RTEMS 6.2-rc1
| #define | VECT_TAB_OFFSET 0x00000000UL |
| #define | DATA_IN_ExtSRAM |
| #define | DATA_IN_ExtSDRAM |
| #define DATA_IN_ExtSDRAM |
Uncomment the following line if you need to relocate your vector Table in Internal SRAM.
| #define DATA_IN_ExtSRAM |
< Uncomment the following line if you need to use external SRAM or SDRAM mounted on EVAL board as data memory
| #define VECT_TAB_OFFSET 0x00000000UL |
< Uncomment the following line if you need to use initialized data in D2 domain SRAM (AHB SRAM)
< Uncomment the following line if you need to relocate your vector Table in Internal SRAM. Vector Table base offset field. This value must be a multiple of 0x200.
< Uncomment the following line if you need to use external SDRAM mounted on DISCO board as data memory
< Uncomment the following line if you need to use initialized data in CD domain AHB SRAM
