RTEMS 6.2-rc1
PGMC
struct  _pgmc_bpc_cpu_power_mode_option
 The control option of the power domain controlled by CPU power mode. More...
struct  _pgmc_bpc_setpoint_mode_option
 The control option of the power domain controlled by setpoint mode. More...
Driver version
enum  {
  kPGMC_SetPoint0 = 1UL << 0UL , kPGMC_SetPoint1 = 1UL << 1UL , kPGMC_SetPoint2 = 1UL << 2UL , kPGMC_SetPoint3 = 1UL << 3UL ,
  kPGMC_SetPoint4 = 1UL << 4UL , kPGMC_SetPoint5 = 1UL << 5UL , kPGMC_SetPoint6 = 1UL << 6UL , kPGMC_SetPoint7 = 1UL << 7UL ,
  kPGMC_SetPoint8 = 1UL << 8UL , kPGMC_SetPoint9 = 1UL << 9UL , kPGMC_SetPoint10 = 1UL << 10UL , kPGMC_SetPoint11 = 1UL << 11UL ,
  kPGMC_SetPoint12 = 1UL << 12UL , kPGMC_SetPoint13 = 1UL << 13UL , kPGMC_SetPoint14 = 1UL << 14UL , kPGMC_SetPoint15 = 1UL << 15UL
 The enumeration of setpoint. . More...
enum  _pgmc_mif_signal_behaviour {
  kPGMC_AssertSleepSignal = 1U << 0U , kPGMC_AssertInputGateSignal = 1U << 1U , kPGMC_AssetLowSpeedSignal = 1U << 2U , kPGMC_AssertHighSpeedSignal = 1U << 3U ,
  kPGMC_AssertStandbySignal = 1U << 4U , kPGMC_AssertArrayPowerDownSignal = 1U << 5U , kPGMC_AssertPeripheralPowerDownSignal = 1U << 6U , kPGMC_AssertInitnSignal = 1U << 7U ,
  kPGMC_AssertSwitch1OffSignal = 1U << 8U , kPGMC_AssertSwitch2OffSignal = 1U << 9U , kPGMC_AssertIsoSignal = 1U << 10U
 The enumeration of MIF signal behaviour(Such as Sleep Signal, Standby Signal, and so on). More...
enum  _pgmc_bpc_assign_domain { kPGMC_CM7Core = 0U , kPGMC_CM4Core = 1U }
 PGMC BPC assign domain enumeration. More...
enum  _pgmc_cpu_mode { kPGMC_RunMode = 0x0UL , kPGMC_WaitMode = 0x1UL , kPGMC_StopMode = 0x2UL , kPGMC_SuspendMode = 0x3UL }
 CPU mode. More...
enum  _pgmc_control_mode { kPGMC_DisableLowPowerControl = 0UL , kPGMC_ControlledByCpuPowerMode = 1UL , kPGMC_ControlledBySetPoint = 2UL }
 PGMC control modes.
enum  _pgmc_memory_low_power_level {
  kPGMC_MLPLHighSpeed = 1U , kPGMC_MLPLNormal = 3U , kPGMC_MLPLLowSpeed = 4U , kPGMC_MLPLInputGating = 5U ,
  kPGMC_MLPLStandby = 6U , kPGMC_MLPLSleep = 8U , kPGMC_MLPLArrOnPerOff = 9U , kPGMC_MLPLArrOffPerOn = 10U ,
  kPGMC_MLPLArrOffPerOff = 11U , kPGMC_MLPLSw2 = 13U , kPGMC_MLPLSw2PerOff = 14U , kPGMC_MLPLSw1PerOff = 15U
 The enumeration of memory low power level. More...
enum  _pgmc_mif_signal {
  kPGMC_SleepSignal = 0U , kPGMC_InputGateSignal = 1U , kPGMC_LowSpeedSignal = 2U , kPGMC_HighSpeedSignal = 3U ,
  kPGMC_StandbySignal = 4U , kPGMC_ArrayPowerDownSignal = 5U , kPGMC_PeripheralPowerDownSignal = 6U , kPGMC_InitnSignal = 7U ,
  kPGMC_Switch1OffSignal = 8U , kPGMC_Switch2OffSignal = 9U , kPGMC_IsoSignal = 10U
 The enumeration of MIF signal. More...
typedef enum _pgmc_bpc_assign_domain pgmc_bpc_assign_domain_t
typedef enum _pgmc_cpu_mode pgmc_cpu_mode_t
 CPU mode.
typedef enum _pgmc_control_mode pgmc_control_mode_t
 PGMC control modes.
typedef enum _pgmc_memory_low_power_level pgmc_memory_low_power_level_t
typedef enum _pgmc_mif_signal pgmc_mif_signal_t
typedef struct _pgmc_bpc_cpu_power_mode_option pgmc_bpc_cpu_power_mode_option_t
typedef struct _pgmc_bpc_setpoint_mode_option pgmc_bpc_setpoint_mode_option_t
#define FSL_PGMC_RIVER_VERSION   (MAKE_VERSION(2, 1, 1))
 PGMC driver version 2.1.1.
Basic Power Controller Related Interfaces
void PGMC_BPC_ControlPowerDomainByCpuPowerMode (PGMC_BPC_Type *base, pgmc_cpu_mode_t mode, const pgmc_bpc_cpu_power_mode_option_t *option)
 Makes the BPC module controlled by the target CPU power mode, such as Wait mode.
void PGMC_BPC_ControlPowerDomainBySetPointMode (PGMC_BPC_Type *base, uint32_t setPointMap, const pgmc_bpc_setpoint_mode_option_t *option)
 Makes the BPC module controlled by the target set points.
void PGMC_BPC_ControlPowerDomainBySoftwareMode (PGMC_BPC_Type *base, bool powerOff)
 Controls the selected power domain by software mode.
CPU Power Controller Related Interfaces
void PGMC_CPC_CORE_PowerOffByCpuPowerMode (PGMC_CPC_Type *base, pgmc_cpu_mode_t mode)
 Powers off the CPC core module by the target CPU power mode, such as Wait mode.
void PGMC_CPC_CACHE_ControlByCpuPowerMode (PGMC_CPC_Type *base, pgmc_cpu_mode_t mode, pgmc_memory_low_power_level_t memoryLowPowerLevel)
 Makes the CPC CACHE module controlled by the target CPU power mode, such as Wait mode.
void PGMC_CPC_CACHE_ControlBySetPointMode (PGMC_CPC_Type *base, uint32_t setPointMap, pgmc_memory_low_power_level_t memoryLowPowerLevel)
 Makes the CPC CACHE module controlled by the target set points.
void PGMC_CPC_CACHE_TriggerMLPLSoftwareChange (PGMC_CPC_Type *base)
 Requests CPC cache module's memory low power level change by software mode.
void PGMC_CPC_LMEM_ControlByCpuPowerMode (PGMC_CPC_Type *base, pgmc_cpu_mode_t mode, pgmc_memory_low_power_level_t memoryLowPowerLevel)
 Makes the CPC LMEM module controlled by the target CPU power mode, such as Wait mode.
void PGMC_CPC_LMEM_ControlBySetPointMode (PGMC_CPC_Type *base, uint32_t setPointMap, pgmc_memory_low_power_level_t memoryLowPowerLevel)
 Makes the CPC LMEM module controlled by the target set points.
void PGMC_CPC_LMEM_TriggerMLPLSoftwareChange (PGMC_CPC_Type *base)
 Requests CPC LMEM module's memory low power level change in software mode.
MIF Module Related APIs
void PGMC_MIF_SetSignalBehaviour (PGMC_MIF_Type *base, pgmc_memory_low_power_level_t memoryLevel, uint32_t mask)
 Sets the behaviour of each signal in MIF, such as Sleep signal.
PMIC Power Related Interfaces
void PGMC_PPC_ControlByCpuPowerMode (PGMC_PPC_Type *base, pgmc_cpu_mode_t mode)
 Makes the PMIC module controlled by the target CPU power mode, such as Wait mode.
void PGMC_PPC_ControlBySetPointMode (PGMC_PPC_Type *base, uint32_t setPointMap, bool enableStandby)
 Makes the PMIC module controlled by the target set points.
◆ anonymous enum
anonymous enum
kPGMC_SetPoint0
The mask of set point0.
kPGMC_SetPoint1
The mask of set point1.
kPGMC_SetPoint2
The mask of set point2.
kPGMC_SetPoint3
The mask of set point3.
kPGMC_SetPoint4
The mask of set point4.
kPGMC_SetPoint5
The mask of set point5.
kPGMC_SetPoint6
The mask of set point6.
kPGMC_SetPoint7
The mask of set point7.
kPGMC_SetPoint8
The mask of set point8.
kPGMC_SetPoint9
The mask of set point9.
kPGMC_SetPoint10
The mask of set point10.
kPGMC_SetPoint11
The mask of set point11.
kPGMC_SetPoint12
The mask of set point12.
kPGMC_SetPoint13
The mask of set point13.
kPGMC_SetPoint14
The mask of set point14.
kPGMC_SetPoint15
The mask of set point15.
◆ _pgmc_bpc_assign_domain
kPGMC_CM7Core
CM7 Core domain.
kPGMC_CM4Core
CM4 Core domain.
◆ _pgmc_cpu_mode
CPU mode.
kPGMC_RunMode
RUN mode.
kPGMC_WaitMode
WAIT mode.
kPGMC_StopMode
STOP mode.
kPGMC_SuspendMode
SUSPEND mode.
◆ _pgmc_memory_low_power_level
kPGMC_MLPLHighSpeed
Memory low power level: High speed.
kPGMC_MLPLNormal
Memory low power level: Normal.
kPGMC_MLPLLowSpeed
Memory low power level: Low Speed.
Memory low power level: Input Gating.
kPGMC_MLPLStandby
Memory low power level: Standby.
kPGMC_MLPLSleep
Memory low power level: Sleep.
Memory low power level: Arr on per off.
Memory low power level: Arr off per on.
Memory low power level: Arr off per off.
kPGMC_MLPLSw2
Memory low power level: SW2.
kPGMC_MLPLSw2PerOff
Memory low power level: SW2 Per off.
kPGMC_MLPLSw1PerOff
Memory low power level: SW1 Per off.
◆ _pgmc_mif_signal
kPGMC_SleepSignal
MIF Sleep signal.
MIF InputGate signal.
MIF LowSpeed signal.
MIF HighSpeed signal.
kPGMC_StandbySignal
MIF Standby signal.
MIF ArrayPowerDown signal.
MIF PeripheralPowerDown signal.
kPGMC_InitnSignal
MIF Initn signal.
MIF Switch1Off signal.
MIF Switch2Off signal.
kPGMC_IsoSignal
MIF Iso_en signal.
◆ _pgmc_mif_signal_behaviour
Assert Sleep signal.
Assert InputGate signal.
Assert LowSpeed signal.
Assert HighSpeed signal.
Assert Standby signal.
Assert ArrayPowerDown signal.
Assert PeripheralPowerDown signal.
Assert Initn signal.
Assert Switch1Off signal.
Assert Switch2Off signal.
Assert Iso_en signal.
◆ PGMC_BPC_ControlPowerDomainByCpuPowerMode()
void PGMC_BPC_ControlPowerDomainByCpuPowerMode ( PGMC_BPC_Type base,
const pgmc_bpc_cpu_power_mode_option_t option
This function makes the module controlled by four typical CPU power modes, It also configs the resource domain and set memory low power level.
Parameters
basePGMC basic power controller base address.
modeTarget CPU power mode.
optionThe pointer of pgmc_bpc_cpu_power_mode_option_t structure.
brief Makes the BPC module controlled by the target CPU power mode(Such as Wait mode).
param base PGMC basic power controller base address. param mode Target CPU power mode. param option The pointer of pgmc_bpc_cpu_power_mode_option_t structure.
◆ PGMC_BPC_ControlPowerDomainBySetPointMode()
void PGMC_BPC_ControlPowerDomainBySetPointMode ( PGMC_BPC_Type base,
const pgmc_bpc_setpoint_mode_option_t option
This function makes the module controlled by specific set point, It also supports set memory lowe power level.
Note
When setting more than one set point, use "|" between the map values in _pgmc_setpoint_map.
Parameters
setPointMapShould be the OR'ed value of _pgmc_setpoint_map.
optionThe pointer of pgmc_bpc_setpoint_mode_option_t structure.
brief Makes the BPC module controlled by the target set points.
note When setting more than one set point, use "|" between the map values in _pgmc_setpoint_map.
param base PGMC basic power controller base address. param setPointMap Should be the OR'ed value of _pgmc_setpoint_map. param option The pointer of pgmc_bpc_setpoint_mode_option_t structure.
◆ PGMC_BPC_ControlPowerDomainBySoftwareMode()
void PGMC_BPC_ControlPowerDomainBySoftwareMode ( PGMC_BPC_Type base,
bool  powerOff
Note
The function is used to control power domain when the CPU is in RUN mode.
Parameters
powerOffPower On/Off power domain in software mode.
  • true Power off the power domain in software mode.
  • false Power on the power domain in software mode.
brief Controls the selected power domain by software mode.
note The function is used to control power domain when the CPU is in RUN mode.
param base PGMC basic power controller base address. param powerOff Power On/Off power domain in software mode.
◆ PGMC_CPC_CACHE_ControlByCpuPowerMode()
void PGMC_CPC_CACHE_ControlByCpuPowerMode ( PGMC_CPC_Type base,
This function makes the module controlled by four typical CPU power modes, it also can set memory low power level.
Parameters
baseCPC CACHE module base address.
memoryLowPowerLevelMemory low power level.
brief Makes the CPC CACHE module controlled by the target CPU power mode(Such as Wait mode).
param base CPC CACHE module base address. param mode Target CPU power mode. param memoryLowPowerLevel Memory low power level.
◆ PGMC_CPC_CACHE_ControlBySetPointMode()
void PGMC_CPC_CACHE_ControlBySetPointMode ( PGMC_CPC_Type base,
Note
Parameters
brief Makes the CPC CACHE module controlled by the target set points.
param base CPC CACHE module base address. param setPointMap Should be the OR'ed value of _pgmc_setpoint_map. param memoryLowPowerLevel Memory low power level.
◆ PGMC_CPC_CACHE_TriggerMLPLSoftwareChange()
void PGMC_CPC_CACHE_TriggerMLPLSoftwareChange ( PGMC_CPC_Type base)
Note
If request memory low power level change, must wait the MLPL transition complete.
Parameters
baseCPC LMEM module base address.
brief Requests CPC cache module's memory low power level change by software mode.
note If request memory low power level change, must wait the MLPL transition complete.
param base CPC LMEM module base address.
◆ PGMC_CPC_CORE_PowerOffByCpuPowerMode()
void PGMC_CPC_CORE_PowerOffByCpuPowerMode ( PGMC_CPC_Type base,
Parameters
baseCPC CORE module base address.
brief Powers off the CPC core module by the target CPU power mode(Such as Wait mode).
param base CPC CORE module base address. param mode Target CPU power mode.
◆ PGMC_CPC_LMEM_ControlByCpuPowerMode()
void PGMC_CPC_LMEM_ControlByCpuPowerMode ( PGMC_CPC_Type base,
Parameters
brief Makes the CPC LMEM module controlled by the target CPU power mode(Such as Wait mode).
param base CPC LMEM module base address. param mode Target CPU power mode. param memoryLowPowerLevel Memory low power level.
◆ PGMC_CPC_LMEM_ControlBySetPointMode()
void PGMC_CPC_LMEM_ControlBySetPointMode ( PGMC_CPC_Type base,
Note
Parameters
brief Makes the CPC LMEM module controlled by the target set points.
param base CPC LMEM module base address. param setPointMap Should be the OR'ed value of _pgmc_setpoint_map. param memoryLowPowerLevel Memory low power level.
◆ PGMC_CPC_LMEM_TriggerMLPLSoftwareChange()
void PGMC_CPC_LMEM_TriggerMLPLSoftwareChange ( PGMC_CPC_Type base)
Note
Parameters
brief Requests CPC LMEM module's memory low power level change in software mode.
◆ PGMC_MIF_SetSignalBehaviour()
void PGMC_MIF_SetSignalBehaviour ( PGMC_MIF_Type base,
uint32_t  mask
Note
To control the memory low power operation, this function must be invoked after selecting the memory low power level. Use case:
kPGMC_MLPLSleep, false);
#define PGMC_BPC0_BASE
Definition: MIMXRT1166_cm4.h:66761
void PGMC_MIF_SetSignalBehaviour(PGMC_MIF_Type *base, pgmc_memory_low_power_level_t memoryLevel, uint32_t mask)
Definition: fsl_pgmc.c:392
void PGMC_BPC_ControlPowerDomainByCpuPowerMode(PGMC_BPC_Type *base, pgmc_cpu_mode_t mode, const pgmc_bpc_cpu_power_mode_option_t *option)
Definition: fsl_pgmc.c:48
@ kPGMC_WaitMode
Definition: fsl_pgmc.h:83
@ kPGMC_CM7Core
Definition: fsl_pgmc.h:75
@ kPGMC_MLPLSleep
Definition: fsl_pgmc.h:106
@ kPGMC_AssertSleepSignal
Definition: fsl_pgmc.h:57
Parameters
basePGMC MIF peripheral base address.
memoryLevelThe selected memory low power level. For details please refer to pgmc_memory_low_power_level_t.
maskThe mask of MIF signal behaviour. Should be the OR'ed value of _pgmc_mif_signal_behaviour
brief Sets the behaviour of each signal(Such as Sleep signal) in MIF.
note To control the memory low power operation, this function must be invoked after selecting the memory low power level. Use case: code PGMC_BPC_ControlPowerDomainByCpuPowerMode(PGMC_BPC0_BASE, kPGMC_WaitMode, kPGMC_CM7Core, kPGMC_MLPLSleep, false); PGMC_MIF_SetSignalBehaviour(PGMC_BPC0_MIF_BASE, kPGMC_MLPLSleep, kPGMC_AssertSleepSignal); endcode
param base PGMC MIF peripheral base address. param memoryLevel The selected memory low power level. For details please refer to pgmc_memory_low_power_level_t. param mask The mask of MIF signal behaviour. Should be the OR'ed value of _pgmc_mif_signal_behaviour
◆ PGMC_PPC_ControlByCpuPowerMode()
void PGMC_PPC_ControlByCpuPowerMode ( PGMC_PPC_Type base,
Parameters
basePMIC module base address.
brief Makes the PMIC module controlled by the target CPU power mode(Such as Wait mode).
param base PMIC module base address. param mode Target CPU power mode.
◆ PGMC_PPC_ControlBySetPointMode()
void PGMC_PPC_ControlBySetPointMode ( PGMC_PPC_Type base,
bool  enableStandby
This function makes the module controlled by specific set point, It also supports PMIC standby on.
Note
Parameters
enableStandbytrue: PMIC standby on when system enters set point number and system is in standby mode. false: PMIC standby on when system enters set point number
brief Makes the PMIC module controlled by the target set points.
param base PMIC module base address. param setPointMap Should be the OR'ed value of _pgmc_setpoint_map. param enableStandby true: PMIC standby on when system enters set point number and system is in standby mode. false: PMIC standby on when system enters set point number
