RTEMS 6.2-rc1
| #define | RDC_SEMAPHORE_GATE_COUNT (64U) |
GATE - Gate Register | |
| #define | RDC_SEMAPHORE_GATE_GTFSM_MASK (0xFU) |
| #define | RDC_SEMAPHORE_GATE_GTFSM_SHIFT (0U) |
| #define | RDC_SEMAPHORE_GATE_GTFSM(x) (((uint8_t)(((uint8_t)(x)) << RDC_SEMAPHORE_GATE_GTFSM_SHIFT)) & RDC_SEMAPHORE_GATE_GTFSM_MASK) |
| #define | RDC_SEMAPHORE_GATE_LDOM_MASK (0x30U) |
| #define | RDC_SEMAPHORE_GATE_LDOM_SHIFT (4U) |
| #define | RDC_SEMAPHORE_GATE_LDOM(x) (((uint8_t)(((uint8_t)(x)) << RDC_SEMAPHORE_GATE_LDOM_SHIFT)) & RDC_SEMAPHORE_GATE_LDOM_MASK) |
RSTGT_R - Reset Gate Read | |
| #define | RDC_SEMAPHORE_RSTGT_R_RSTGMS_MASK (0xFU) |
| #define | RDC_SEMAPHORE_RSTGT_R_RSTGMS_SHIFT (0U) |
| #define | RDC_SEMAPHORE_RSTGT_R_RSTGMS(x) (((uint16_t)(((uint16_t)(x)) << RDC_SEMAPHORE_RSTGT_R_RSTGMS_SHIFT)) & RDC_SEMAPHORE_RSTGT_R_RSTGMS_MASK) |
| #define | RDC_SEMAPHORE_RSTGT_R_RSTGSM_MASK (0x30U) |
| #define | RDC_SEMAPHORE_RSTGT_R_RSTGSM_SHIFT (4U) |
| #define | RDC_SEMAPHORE_RSTGT_R_RSTGSM(x) (((uint16_t)(((uint16_t)(x)) << RDC_SEMAPHORE_RSTGT_R_RSTGSM_SHIFT)) & RDC_SEMAPHORE_RSTGT_R_RSTGSM_MASK) |
| #define | RDC_SEMAPHORE_RSTGT_R_RSTGTN_MASK (0xFF00U) |
| #define | RDC_SEMAPHORE_RSTGT_R_RSTGTN_SHIFT (8U) |
| #define | RDC_SEMAPHORE_RSTGT_R_RSTGTN(x) (((uint16_t)(((uint16_t)(x)) << RDC_SEMAPHORE_RSTGT_R_RSTGTN_SHIFT)) & RDC_SEMAPHORE_RSTGT_R_RSTGTN_MASK) |
| #define RDC_SEMAPHORE_GATE_GTFSM | ( | x | ) | (((uint8_t)(((uint8_t)(x)) << RDC_SEMAPHORE_GATE_GTFSM_SHIFT)) & RDC_SEMAPHORE_GATE_GTFSM_MASK) |
GTFSM - Gate Finite State Machine. 0b0000..The gate is unlocked (free). 0b0001..The gate has been locked by processor with master_index = 0. 0b0010..The gate has been locked by processor with master_index = 1. 0b0011..The gate has been locked by processor with master_index = 2. 0b0100..The gate has been locked by processor with master_index = 3. 0b0101..The gate has been locked by processor with master_index = 4. 0b0110..The gate has been locked by processor with master_index = 5. 0b0111..The gate has been locked by processor with master_index = 6. 0b1000..The gate has been locked by processor with master_index = 7. 0b1001..The gate has been locked by processor with master_index = 8. 0b1010..The gate has been locked by processor with master_index = 9. 0b1011..The gate has been locked by processor with master_index = 10. 0b1100..The gate has been locked by processor with master_index = 11. 0b1101..The gate has been locked by processor with master_index = 12. 0b1110..The gate has been locked by processor with master_index = 13. 0b1111..The gate has been locked by processor with master_index = 14.
| #define RDC_SEMAPHORE_GATE_LDOM | ( | x | ) | (((uint8_t)(((uint8_t)(x)) << RDC_SEMAPHORE_GATE_LDOM_SHIFT)) & RDC_SEMAPHORE_GATE_LDOM_MASK) |
LDOM 0b00..The gate is locked by domain 0. (True if the field GTFSM does not equal to 0000.) 0b01..The gate has been locked by domain 1. 0b10..Reserved 0b11..Reserved
| #define RDC_SEMAPHORE_RSTGT_R_RSTGSM | ( | x | ) | (((uint16_t)(((uint16_t)(x)) << RDC_SEMAPHORE_RSTGT_R_RSTGSM_SHIFT)) & RDC_SEMAPHORE_RSTGT_R_RSTGSM_MASK) |
RSTGSM 0b00..Idle, waiting for the first data pattern write. 0b01..Waiting for the second data pattern write. 0b10..The 2-write sequence has completed. Generate the specified gate reset(s). After the reset is performed, this machine returns to the idle (waiting for first data pattern write) state. The "01" state persists for only one clock cycle. Software will never be able to observe this state. 0b11..This state encoding is never used and therefore reserved.
