBI2C_IOCTL_GET_DRV_T 4 |
| #define | RTEMS_LIBI2C_IOCTL_READ_WRITE_ASYNC 5 |
| IO control command for asynchronous read and write. | |
Typedefs | |
| typedef struct rtems_libi2c_bus_t_ | rtems_libi2c_bus_t |
| typedef struct rtems_libi2c_bus_ops_ | rtems_libi2c_bus_ops_t |
| typedef struct rtems_libi2c_drv_t_ | rtems_libi2c_drv_t |
| typedef void(* | rtems_libi2c_read_write_done_t) (int, int, void *) |
| Notification function type for asynchronous read and write. | |
| int | rtems_libi2c_initialize (void) |
| rtems_status_code | rtems_i2c_init (rtems_device_major_number major, rtems_device_minor_number minor, void *arg) |
| rtems_status_code | rtems_i2c_open (rtems_device_major_number major, rtems_device_minor_number minor, void *arg) |
| rtems_status_code | rtems_i2c_close (rtems_device_major_number major, rtems_device_minor_number minor, void *arg) |
| rtems_status_code | rtems_i2c_read (rtems_device_major_number major, rtems_device_minor_number minor, void *arg) |
| rtems_status_code | rtems_i2c_write (rtems_device_major_number major, rtems_device_minor_number minor, void *arg) |
| rtems_status_code | rtems_i2c_ioctl (rtems_device_major_number major, rtems_device_minor_number minor, void *arg) |
| int | rtems_libi2c_register_bus (const char *name, rtems_libi2c_bus_t *bus) |
| int | rtems_libi2c_register_drv (const char *name, rtems_libi2c_drv_t *drvtbl, unsigned bus, unsigned i2caddr) |
| rtems_status_code | rtems_libi2c_send_start (rtems_device_minor_number minor) |
| rtems_status_code | rtems_libi2c_send_stop (rtems_device_minor_number minor) |
| rtems_status_code | rtems_libi2c_send_addr (rtems_device_minor_number minor, int rw) |
| int | rtems_libi2c_read_bytes (rtems_device_minor_number minor, unsigned char *bytes, int nbytes) |
| int | rtems_libi2c_write_bytes (rtems_device_minor_number minor, const unsigned char *bytes, int nbytes) |
| int | rtems_libi2c_start_read_bytes (rtems_device_minor_number minor, unsigned char *bytes, int nbytes) |
| int | rtems_libi2c_start_write_bytes (rtems_device_minor_number minor, const unsigned char *bytes, int nbytes) |
| int | rtems_libi2c_ioctl (rtems_device_minor_number minor, int cmd,...) |
| const rtems_driver_address_table | rtems_libi2c_io_ops |
| rtems_device_major_number | rtems_libi2c_major |
Legacy I2C library.
| #define RTEMS_LIBI2C_DRIVER_TABLE_ENTRY |
| #define RTEMS_LIBI2C_IOCTL_READ_WRITE_ASYNC 5 |
| typedef void(* rtems_libi2c_read_write_done_t) (int, int, void *) |
