RTEMS 6.2-rc1
| #define | __HAL_WWDG_ENABLE(__HANDLE__) SET_BIT((__HANDLE__)->Instance->CR, WWDG_CR_WDGA) |
| Enable the WWDG peripheral. | |
| #define | __HAL_WWDG_ENABLE_IT(__HANDLE__, __INTERRUPT__) SET_BIT((__HANDLE__)->Instance->CFR, (__INTERRUPT__)) |
| Enable the WWDG early wakeup interrupt. | |
| #define | __HAL_WWDG_GET_IT(__HANDLE__, __INTERRUPT__) __HAL_WWDG_GET_FLAG((__HANDLE__),(__INTERRUPT__)) |
| Check whether the selected WWDG interrupt has occurred or not. | |
| #define | __HAL_WWDG_CLEAR_IT(__HANDLE__, __INTERRUPT__) __HAL_WWDG_CLEAR_FLAG((__HANDLE__), (__INTERRUPT__)) |
| Clear the WWDG interrupt pending bits. bits to clear the selected interrupt pending bits. | |
| #define | __HAL_WWDG_GET_FLAG(__HANDLE__, __FLAG__) (((__HANDLE__)->Instance->SR & (__FLAG__)) == (__FLAG__)) |
| Check whether the specified WWDG flag is set or not. | |
| #define | __HAL_WWDG_CLEAR_FLAG(__HANDLE__, __FLAG__) ((__HANDLE__)->Instance->SR = ~(__FLAG__)) |
| Clear the WWDG's pending flags. | |
| #define | __HAL_WWDG_GET_IT_SOURCE(__HANDLE__, __INTERRUPT__) |
| Check whether the specified WWDG interrupt source is enabled or not. | |
| #define __HAL_WWDG_CLEAR_FLAG | ( | __HANDLE__, | |
| __FLAG__ | |||
| ) | ((__HANDLE__)->Instance->SR = ~(__FLAG__)) |
| __HANDLE__ | WWDG handle |
| __FLAG__ | specifies the flag to clear. This parameter can be one of the following values:
| None |
| #define __HAL_WWDG_CLEAR_IT | ( | __HANDLE__, | |
| __INTERRUPT__ | |||
| ) | __HAL_WWDG_CLEAR_FLAG((__HANDLE__), (__INTERRUPT__)) |
| __INTERRUPT__ | specifies the interrupt pending bit to clear. This parameter can be one of the following values:
| #define __HAL_WWDG_ENABLE | ( | __HANDLE__ | ) | SET_BIT((__HANDLE__)->Instance->CR, WWDG_CR_WDGA) |
| None |
| #define __HAL_WWDG_ENABLE_IT | ( | __HANDLE__, | |
| __INTERRUPT__ | |||
| ) | SET_BIT((__HANDLE__)->Instance->CFR, (__INTERRUPT__)) |
| __INTERRUPT__ | specifies the interrupt to enable. This parameter can be one of the following values:
| None |
| #define __HAL_WWDG_GET_FLAG | ( | __HANDLE__, | |
| __FLAG__ | |||
| ) | (((__HANDLE__)->Instance->SR & (__FLAG__)) == (__FLAG__)) |
| __FLAG__ | specifies the flag to check. This parameter can be one of the following values:
| The | new state of WWDG_FLAG (SET or RESET). |
| #define __HAL_WWDG_GET_IT | ( | __HANDLE__, | |
| __INTERRUPT__ | |||
| ) | __HAL_WWDG_GET_FLAG((__HANDLE__),(__INTERRUPT__)) |
| __INTERRUPT__ | specifies the it to check. This parameter can be one of the following values:
| #define __HAL_WWDG_GET_IT_SOURCE | ( | __HANDLE__, | |
| __INTERRUPT__ | |||
| __HANDLE__ | WWDG Handle. |
| __INTERRUPT__ | specifies the WWDG interrupt source to check. This parameter can be one of the following values:
| state | of INTERRUPT (TRUE or FALSE). |
