RTEMS 6.2-rc1
This group contains the atomic operations implementation. More...
Files | |
| file | atomic.h |
| This header file provides the interfaces of the Atomic Operations. | |
| file | libatomic.c |
| This source file contains the implementation of _Libatomic_Protect_start() and _Libatomic_Protect_end(). | |
Typedefs | |
| typedef unsigned int | Atomic_Uint |
| typedef unsigned long | Atomic_Ulong |
| typedef uintptr_t | Atomic_Uintptr |
| typedef bool | Atomic_Flag |
| typedef int | Atomic_Order |
Atomic operations can be used to implement low-level synchronization primitives on SMP systems, like spin locks. All atomic operations are defined in terms of C11 (ISO/IEC 9899:2011) or C++11 (ISO/IEC 14882:2011). For documentation use the standard documents.
